查看: 5058|回复: 10
[原创] StarVision PRO, SpiceVision & GateVision 2022.3 Full Lic (Win&Linux)
发表于 2023-3-4 18:40:42 | 显示全部楼层 |阅读模式
StarVision PRO, SpiceVision PRO, GateVision PRO 2022.3 (2023 Version - Windows and Linux) Full License
StarVision PRO
SoC, Multi-mode Debug for Transistor, RTL, and System-Level Designs
Modern semiconductor debug represents more than a quarter of the entire development process, and requires the most intensive engineering effort. As System-on-Chip (SoC) devices become larger and more diverse, containing analog components, third party IP and multi-core processors , debug tools must adapt to these new requirements.
StarVision® PRO   represents the state-of-the-art in debug solutions for advanced electronic SoCs. The incorporation of Concept's leading visualization and detection technology enables rapid cause-effect analysis for efficient functional analysis. combines SPICE and transient or analysis from our market leading SpiceVision PRO tool with digital RTL and gates from our advanced RTLvision PRO tool. It is fully customizable and incorporates many advanced features not available in other debug solutions, to handle the most complexes of SoC plate
  • Powerful general-purpose debugger for rapid cause-effect resolution
  • Effective mixed-mode, RTL, Gate, SPICE and post-layout level debug
  • Customizable tool platform with specialized SoC & IP capabilities
Advanced, General-Purpose Debug
IP-Based SoC Debug   – Working with third party IP requires the comprehension of unfamiliar code. Concept's visualization technology allows unfamiliar sections of the SoC to be easily understood, enabling fast IP integration and problem resolution. Due to the many by different Vision data formats Star support PRO engineers can explore, analyze and debug almost any SoC and IP building block within a single, easy-to-use debug cockpit.
Path Extraction & Logic Cone Window   – The customizable path extraction engine can automatically identify and extract critical paths in a design, allowing for bugs to be easily tracked from observation point to actual cause. A configurable logic cone window can also be displayed to rain pidly ex logic 。 These two features provide fast cause-effect observation, the heart of accelerated debug.
Easy Design Exploration   – Leveraging Concept's leading visualization technology, the interactive design navigation window shows schematic fragments of just the critical portion of the design linked to the original source code (RTL, Netlist, SPICE) and to simulation results.
Abstract SoC View   – Today's SoCs, containing a myriad of IP blocks and complex interconnect, have reached complexities that make it very hard for engineers to understand component structure and interaction. StarVision PRO automatically generates displays of complex lock design al overformation sections all fcshow and structure . This provides a quick overview of the SoC under investigation, which may be instantly flipped to reveal abstract or detailed information.
Analog, Mixed-Mode and Transistor-Level Debug
Integration of RTL, Gate, SPICE Debug and Visualization   – In SoC design, engineers need to work at different abstraction levels, for example, RTL, gate, transistor, analog, and parasitic. StarVision PRO provides full analog debug and analysis, mixed with digital debug that leverages waveform, schematic and other displays. StarVision PRO enables engineers to find connection points where analog and digital circuits meet and can check to ensure a clean "transition."
Automatic Logic Recognition   – The built-in automatic logic recognition engine creates digital logic symbols from pure SPICE-level netlists for easy transistor-level design exploration and analysis.
Specialized Functionality and Customization Features
Clock Tree Extraction   – Clock signals are often a source of problems in complex SoC design. StarVision PRO automatically extracts and analyzes clock trees and gives an immediate, configurable view of clock networks and domains. Clock Domain Crossing (CDC) logic may be au tomatically analyzed.
User Specific Customization   – API access is provided to all aspects of StarVision PRO, allowing for extensive customization and specialized features to be easily coded in TCL and executed. Many UserWare examples are provided with StarVision PRO.
UserWare Plugin Mechanism – In order to make it easy for organizations to manage and deploy customized tool features within an organization, StarVision PRO comes with a smart UserWare plugin mechanism that makes it very easy to add and exchange new tool features within development organization teams and exchanges new tool features within development teams and organizations. – In addition to the Tcl UserWare interface, a C API is also provided that allows application specific C code to be bundled into the debugger. This allows end users to add new tool features with full access to the tool database and internal data structures and offers broad data iteration and modification. Examples of applications that have been coded into the tool include linting, netlist pruning, and FPGA partitioning.
C Code Customization   – In addition to the Tcl UserWare interface, a C API is also provided that allows application specific C code to be bundled into the debugger. This allows end users to add new tool features with full access to the tool database and internal data structures and offers broad data iteration and modification. Examples of applications that have been coded into the tool include linting, netlist pruning, and FPGA partitioning.
Waveform Viewer and Signal Tracing   – StarVision PRO comes with a fully integrated digital waveform browser and with support for interactive signal tracing in the source code, schematic view and waveform window. StarVision PRO compiles simulation output into a high-performance database for accelerated waveform brow signal tracing.
At a Glance
[td]
Features
Benefits
Ultra fast HDL reader and graphics on the fly
Graphical representations make it easier to understand, debug, change and optimize SystemVerilog, VHDL and Verilog code
Schematics from SPICE netlists
Schematics provide easier and faster debugging for complex circuits. Supported dialects include SPICE, HSPICE, Spectre, Caliber, CDL, Eldo and PSPICE.
64-bit database
Higher performance and increased capacity, for very large designs
Powerful GUI
Multiple views, including tree, schematic, waveform and source file plus drag and drop between different views for increased circuit understanding
Cone Window
Incremental schematic navigation for easy design exploration and reduction of complexity
Tcl UserWare API
Allows interfacing with tool flow and definition of electrical rule checks
Circuit fragment save
Circuit netlists can be saved as SPICE, Verilog or SPEF files for future reuse as IP, or for partial simulation
Automatic clock tree and clock domain extraction and visualization
Fast detection and resolution of clock domain problems
Full support for mixed language and mixed-signal designs
Designers can easily develop and debug today's most complex heterogeneous SoCs and IPs (SystemVerilog, Verilog, VHDL, SPICE, HSPICE, ...)
Parasitic analysis featuresAllows visualization, analysis and pruning of parasitic networks (DSPF, RSPF, SPEF) and provides capabilities to export SPICE netlists for critical circuit fragment simulation.
If you are interested in the full licensed software StarVision PRO, SpiceVision PRO, and GateVision PRO 2022.3 with full feature license, then do well to contact     fast.forever24@gmail.com
发表于 2023-5-1 10:14:59 | 显示全部楼层
Hi, Tnx.. for sharing information.
I need this for my learning purpose.Please do share more information @ ecphds@gmail.com
发表于 2023-7-1 13:02:06 | 显示全部楼层
very good tool
发表于 2023-8-9 11:08:38 | 显示全部楼层
非常好的工具
发表于 2023-10-9 22:56:22 | 显示全部楼层
Do you have virtuoso add-on ?
发表于 2023-12-12 17:31:57 | 显示全部楼层
thanks
发表于 2023-12-14 17:24:08 | 显示全部楼层
Thank you for sharing. I am looking for this software to generate circuit diagrams from SPICE netlists for learning purposes. How can I obtain the download link? Please let me know.
发表于 2024-1-18 23:18:24 | 显示全部楼层
Wow I need this.
发表于 2024-1-21 11:43:41 | 显示全部楼层
StarVision, RTLvision, GateVision, SpiceVision 2023.1 is released,who can share installer?
发表于 2024-2-18 15:36:07 | 显示全部楼层
  I need this.
GMT+8, 2025-9-13 07:30 , Processed in 0.034660 second(s), 3 queries , Gzip On, Redis On.
