查看: 10885|回复: 16
[资料] The Art of Writing Efficient Programs @2021
发表于 2022-11-20 10:38:25 | 显示全部楼层 |阅读模式
Book description
Become a better programmer with performance improvement techniques such as concurrency, lock-free programming, atomic operations, parallelism, and memory management
Key Features
  • Learn proven techniques from a heavyweight and recognized expert in C++ and high-performance computing
  • Understand the limitations of modern CPUs and their performance impact
  • Find out how you can avoid writing inefficient code and get the best optimizations from the compiler
  • Learn the tradeoffs and costs of writing high-performance programs
The Art of Efficient Programming covers all the major aspects of writing efficient programs, such as using CPU resources and memory efficiently, avoiding unnecessary computations, measuring performance, and how to put concurrency and multithreading to good use. You'll also learn about compiler optimizations and how to use the programming language (C++) more efficiently. Finally, you'll understand how design decisions impact performance.
By the end of this book, you'll not only have enough knowledge of processors and compilers to write efficient programs, but you'll also be able to understand which techniques to use and what to measure while improving performance. At its core, this book is about learning how to learn.
Who this book is for
This book is for experienced developers and programmers who work on performance-critical projects and want to learn new techniques to improve the performance of their code. Programmers in algorithmic trading, gaming, bioinformatics, computational genomics, or computational fluid dynamics communities will get the most out of the examples in this book, but the techniques are fairly universal. Although this book uses the C++ language, the concepts demonstrated in the book can be easily transferred or applied to other compiled languages such as C, Java, Rust, Go, and more.
The Art of Writing Efficient Programs (Fedor G. Pikus).pdf
6.6 MB, 下载次数: 138 , 下载积分: 资产 -3 信元, 下载支出 3 信元
发表于 2022-11-20 10:56:28 | 显示全部楼层
谢谢分享
发表于 2022-11-20 11:09:13 | 显示全部楼层
谢谢分享
发表于 2022-11-20 12:26:31 | 显示全部楼层
发表于 2022-11-20 12:53:26 | 显示全部楼层
THanks
发表于 2022-11-20 15:10:20 | 显示全部楼层
楼主辛苦了
发表于 2022-11-20 16:40:14 | 显示全部楼层
谢谢分享
发表于 2022-11-20 16:43:16 | 显示全部楼层
谢谢分享!!
发表于 2022-11-20 21:05:32 | 显示全部楼层
Thank you for sharing the book.
发表于 2022-11-20 22:34:55 | 显示全部楼层
kanaknaa
GMT+8, 2025-9-13 06:59 , Processed in 0.023610 second(s), 4 queries , Gzip On, Redis On.
