查看: 7946|回复: 0
[原创] ETAP PowerStation 22.0.1 x64 Full Feature License
发表于 2023-1-6 07:15:34 | 显示全部楼层 |阅读模式
ETAP 22 is an analytical engineering solution company specializing in the simulation, design, monitoring, control, operator training, optimizing, and automating power systems. ETAP's integrated digital twin platform offers the best comprehensive suite of enterprise solutions.
ETAP 22.0.1 is the only verified & validated high-impact software in its class, meeting the stringent quality & safety requirements established by global standards' bodies, and is ready for use in mission critical installations including nuclear facilities, hospitals, data more.
ETAP 22 Series offers an impressive new set of integrated power analysis modules, electrical dimensioning capabilities, automation, and operations solutions.
From advanced renewable energy modeling, safety compliance, simulation tools, leading-edge model-driven real-time network management solutions, ETAP 22 addresses your requirements and industry needs.
ETAP 22 provides a package of comprehensive electronic engineering software solutions that include load current, short circuit, transient impedance, amplifier matching, cable power, optimal power flow, etc. Its modular throughput can be customized to cover the needs of any company, from small to large power systems.
ETAP real-time capability is an integrated package of electronic software programs that provide intelligent power monitoring, energy management, system optimization, advanced automation and real-time forecasting.
The ETAP smart mesh network provides enterprise applications with the possibility of using tools for planning, coordination and secure implementation of the network.
This real-time system has the ability to manage, control, virtualize, optimize and automate power transmission and distribution networks.
ETAP is the most conceptual business solution for design, simulation, implementation, control, optimization and automation of production, transmission, distribution and industrial power systems.
ETAP is written under a quality assurance program and is used globally as a high-level impact software. ETAP is designed with seven languages ​​that can translate the report output into eight languages.
As an integrated and complete business solution, ETAP is extended to a real-time power management system to monitor, control, automate, simulate and optimize the operation of power systems.
The ETAP base package is a set of core tools, additional analysis modules, and engineering libraries that allow you to create, configure, customize, and manage your system model. The core tools allow you to Quickly and easily create one-line diagrams of single-phase and three-phase AC and DC networks with an unlimited number of elements and busbars, including small tools and basic components. Engineering libraries provide verified and complete databases of published data on manufactured equipment.
Features and features of ETAP software:
  • - Built-in analysis modules
  • -Cable concepts
  • -Transmission line concepts
  • – Ampacity of the cable
  • - Cable measurement
  • - Cable management
  • - Reducing risk and improving safety
  • - Simplicity and speed in evaluating results and making decisions
  • - Multilingual editions
  • - Faster than similar real-time solutions
  • - Power management system
  • - Energy management system
  • - Production management system
  • - Distribution management system
  • - Intelligent load release
  • - Smart network and micro-grid solutions
AC Arc Flash Reduce Risk, Improve Safety & Enforce Compliance based on Australian Std.
Compliance with guidelines for the selection, use and maintenance of PPE for electrical arc hazards
  • Calculation based on Australian Std. Energy Networks Association's   ENA NENS 09-2014 (Sweeting Method)
  • Maximum and Minimum Arc Current Incident Energy Results
  • User-Definable Arc Current Determination Factors
  • 3-Phase/1-Phase, Electrode material, and Distance Exponent Factors
  • PPE Breakthrough ATPV Multiplier factor
  • Batch calculation for 1000's of locations
  • Edit, customize, and Print Labels from the Calculator
  • Arc-Flash Boundary and Shock Risk Assessment Plots
  • IE vs. Arc Duration and Working Distance Plots
  • Enclosed and Open-Air Typical Input Data (per IEEE 1584)
  • Arc-Flash Label Templates for ENA NENS 09
If you are interested in the full licensed software ETAP PowerStation 22 x64 with full feature license and tutorial examples, then do well to contact    fast.forever24@gmail.com
PLEASE NOTE
Also, if you are interested in other EDA software like: EMPIRE XPU 8.1.3 , Remcom XFDTD 7.10.1, Remcom XGTD 3.1.2, Remcom Wireless Insite 3.3.5, Remcom WaveFarer Radar Software 2.1, Sonnet Suite Pro 18.56 and ASN Filter Designer 5.2.1, Tetcos Netsim Professional 13.1, DigacSilent 2022, VPI Photonic TransmissionMaker 11.1, Optenni Lab 5.0, EMTP-RV 4.2.1, SpiceVision 7.0 and StarVision etc. please contact   fast.forever24@gmail.com
GMT+8, 2025-10-16 00:49 , Processed in 0.017283 second(s), 4 queries , Gzip On, Redis On.
