查看: 8934|回复: 37
[资料] Lecture Notes in Analog Electronics
发表于 2023-2-9 20:21:47 | 显示全部楼层 |阅读模式
Lecture Notes in Analog Electronics: Discrete and Integrated Large Signal Amplifiers (true PDF)
English  2 March 2023
ISBN-10: 9811965277
This book discusses larger signal amplifiers (denoted as PA). Large signal amplifiers are dealing with signals whose magnitude is such that the operation of the active element can no longer be considered linear. They are usually designed to get as much power gain and efficiency as possible. That is why they are often called power amplifiers. In this book, two implementations of PA are considered. First, it is of interest to obtain large signals (current or voltage) at the output of a cascade of direct coupled amplifiers. In this case, linearity, frequency response, and speed are the most important requirements. Second are real power amplifiers where the power delivered to the load is of primary interest. Of course, efficiency, linearity, and high frequency response are of interest, too. A very special attention is paid to modern power electronic components such as Power BJT, VDMOS, IGBT, SiC MOS, and GaN HEMT. DC and switching properties of all these devices are studied in much detail. This book also includes a set of appendices which cover: solved problems, SPICE simulation results for selected set of circuits, and a short review of microelectronic technology process
Lecture Notes in Analog Electronics.rar
7.72 MB, 下载次数: 233 , 下载积分: 资产 -3 信元, 下载支出 3 信元
发表于 2023-2-9 21:33:37 | 显示全部楼层
kANSKANSA
发表于 2023-2-9 23:08:46 | 显示全部楼层
谢谢分享
发表于 2023-2-10 00:15:15 | 显示全部楼层
thanks
发表于 2023-2-10 08:56:21 | 显示全部楼层
模拟电子学课堂讲稿
发表于 2023-2-10 09:16:34 | 显示全部楼层
謝謝分享
发表于 2023-2-10 10:28:04 | 显示全部楼层
tks a lot
发表于 2023-2-10 13:55:34 | 显示全部楼层
thank you!
发表于 2023-2-10 16:43:21 | 显示全部楼层
多谢分享
发表于 2023-2-10 17:37:05 | 显示全部楼层
下来看看,谢谢!
GMT+8, 2025-12-15 04:06 , Processed in 0.019070 second(s), 4 queries , Gzip On, Redis On.
