查看: 2759|回复: 3
[求助] cadence 报错
发表于 2023-5-23 20:56:19 | 显示全部楼层 |阅读模式
想问下画出电路图后,前仿真 点击Netlist and Run 后就出现报错,这个怎么解决
ERROR (OSSHNL-116): Unable to descend into any of the views defined in the view list, 'hspiceD spice cmos_sch cmos.sch schematic', for the
instance 'N4' in cell 'IVcurves'. Either add one of these views to the library 'NCSU_Analog_Parts',
cell 'nmos4' or modify the view list to contain an existing view.
End netlisting May 23 05:42:29 2023
ERROR (OSSHNL-514): Netlisting failed due to errors reported before. Netlist may be corrupt or may not be produced at all. Fix reported errors and netlist again.
      ...unsuccessful.
发表于 2023-5-24 12:04:17 | 显示全部楼层
library user read/access permission?
发表于 2024-1-29 13:52:54 | 显示全部楼层
重启一下试试
发表于 2024-10-30 15:13:40 | 显示全部楼层
同问,最终是怎么解决的
GMT+8, 2025-10-6 09:01 , Processed in 0.031257 second(s), 4 queries , Gzip On, Redis On.
