查看: 2364|回复: 2
安装virtuoso后,启动出现了如下提示,该怎么办
发表于 2022-12-13 20:28:43 | 显示全部楼层 |阅读模式
安装virtuoso后,启动出现了如下提示,该怎么办?
"[ic@ic ~]$ virtuoso
virtuoso:   ERROR: The OA2.2 library directory (/opt/eda/Cadence/ICADVM201/oa_v22.60.082/lib/linux_rhel50_gcc44x_64/opt) does not seem to exist.
virtuoso:    INFO: You have OA_UNSUPPORTED_PLAT set to "linux_rhel50_gcc44x" in your environment:
virtuoso:          check that the value provided correspond to a valid OA platform.
virtuoso:          If this value is correct, check your OA installation.
virtuoso:    INFO: Note that OpenAccess (OA) requires running the Configure phase.
virtuoso:          See the "OpenAccess Installation and Configuration Guide" before
virtuoso:          you complete the configuration step. This manual is included with
virtuoso:          the Cadence product documentation.
[ic@ic ~]$
发表于 2022-12-13 22:21:01 | 显示全部楼层
设置这 linux_rhel50_gcc44x
发表于 2022-12-14 20:57:17 | 显示全部楼层
setenv OA_UNSUPPORTED_PLAT         linux_rhel60
GMT+8, 2025-12-30 20:47 , Processed in 0.014143 second(s), 3 queries , Gzip On, Redis On.
