查看: 7490|回复: 16
[求助] 有使用过SMIC工艺后仿用QRC的前辈吗
发表于 2023-5-28 17:00:45 | 显示全部楼层 |阅读模式
查看了一下SMIC180BCD和SMIC55的库,参数提取都用的是QRC
研究了一周多,现在是最后提取一直失败
论坛里的帖子也是很久的,没有解决办法,再来求助一下大家。
QRC这个tech lib是工艺库还是他的QRCtechfiles呢
Virtuoso Framework License (111) was checked out successfully. Total checkout time was 0.02s.
device n18 M ngate18 n18 ivpcell smic18bcdepi D G S B
Loading smic18bcdepi/libInit.il ...
        Loading smic18bcdepi/loadCxt.ile ... done!
        Loading context 'smic18bcdepi' from library 'smic18bcdepi' ... done!
        Loading context 'pdkUtils' from library 'smic18bcdepi' ... done!
        Loading smic18bcdepi/libInitCktPro.il ... done!
        Loading smic18bcdepi/libInitCustomExit.il ... Loading libInitCustomExit.il for smic18bcdepi
done!
Loaded smic18bcdepi/libInit.il successfully!
Loading smic skill utility
file="batchSetCDF.ile"loadfile="/home/IC/AIWEI_L_W_Z/PDK/smic18_Epi_1P6M_TM1_MTT2_HRP3k_MIM2_TYP2_oa_cds_v1.14_rev0_0_cciqrc/smic18bcdepi/../SMIC18_skillUtility/batchSetCDF.ile"/home/IC/AIWEI_L_W_Z/PDK/smic18_Epi_1P6M_TM1_MTT2_HRP3k_MIM2_TYP2_oa_cds_v1.14_rev0_0_cciqrc/smic18bcdepi/../SMIC18_skillUtility/batchSetCDF.ile
*Error* eval: undefined function - ciwMenuInit
*Error* load: error while loading file - "/home/IC/AIWEI_L_W_Z/PDK/smic18_Epi_1P6M_TM1_MTT2_HRP3k_MIM2_TYP2_oa_cds_v1.14_rev0_0_cciqrc/smic18bcdepi/../SMIC18_skillUtility/batchSetCDF.ile" at line 0
device xxxxxx几十行器件描述
All device symbols for the extracted view are present.
INFO (LBRCXU-114): Finished /opt/eda/cadence/IC618/bin/qrcToDfII
INFO (LBRCXM-642): Constructing the RCX run script
WARNING (RCXSPIC-27104): p2lvsfile in tech directory does not have resistance
temperature coefficients (TC1, TC2). ?temperature is ignored
agdsPrep: error while loading shared libraries: libtermcap.so.2: cannot open shared object file: No such file or directory
INFO (RCXSPIC-27150): The following forked command failed. Contact Cadence Customer Support for assistance.
agdsPrep -V -rundir XXXXXX(一堆目录,指向query_output)
Forking: agdsPrep -V -rundir XXXXXX(一堆目录,指向query_output)
ERROR (LBRCXM-644): Bad return status from RCX script generator. 0x100
INFO (LBRCXM-709): *****  Quantus QRC terminated abnormally  *****
 楼主| 发表于 2023-5-28 17:12:19 | 显示全部楼层
INFO (LBRCXU-111): Warning /opt/eda/cadence/IC618/tools/dfII/bin/qrcToDfII exit with bad status
INFO (LBRCXU-112): Warning Status 256
INFO (LBRCXU-113): Warning QRC execution terminated
用脚本运行,最后会报错这个
发表于 2023-6-7 18:53:02 | 显示全部楼层
用PEX ,PDK里面有个文档是教程,  在calibre/PEX/    SMIC_CalxEC………… 这个文件
 楼主| 发表于 2023-6-7 23:35:19 | 显示全部楼层
哎,这个PEX文件夹都没有,PDK的docx文档写的也是用QRC。可能是论坛里下载的不全吧,没有办法了,以后用某个工艺做电路前,还是要搭简单电路来试试全不全
发表于 2023-6-8 08:47:32 | 显示全部楼层
calibre里面不是应该有三个文件吗?其中一个是PEX,我们用的是smic40的PDK
 楼主| 发表于 2023-6-8 09:16:03 | 显示全部楼层
对啊,正常的都是有的。我那个没有,也没有rule.r rule.c rule.s文件,工艺库不全吧,没有办法。
发表于 2023-6-8 09:21:01 | 显示全部楼层
应该是不全,换个工艺吧
发表于 2023-7-10 13:31:27 | 显示全部楼层
请问有这三个文件的话怎么用呀,求讲解,我不太会
 楼主| 发表于 2023-7-14 14:36:22 | 显示全部楼层
有这几个文件的话,就是PEX的流程走,网上视频文档教程应该不少
发表于 2023-7-29 15:25:35 | 显示全部楼层
大哥解决了吗?我提出来的av_extracted不知道咋弄,输出选择spectre的话又要报错跟你那个错一样
GMT+8, 2025-9-16 20:11 , Processed in 0.019075 second(s), 4 queries , Gzip On, Redis On.
