查看: 2092|回复: 0
Cadence Joules RTL Power Solution 21.16.000-ISR6
发表于 2023-6-2 05:51:00 | 显示全部楼层 |阅读模式
Cadence Design Systems, Inc. , the leader in global electronic design innovation, has unveiled Cadence Joules RTL Power Solution 21.16.000-ISR6 Hotfix. This solution delivering time based RTL power analysis with system-level runtimes and capacity, as well as high- quality estimates of gates and wires based on production implementation technology.
Getting an accurate measure of RTL power consumption during design exploration has long been a major challenge for SoC design teams. Another challenge is getting consistent power through the design progress from RTL to P&R, because different tools are used at different stages of the design. -level verification tools have the capacity to exercise real use cases but they are disconnected from the implementation tools that translate RTL to gates and wires. The Cadence Joules RTL Power Solutioncloses this gap by delivering timebased RTL power analysis with system-level runtimes and capacity, as well as high-quality estimates of gates and wires based on production implementation technology. The Joules RTL Power Solution integrates seamlessly with the Cadence Palladium emulation platforms and the Stratus High-Level Synthesis (HLS) platform for early system-level power 2.0% analysis and optimization. The Cadence Genus Synthesis Solution integrates the Joules solution for accurate power analysis and unrivaled dynamic power efficiency results.
Cadence is a pivotal leader in electronic design and computational expertise, using its Intelligent System Design strategy to turn design concepts into reality. Cadence customers are the world's most creative and innovative companies, delivering extraordinary electronic products from chips to boards to systems for the most dynamic market applications.
*****Please note*****
If you are interested in the full licensed software  Cadence Joules RTL Power Solution 21.16.000-ISR6 with full feature license, then do well to contact     fast.forever24@gmail.com
GMT+8, 2025-12-25 21:29 , Processed in 0.012504 second(s), 3 queries , Gzip On, Redis On.
