查看: 2320|回复: 2
VCS2018使用时发生的一些问题
发表于 2023-2-27 22:24:28 | 显示全部楼层 |阅读模式
我的虚拟机安装好了gcc, g++等必要组件,但是在vcs -full64 ***.v命令执行中会报出make  g++-4.8: Command not found ,请问各位大神是什么问题
*** Using c compiler gcc-4.8 instead of cc ...
                         Chronologic VCS (TM)
       Version O-2018.09-SP2_Full64 -- Mon Feb 27 22:22:30 2023
               Copyright (c) 1991-2018 by Synopsys Inc.
                         ALL RIGHTS RESERVED
This program is proprietary and confidential information of Synopsys Inc.
and may be used and disclosed only as authorized in a license agreement
controlling such use and disclosure.
Parsing design file 'top.v'
Parsing design file 'add4.v'
Top Level Modules:
       top
No TimeScale specified
Starting vcs inline pass...
1 module and 0 UDP read.
        However, due to incremental compilation, no re-compilation is necessary.
rm -f _csrc*.so pre_vcsobj_*.so share_vcsobj_*.so
ld -shared  -Bsymbolic  -o .//../simv.daidir//_csrc0.so objs/amcQw_d.o
rm -f _csrc0.so
if [ -x ../simv ]; then chmod -x ../simv; fi
g++-4.8  -o ../simv    -Wl,-rpath-link=./ -Wl,-rpath='$ORIGIN'/simv.daidir/ -Wl,-rpath=./simv.daidir/ -Wl,-rpath='$ORIGIN'/simv.daidir//scsim.db.dir  -Wl,--no-as-needed -rdynamic  -Wl,-rpath=/opt/eda/Synopsys/vcs/O-2018.09-SP2/linux64/lib -L/opt/eda/Synopsys/vcs/O-2018.09-SP2/linux64/lib     _31292_archive_1.so _prev_archive_1.so _csrc0.so  SIM_l.o  _csrc0.so     rmapats_mop.o rmapats.o rmar.o rmar_nd.o  rmar_llvm_0_1.o rmar_llvm_0_0.o          -lzerosoft_rt_stubs -lvirsim -lerrorinf -lsnpsmalloc -lvfs    -lvcsnew -lsimprofile -luclinative /opt/eda/Synopsys/vcs/O-2018.09-SP2/linux64/lib/vcs_tls.o   -Wl,-whole-archive -lvcsucli -Wl,-no-whole-archive          /opt/eda/Synopsys/vcs/O-2018.09-SP2/linux64/lib/vcs_save_restore_new.o -ldl  -lc -lm -lpthread -ldl
make: g++-4.8: Command not found
make: *** [product_timestamp] Error 127
Make exited with status 2
CPU time: .354 seconds to compile + .297 seconds to elab + .235 seconds to link
 楼主| 发表于 2023-2-27 22:26:16 | 显示全部楼层
系统是Redhat7换的CentOS7的源,S家版本是2018
发表于 2024-10-5 13:44:43 | 显示全部楼层
安装g++后,软链接一个g++-4.8文件
GMT+8, 2025-12-28 03:01 , Processed in 0.017478 second(s), 5 queries , Gzip On, Redis On.
