查看: 4809|回复: 17
VMANAGER Failed to acquire bundle PROJECT_SERVER features
发表于 2023-4-26 17:44:31 | 显示全部楼层 |阅读模式
啟動VMANAGER 22.01.003 時遇license call failed 問題,就教先輩。
2023-04-25 23:33:08,981 com.cadence.mdv.license.backend.LicenseBackendServiceImpl [ctx-loader-daemon-vmgr] ERROR - The server capabilities exceeds the licenses available - Failed to acquire bundle PROJECT_SERVER features sequence is: [VMG100-[vmanager_project:22.0], VMG200-[vmanager_integration:22.0]], last message was Failed - (LMF-03513): License call failed for feature vmanager_integration, version 22.0 and quantity 1. The license server search path is defined as /opt/local/lic/cadence.dat&&/opt/local/lic/synopsys.dat&/opt/local/lic/cadence.dat. The FLEXnet error message is as follows,
FLEXnet ERROR(-513, 7006, 0): Error List Returned (-513,7006) ; Authentication Failed (-8,3046) ; Authentication Failed (-8,3046)
Run 'lic_error LMF-03513' for more information.
cadence.dat license 的激活部分資料如下:
23:24:55 (cdslmd) Voltus_Power_Integrity_AA Voltus_Power_Integrity_AA_GXL Voltus_Power_Integrity_Fi_L
23:24:55 (cdslmd) Voltus_Power_Integrity_Fi_XL Voltus_Power_Integrity_L Voltus_Power_Integrity_MP
23:24:55 (cdslmd) Voltus_Power_Integrity_XL vmanager_project vmanager_integration
23:24:55 (cdslmd) vmanager         vmanager_client vmanager_ucis
23:24:55 (cdslmd) vmanager_web         Vmanager_High_Availability vmanager_safety_client
23:24:55 (cdslmd) vm_app_multiproject vm_app_multisite VM_integ_opt
23:24:55 (cdslmd) Integrated_Metrics_Center Integrated_Metric_Center jasper_fpv
$ vmanager -version
Picked up JAVA_TOOL_OPTIONS: -Xss8m
Cadence vManager: 22.03-s003: (c) Copyright 1995-2022 Cadence Design Systems Inc build:2022-08-23 14:52:26
系統是 centos 7
$ uname -a
Linux lnx60 3.10.0-1160.88.1.el7.x86_64 #1 SMP Tue Mar 7 15:41:52 UTC 2023 x86_64 x86_64 x86_64 GNU/Linux
发表于 2024-7-16 22:17:03 | 显示全部楼层
一样的问题, 楼主有解决方法吗?
 楼主| 发表于 2024-7-16 22:58:06 | 显示全部楼层
解決了。
先讓C家 license 啟動,一般軟體如 xcelium 可正常運作。
找出 vmanager 中 LmApi-xxx.jar 或 framwework-licsrv-***.jar 兩個檔案。現印象中找到 LmApi-xxx.jar
find <vmanager-path> -name LmApi-*
找到後,削掉或改名保留。再將附件中檔案改與原檔案同名並取代。
這樣就好了。
java.zip
1.93 MB, 下载次数: 122 , 下载积分: 资产 -2 信元, 下载支出 2 信元
回复 支持 2 反对 0
发表于 2024-7-16 23:50:04 | 显示全部楼层
thanks
发表于 2024-7-19 17:08:17 | 显示全部楼层
tom0626 发表于 2024-7-16 22:58
解決了。
找出 vmanager 中 LmApi-xxx.jar 或 fra ...
Thanks!
发表于 2024-8-1 14:40:24 | 显示全部楼层
解決了。
非常感谢,解决了我悬而未决的问题呀
发表于 2024-12-9 12:23:57 | 显示全部楼层
thanks
发表于 2024-12-12 04:24:57 | 显示全部楼层
Thanks
发表于 2024-12-12 08:09:09 | 显示全部楼层
非常感谢
发表于 2024-12-15 10:52:16 | 显示全部楼层
解決了。
Thanks for sharing
GMT+8, 2025-10-6 07:31 , Processed in 0.017543 second(s), 4 queries , Gzip On, Redis On.
