查看: 2758|回复: 5
[求助] 求论文
发表于 2022-8-22 16:57:44 | 显示全部楼层 |阅读模式
悬赏20资产已解决
A Cascaded PLL (LC-PLL + RO-PLL) with a Programmable Double Realignment Achieving 204fs Integrated Jitter (100kHz to 100MHz) and -72dB Reference SpurA 55.9-fs Integrated Jitter (100 kHz–100 MHz) Hybrid LC-Tank PLL in 5-nm FinFET Using Programmable Phase Realignment and Dynamic Coarse TuningA 188fsrms-Jitter and −243d8-FoMjitter 5.2GHz-Ring-DCO-Based Fractional-N Digital PLL with a 1/8 DTC-Range-Reduction Technique Using a Quadruple-Timing-Margin Phase SelectorA 12-GHz Reconfigurable Multicore CMOS DCO, With a Time-Variant Analysis of the Impact of Reconfiguration Switches on Phase NoiseA 9GHz 72fs-Total-lntegrated-Jitter Fractional-N Digital PLL with Calibrated Frequency QuadruplerA Fractional-N Synthesizable PLL Using DTC-Based Multistage Injection With Dithering-Assisted Local Skew CalibrationA Sub-100 Fs RMSjitter 20 GHz Fractional-N Analog PLL With a BAW Resonator Based On-Chip 2.5 GHz ReferenceA 40 GHz CMOS PLL With −75-dBc Reference Spur and 121.9-fsrms Jitter Featuring a Quadrature Sampling Phase-Frequency Detector
A 12.9-to-15.1-GHz Digital PLL Based on a Bang-Bang Phase Detector With Adaptively Optimized Noise Shaping
最佳答案
发表于 2022-8-22 16:57:45 | 显示全部楼层
enjoy
A_Sub-100MHz_Reference-Driven_25-to-28GHz_Fractional-N_PLL_with_250dB_FoM.pdf
1017.64 KB, 下载次数: 5 , 下载积分: 资产 -2 信元, 下载支出 2 信元
A_9GHz_72fs-Total-lntegrated-Jitter_Fractional-N_Digital_PLL_with_Calibrated_Fre.pdf
2.76 MB, 下载次数: 5 , 下载积分: 资产 -2 信元, 下载支出 2 信元
A_12.9-to-15.1-GHz_Digital_PLL_Based_on_a_Bang-Bang_Phase_Detector_With_Adaptive.pdf
5.7 MB, 下载次数: 5 , 下载积分: 资产 -3 信元, 下载支出 3 信元
A_40_GHz_CMOS_PLL_With_75-dBc_Reference_Spur_and_121.9-fsrms_Jitter_Featuring_a_.pdf
13.08 MB, 下载次数: 3 , 下载积分: 资产 -5 信元, 下载支出 5 信元
A_Sub-100_Fs_RMSjitter_20_GHz_Fractional-N_Analog_PLL_With_a_BAW_Resonator_Based.pdf
7.15 MB, 下载次数: 4 , 下载积分: 资产 -3 信元, 下载支出 3 信元
A_Fractional-N_Synthesizable_PLL_Using_DTC-Based_Multistage_Injection_With_Dithe.pdf
4.83 MB, 下载次数: 3 , 下载积分: 资产 -3 信元, 下载支出 3 信元
A_12-GHz_Reconfigurable_Multicore_CMOS_DCO_With_a_Time-Variant_Analysis_of_the_I.pdf
2.86 MB, 下载次数: 3 , 下载积分: 资产 -2 信元, 下载支出 2 信元
A_188fsrms-Jitter_and_243d8-FoMjitter_5.2GHz-Ring-DCO-Based_Fractional-N_Digital.pdf
1.45 MB, 下载次数: 3 , 下载积分: 资产 -2 信元, 下载支出 2 信元
A_55.9-fs_Integrated_Jitter_100_kHz100_MHz_Hybrid_LC-Tank_PLL_in_5-nm_FinFET_Usi.pdf
3.92 MB, 下载次数: 4 , 下载积分: 资产 -2 信元, 下载支出 2 信元
A_Cascaded_PLL_LC-PLL__RO-PLL_with_a_Programmable_Double_Realignment_Achieving_2.pdf
1.22 MB, 下载次数: 5 , 下载积分: 资产 -2 信元, 下载支出 2 信元
 楼主| 发表于 2022-8-22 16:59:42 | 显示全部楼层
1.A Cascaded PLL (LC-PLL + RO-PLL) with a Programmable Double Realignment Achieving 204fs Integrated Jitter (100kHz to 100MHz) and -72dB Reference Spur
2.A 55.9-fs Integrated Jitter (100 kHz–100 MHz) Hybrid LC-Tank PLL in 5-nm FinFET Using Programmable Phase Realignment and Dynamic Coarse Tuning
3.A 188fsrms-Jitter and −243d8-FoMjitter 5.2GHz-Ring-DCO-Based Fractional-N Digital PLL with a 1/8 DTC-Range-Reduction Technique Using a Quadruple-Timing-Margin Phase Selector
4.A 12-GHz Reconfigurable Multicore CMOS DCO, With a Time-Variant Analysis of the Impact of Reconfiguration Switches on Phase Noise
5.A 9GHz 72fs-Total-lntegrated-Jitter Fractional-N Digital PLL with Calibrated Frequency Quadrupler
6.A Fractional-N Synthesizable PLL Using DTC-Based Multistage Injection With Dithering-Assisted Local Skew Calibration
7.A Sub-100 Fs RMSjitter 20 GHz Fractional-N Analog PLL With a BAW Resonator Based On-Chip 2.5 GHz Reference
8.A 40 GHz CMOS PLL With −75-dBc Reference Spur and 121.9-fsrms Jitter Featuring a Quadrature Sampling Phase-Frequency Detector
9.A 12.9-to-15.1-GHz Digital PLL Based on a Bang-Bang Phase Detector With Adaptively Optimized Noise Shaping
10.A Sub-100MHz Reference-Driven 25-to-28GHz Fractional-N PLL with −250dB FoM
 楼主| 发表于 2022-8-25 14:54:45 | 显示全部楼层
大神们帮帮忙!
发表于 2022-8-25 16:56:58 | 显示全部楼层
4楼好人
发表于 2022-9-30 15:09:57 | 显示全部楼层
GMT+8, 2025-9-17 06:44 , Processed in 0.022057 second(s), 5 queries , Gzip On, Redis On.
