发表于 2011-8-6 04:13:40
显示全部楼层
Digital Signal Processing: A Computer-Based Approach has a good amount of Matlab examples, they will not help you prepare for any practical DSP exams. I recently bought this book as a required textbook for a graduate course on DSP and I found myself having to use my undergraduate book on DSP (Proakis) for learning the material and preparing for my exams. This book's weakness lies in the fact that the examples are not worked out in detail, but rather they are shown through the use of matlab functions and commands which will in no way prepare you for working out a problem's answers using the tried and true paper, pencil, and calculator approach. I found myself frustrated several times during my homework assignments because there were not enough examples worked out showing the nitty gritty details of the solution. Instead, the solutions were in matlab which only helps if the problem being solved is asking for a matlab solution. The only plus side of this book is that it does use matlab to teach some DSP concepts just as the title says but I agree with the other reviewers that this book is nothing special. I found Proakis and Manolakis to be a far better book with worked out problems and only used this Mitra book for matlab problems on DSP |
