查看: 2097|回复: 4
[求助] 请问dvt-eclipse 21.1.41出现gtk不兼容,闪屏,怎么解决?
发表于 2022-12-10 17:57:07 | 显示全部楼层 |阅读模式
[WARNING] Unable to find a working GTK and browser engine combination, using 'gtk3-webkit' (error F02__display_failed)
[WARNING] It means that this DVT distro flavor is not compatible with your OS, and crashes are likely to occur.
[WARNING] Possible fixes:
[WARNING]  - Install/Update WebKitGTK library in your OS
[WARNING]  - Download a DVT distro based on a different Eclipse version, currently you are using one based on Eclipse 4.19.0
发表于 2023-5-5 14:37:31 | 显示全部楼层
楼主,这个解决了吗?
 楼主| 发表于 2023-5-5 15:07:46 | 显示全部楼层
kjq999 发表于 2023-5-5 14:37
楼主,这个解决了吗?
这个warning更新gtk版本就可以解决,如果界面闪屏,环境变量加export GTK_IM_MODULE=gtk-im-context-simple可以解决
发表于 2023-5-6 14:20:37 | 显示全部楼层
多谢楼主解答
发表于 2023-9-6 20:19:03 | 显示全部楼层
see see
GMT+8, 2025-11-3 01:04 , Processed in 0.013165 second(s), 3 queries , Gzip On, Redis On.
