查看: 2850|回复: 1
[求助] virtuoso IC616 corner添加model files时软件闪退
发表于 2023-5-23 23:18:53 | 显示全部楼层 |阅读模式
各位大侠,小弟用的是virtuoso IC616-64b,之前用smic180nm工艺跑corner没啥问题,然后准备用tsmc180rf跑corner时,发现每次在add model files时候,点完import from tests再选ok的时候virtuoso都会闪退,然后报错如下,
A panic file has been created for cellview 'test_circuit/test_rail_to_rail_single_OPA/schematic' at:
    (/home/libin/TSMC18rf/test_circuit/test_rail_to_rail_single_OPA/schematic/sch.oa-)
To open the cellview with the recovered data:
    cellview = dbOpenPanicCellView("test_circuit" "test_rail_to_rail_single_OPA" "schematic")
Panic files have been created for cellviews that were opened in edit mode.
For details on these panic files, see
    '/home/libin/panic.log.linuxhost.3679'
/tools/EDA/ic616090/tools/bin/32bit/cdsCrashReport: error while loading shared libraries: libelf.so.1: wrong ELF class: ELFCLASS64
请教各位大侠这个问题怎么解决?
发表于 2024-9-16 12:58:47 | 显示全部楼层
您好,问题解决了吗,遇到了相同的问题,可以请教一下吗
GMT+8, 2025-12-25 02:44 , Processed in 0.013040 second(s), 4 queries , Gzip On, Redis On.
