查看: 12113|回复: 35
[资料] Linux Device Driver Development - Second Edition @2022
发表于 2022-11-17 21:41:15 | 显示全部楼层 |阅读模式
    You'll learn how to configure, tailor, and build the Linux kernel. Filled with real-world examples, the book covers each of the most-used subsystems in the embedded domains such as GPIO, direct memory access, interrupt management, and I2C/SPI device drivers. This book will show you how Linux abstracts each device from a hardware point of view and how a device is bound to its driver(s). You'll also see how interrupts are propagated in the system as the book covers the interrupt processing mechanisms in-depth and describes every kernel structure and API involved. This new edition also addresses how not to write device drivers using user space libraries for GPIO clients, I2C, and SPI drivers.
    By the end of this Linux book, you'll be able to write device drivers for most of the embedded devices out there.
What you will learn
  • Download, configure, build, and tailor the Linux kernel
  • Describe the hardware using a device tree
  • Write feature-rich platform drivers and leverage I2C and SPI buses
  • Get the most out of the new concurrency managed workqueue infrastructure
  • Understand the Linux kernel timekeeping mechanism and use time-related APIs
  • Use the regmap framework to factor the code and make it generic
  • Offload CPU for memory copies using DMA
  • Interact with the real world using GPIO, IIO, and input subsystems
Who this book is for
This Linux OS book is for embedded system and embedded Linux enthusiasts/developers who want to get started with Linux kernel development and leverage its subsystems. Electronic hackers and hobbyists interested in Linux kernel development as well as anyone looking to interact with the platform using GPIO, IIO, and input subsystems will also find this book useful.
Linux Device Driver Development 2nd Edition (John Madieu).pdf
5.43 MB, 下载次数: 192 , 下载积分: 资产 -3 信元, 下载支出 3 信元
发表于 2022-11-17 22:04:32 | 显示全部楼层
谢谢分享
发表于 2022-11-17 22:19:35 | 显示全部楼层
Thanks
发表于 2022-11-17 22:21:35 | 显示全部楼层
感谢分享
发表于 2022-11-17 23:04:26 | 显示全部楼层
thanks
发表于 2022-11-18 05:28:21 | 显示全部楼层
楼主辛苦了
发表于 2022-11-18 07:12:41 | 显示全部楼层
Thanks
发表于 2022-11-18 08:06:54 | 显示全部楼层
不错,看看
发表于 2022-11-18 08:48:03 | 显示全部楼层
赞楼主一个
发表于 2022-12-4 20:53:41 | 显示全部楼层
谢谢(你的)信息。期待新内容
GMT+8, 2025-12-24 02:45 , Processed in 0.028617 second(s), 4 queries , Gzip On, Redis On.
