查看: 5495|回复: 14
[求助] 关于shield线,floating怎么能够全部找出来?
发表于 2023-5-4 13:57:38 | 显示全部楼层 |阅读模式
shield 没有接在vss上面,floating在哪里,怎么能够更快速找出来。
或者大家在做vss shield的时候就直接先打孔,以免后续没接,经验丰富的layout手法是怎样做的呢?
发表于 2023-5-4 17:36:41 | 显示全部楼层
ERC里有。。floating net
发表于 2023-5-4 17:44:22 | 显示全部楼层
ERC Pathchk !LABELED NOFLOAT
Specification statement
ERC PATHCHK
{labeled_flag | power_ground_flag [operand power_ground_flag]}
[POLYGONS NETS | POLYGONS | NETS]
[BY LAYER] [BY CELL | FLAT]
[PORTS ALSO] [NOFLOAT] [EXCLUDE UNUSED]
[EXCLUDE SUPPLY]
Used during circuit extraction in Calibre nmLVS/nmLVS-H and ICtrace Mask mode.
A required string that specifies how the tool reports a net that does or does not have a path to
a labeled net. This option uses top-level text objects that are neither power nor ground net
labels. Possible choices are:
LABELED — Reports nets with a path to a labeled (texted) net.
! LABELED — Reports nets with no path to any labeled (texted) net.
where the exclamation mark (!) is synonymous with Boolean NOT
NOFLOAT
An optional keyword that instructs the statement to ignore floating nets. Floating nets are
nets that are not connected to any devices.
回复 支持 2 反对 0
发表于 2023-5-5 09:57:12 | 显示全部楼层
ERC Pathchk !LABELED BY LAYER
把这行加到lvs.com
 楼主| 发表于 2023-5-5 13:12:49 | 显示全部楼层
把这行加到lvs.com
lvs.com是在哪里啊?
 楼主| 发表于 2023-5-5 13:15:57 | 显示全部楼层
是在这里吗?
怎么设置
 楼主| 发表于 2023-5-5 13:21:24 | 显示全部楼层
没懂,是在这么怎么设置吗?
 楼主| 发表于 2023-5-5 13:39:45 | 显示全部楼层
825555056 发表于 2023-5-4 17:36
ERC里有。。floating net
我这里ERC就只有 ERC Results    ERC summary
发表于 2023-5-5 13:49:15 | 显示全部楼层
漫天游侠 发表于 2023-5-5 13:12
lvs.com是在哪里啊?
include进去
发表于 2023-5-5 14:17:01 | 显示全部楼层
这个适用calibre 跑lvs的。
1)4#的加到lvs文件里。
2)查看lvs结果就可以看到会把m1 m2 m3...所有的金属悬空列出。
GMT+8, 2025-12-20 17:44 , Processed in 0.027380 second(s), 3 queries , Gzip On, Redis On.
