查看: 2353|回复: 5
求Candence IC6.18帮助文件
发表于 2022-12-24 09:04:11 | 显示全部楼层 |阅读模式
最近在学习virtuoso,请问有没有哪位朋友可以把IC618安装目录下DOC里的所有文件打包发我一下或者传至百度网盘,谢谢了!
发表于 2022-12-24 10:18:32 | 显示全部楼层
 楼主| 发表于 2022-12-24 14:08:39 | 显示全部楼层
shindziharan 发表于 2022-12-24 10:18
check this https://pan.baidu.com/s/1RxHNj1XEsvwQvc6zJpE8aw?pwd=5b5x
感谢!
 楼主| 发表于 2022-12-24 14:22:02 | 显示全部楼层
包括html文件等的整个doc目录下的全部文件(约4.5G)可以麻烦再次打包发一下百度云盘吗,感谢了!
发表于 2022-12-24 15:15:07 | 显示全部楼层
The archive that I posted above is provided directly by the vendor. I additionally did not check any documents there.
Since my upload speed is extremely slow (~400KB/s) there are more important things that need to be uploaded.
You can make everything much easier, install and configure this tool once https://bbs.eetop.cn/thread-941354-1-1.html , all the necessary documents will be at your fingertips (provided that the software for which the documents are needed is installed).
 楼主| 发表于 2022-12-24 15:59:01 | 显示全部楼层
shindziharan 发表于 2022-12-24 15:15
The archive that I posted above is provided directly by the vendor. I additionally did not check any ...
Thanks!
GMT+8, 2025-12-17 04:36 , Processed in 0.022547 second(s), 4 queries , Gzip On, Redis On.
