查看: 2423|回复: 6
[求助] 晶振的phase noise,是由oscillator决定的吗?
发表于 2023-2-23 21:29:28 | 显示全部楼层 |阅读模式
因为我看到无源晶体的datasheet上,都没有phase noise这一项。
https://www5.epsondevice.com/en/products/crystal_unit/
发表于 2023-2-24 10:07:44 | 显示全部楼层
mark,我也想知道。说下我的看法,oscillator的电路元件肯定会恶化phase noise,但是晶体是否决定了oscillator输出时钟的相位噪声的上限呢?
发表于 2023-2-24 14:03:19 | 显示全部楼层
check others, most have the jitter spec.
in the link you attached, it only specifies ppm, i.e. freq stability, so it might be application dependent.
 楼主| 发表于 2023-2-24 14:46:42 | 显示全部楼层
in the link you attached, it only specifies ppm, i.e. freq  ...
many thanks, please show some others which have the jitter spec.
发表于 2023-2-25 09:42:45 | 显示全部楼层
发表于 2023-2-25 09:43:41 | 显示全部楼层
发表于 2024-12-4 12:02:45 | 显示全部楼层
有答案了吗?我看网上说近端取决于晶体Q值,是Q值的四次方,远端取决于电路。
GMT+8, 2025-10-6 21:29 , Processed in 0.015210 second(s), 3 queries , Gzip On, Redis On.
