查看: 3126|回复: 0
[解决] sv 综合
发表于 2022-8-1 00:43:22 | 显示全部楼层 |阅读模式
https://www.wenjiangs.com/doc/vtwxqflw
https://blog.csdn.net/zhuguanlin121/article/details/122998465
https://github.com/whik/crc-lib-c/blob/master/crcLib.c
https://verificationacademy.com/ ... /uvm/docs_1.2/html/
#[color=var(--color-prettylights-syntax-keyword)]include [color=var(--color-prettylights-syntax-string)]"crcLib.h"
[color=var(--color-prettylights-syntax-comment)]/******************************************************************************
[color=var(--color-prettylights-syntax-comment)] * Name:    CRC-4/ITU           x4+x+1
[color=var(--color-prettylights-syntax-comment)] * Poly:    0x03
[color=var(--color-prettylights-syntax-comment)] * Init:    0x00
[color=var(--color-prettylights-syntax-comment)] * Refin:   True
[color=var(--color-prettylights-syntax-comment)] * Refout:  True
[color=var(--color-prettylights-syntax-comment)] * Xorout:  0x00
[color=var(--color-prettylights-syntax-comment)] * Note:
[color=var(--color-prettylights-syntax-comment)] *****************************************************************************/
[color=var(--color-prettylights-syntax-constant)]uint8_t [color=var(--color-prettylights-syntax-entity)]crc4_itu([color=var(--color-prettylights-syntax-constant)]uint8_t *data, [color=var(--color-prettylights-syntax-constant)]uint16_t length)
    [color=var(--color-prettylights-syntax-constant)]uint8_t i;
    [color=var(--color-prettylights-syntax-constant)]uint8_t crc = [color=var(--color-prettylights-syntax-constant)]0;                [color=var(--color-prettylights-syntax-comment)]// Initial value
    [color=var(--color-prettylights-syntax-keyword)]while(length--)
        crc ^= *data++;                 [color=var(--color-prettylights-syntax-comment)]// crc ^= *data; data++;
        [color=var(--color-prettylights-syntax-keyword)]for (i = [color=var(--color-prettylights-syntax-constant)]0; i < [color=var(--color-prettylights-syntax-constant)]8; ++i)
            [color=var(--color-prettylights-syntax-keyword)]if (crc & [color=var(--color-prettylights-syntax-constant)]1)
                crc = (crc >> [color=var(--color-prettylights-syntax-constant)]1) ^ [color=var(--color-prettylights-syntax-constant)]0x0C;[color=var(--color-prettylights-syntax-comment)]// 0x0C = (reverse 0x03)>>(8-4)
            [color=var(--color-prettylights-syntax-keyword)]else
                crc = (crc >> [color=var(--color-prettylights-syntax-constant)]1);
    [color=var(--color-prettylights-syntax-keyword)]return crc;
[color=var(--color-prettylights-syntax-comment)] * Name:    CRC-5/EPC           x5+x3+1
[color=var(--color-prettylights-syntax-comment)] * Poly:    0x09
[color=var(--color-prettylights-syntax-comment)] * Init:    0x09
[color=var(--color-prettylights-syntax-comment)] * Refin:   False
[color=var(--color-prettylights-syntax-comment)] * Refout:  False
[color=var(--color-prettylights-syntax-constant)]uint8_t [color=var(--color-prettylights-syntax-entity)]crc5_epc([color=var(--color-prettylights-syntax-constant)]uint8_t *data, [color=var(--color-prettylights-syntax-constant)]uint16_t length)
    [color=var(--color-prettylights-syntax-constant)]uint8_t crc = [color=var(--color-prettylights-syntax-constant)]0x48;        [color=var(--color-prettylights-syntax-comment)]// Initial value: 0x48 = 0x09<<(8-5)
        [color=var(--color-prettylights-syntax-keyword)]for ( i = [color=var(--color-prettylights-syntax-constant)]0; i < [color=var(--color-prettylights-syntax-constant)]8; i++ )
            [color=var(--color-prettylights-syntax-keyword)]if ( crc & [color=var(--color-prettylights-syntax-constant)]0x80 )
                crc = (crc << [color=var(--color-prettylights-syntax-constant)]1) ^ [color=var(--color-prettylights-syntax-constant)]0x48;        [color=var(--color-prettylights-syntax-comment)]// 0x48 = 0x09<<(8-5)
                crc <<= [color=var(--color-prettylights-syntax-constant)]1;
    [color=var(--color-prettylights-syntax-keyword)]return crc >> [color=var(--color-prettylights-syntax-constant)]3;
[color=var(--color-prettylights-syntax-comment)] * Name:    CRC-5/ITU           x5+x4+x2+1
[color=var(--color-prettylights-syntax-comment)] * Poly:    0x15
[color=var(--color-prettylights-syntax-constant)]uint8_t [color=var(--color-prettylights-syntax-entity)]crc5_itu([color=var(--color-prettylights-syntax-constant)]uint8_t *data, [color=var(--color-prettylights-syntax-constant)]uint16_t length)
                crc = (crc >> [color=var(--color-prettylights-syntax-constant)]1) ^ [color=var(--color-prettylights-syntax-constant)]0x15;[color=var(--color-prettylights-syntax-comment)]// 0x15 = (reverse 0x15)>>(8-5)
[color=var(--color-prettylights-syntax-comment)] * Name:    CRC-5/USB           x5+x2+1
[color=var(--color-prettylights-syntax-comment)] * Poly:    0x05
[color=var(--color-prettylights-syntax-comment)] * Init:    0x1F
[color=var(--color-prettylights-syntax-comment)] * Xorout:  0x1F
[color=var(--color-prettylights-syntax-constant)]uint8_t [color=var(--color-prettylights-syntax-entity)]crc5_usb([color=var(--color-prettylights-syntax-constant)]uint8_t *data, [color=var(--color-prettylights-syntax-constant)]uint16_t length)
    [color=var(--color-prettylights-syntax-constant)]uint8_t crc = [color=var(--color-prettylights-syntax-constant)]0x1F;                [color=var(--color-prettylights-syntax-comment)]// Initial value
                crc = (crc >> [color=var(--color-prettylights-syntax-constant)]1) ^ [color=var(--color-prettylights-syntax-constant)]0x14;[color=var(--color-prettylights-syntax-comment)]// 0x14 = (reverse 0x05)>>(8-5)
    [color=var(--color-prettylights-syntax-keyword)]return crc ^ [color=var(--color-prettylights-syntax-constant)]0x1F;
[color=var(--color-prettylights-syntax-comment)] * Name:    CRC-6/ITU           x6+x+1
[color=var(--color-prettylights-syntax-constant)]uint8_t [color=var(--color-prettylights-syntax-entity)]crc6_itu([color=var(--color-prettylights-syntax-constant)]uint8_t *data, [color=var(--color-prettylights-syntax-constant)]uint16_t length)
                crc = (crc >> [color=var(--color-prettylights-syntax-constant)]1) ^ [color=var(--color-prettylights-syntax-constant)]0x30;[color=var(--color-prettylights-syntax-comment)]// 0x30 = (reverse 0x03)>>(8-6)
[color=var(--color-prettylights-syntax-comment)] * Name:    CRC-7/MMC           x7+x3+1
[color=var(--color-prettylights-syntax-comment)] * Use:     MultiMediaCard,SD,ect.
[color=var(--color-prettylights-syntax-constant)]uint8_t [color=var(--color-prettylights-syntax-entity)]crc7_mmc([color=var(--color-prettylights-syntax-constant)]uint8_t *data, [color=var(--color-prettylights-syntax-constant)]uint16_t length)
                crc = (crc << [color=var(--color-prettylights-syntax-constant)]1) ^ [color=var(--color-prettylights-syntax-constant)]0x12;        [color=var(--color-prettylights-syntax-comment)]// 0x12 = 0x09<<(8-7)
    [color=var(--color-prettylights-syntax-keyword)]return crc >> [color=var(--color-prettylights-syntax-constant)]1;
[color=var(--color-prettylights-syntax-comment)] * Name:    CRC-8               x8+x2+x+1
[color=var(--color-prettylights-syntax-comment)] * Poly:    0x07
[color=var(--color-prettylights-syntax-constant)]uint8_t [color=var(--color-prettylights-syntax-entity)]crc8([color=var(--color-prettylights-syntax-constant)]uint8_t *data, [color=var(--color-prettylights-syntax-constant)]uint16_t length)
                crc = (crc << [color=var(--color-prettylights-syntax-constant)]1) ^ [color=var(--color-prettylights-syntax-constant)]0x07;
[color=var(--color-prettylights-syntax-comment)] * Name:    CRC-8/ITU           x8+x2+x+1
[color=var(--color-prettylights-syntax-comment)] * Xorout:  0x55
[color=var(--color-prettylights-syntax-comment)] * Alias:   CRC-8/ATM
[color=var(--color-prettylights-syntax-constant)]uint8_t [color=var(--color-prettylights-syntax-entity)]crc8_itu([color=var(--color-prettylights-syntax-constant)]uint8_t *data, [color=var(--color-prettylights-syntax-constant)]uint16_t length)
    [color=var(--color-prettylights-syntax-keyword)]return crc ^ [color=var(--color-prettylights-syntax-constant)]0x55;
[color=var(--color-prettylights-syntax-comment)] * Name:    CRC-8/ROHC          x8+x2+x+1
[color=var(--color-prettylights-syntax-comment)] * Init:    0xFF
[color=var(--color-prettylights-syntax-constant)]uint8_t [color=var(--color-prettylights-syntax-entity)]crc8_rohc([color=var(--color-prettylights-syntax-constant)]uint8_t *data, [color=var(--color-prettylights-syntax-constant)]uint16_t length)
    [color=var(--color-prettylights-syntax-constant)]uint8_t crc = [color=var(--color-prettylights-syntax-constant)]0xFF;         [color=var(--color-prettylights-syntax-comment)]// Initial value
                crc = (crc >> [color=var(--color-prettylights-syntax-constant)]1) ^ [color=var(--color-prettylights-syntax-constant)]0xE0;        [color=var(--color-prettylights-syntax-comment)]// 0xE0 = reverse 0x07
[color=var(--color-prettylights-syntax-comment)] * Name:    CRC-8/MAXIM         x8+x5+x4+1
[color=var(--color-prettylights-syntax-comment)] * Poly:    0x31
[color=var(--color-prettylights-syntax-comment)] * Alias:   DOW-CRC,CRC-8/IBUTTON
[color=var(--color-prettylights-syntax-comment)] * Use:     Maxim(Dallas)'s some devices,e.g. DS18B20
[color=var(--color-prettylights-syntax-constant)]uint8_t [color=var(--color-prettylights-syntax-entity)]crc8_maxim([color=var(--color-prettylights-syntax-constant)]uint8_t *data, [color=var(--color-prettylights-syntax-constant)]uint16_t length)
        [color=var(--color-prettylights-syntax-keyword)]for (i = [color=var(--color-prettylights-syntax-constant)]0; i < [color=var(--color-prettylights-syntax-constant)]8; i++)
                crc = (crc >> [color=var(--color-prettylights-syntax-constant)]1) ^ [color=var(--color-prettylights-syntax-constant)]0x8C;        [color=var(--color-prettylights-syntax-comment)]// 0x8C = reverse 0x31
                crc >>= [color=var(--color-prettylights-syntax-constant)]1;
[color=var(--color-prettylights-syntax-comment)] * Name:    CRC-16/IBM          x16+x15+x2+1
[color=var(--color-prettylights-syntax-comment)] * Poly:    0x8005
[color=var(--color-prettylights-syntax-comment)] * Init:    0x0000
[color=var(--color-prettylights-syntax-comment)] * Xorout:  0x0000
[color=var(--color-prettylights-syntax-comment)] * Alias:   CRC-16,CRC-16/ARC,CRC-16/LHA
[color=var(--color-prettylights-syntax-constant)]uint16_t [color=var(--color-prettylights-syntax-entity)]crc16_ibm([color=var(--color-prettylights-syntax-constant)]uint8_t *data, [color=var(--color-prettylights-syntax-constant)]uint16_t length)
    [color=var(--color-prettylights-syntax-constant)]uint16_t crc = [color=var(--color-prettylights-syntax-constant)]0;        [color=var(--color-prettylights-syntax-comment)]// Initial value
                crc = (crc >> [color=var(--color-prettylights-syntax-constant)]1) ^ [color=var(--color-prettylights-syntax-constant)]0xA001;        [color=var(--color-prettylights-syntax-comment)]// 0xA001 = reverse 0x8005
[color=var(--color-prettylights-syntax-comment)] * Name:    CRC-16/MAXIM        x16+x15+x2+1
[color=var(--color-prettylights-syntax-comment)] * Xorout:  0xFFFF
[color=var(--color-prettylights-syntax-constant)]uint16_t [color=var(--color-prettylights-syntax-entity)]crc16_maxim([color=var(--color-prettylights-syntax-constant)]uint8_t *data, [color=var(--color-prettylights-syntax-constant)]uint16_t length)
    [color=var(--color-prettylights-syntax-keyword)]return ~crc;    [color=var(--color-prettylights-syntax-comment)]// crc^0xffff
[color=var(--color-prettylights-syntax-comment)] * Name:    CRC-16/USB          x16+x15+x2+1
[color=var(--color-prettylights-syntax-comment)] * Init:    0xFFFF
[color=var(--color-prettylights-syntax-constant)]uint16_t [color=var(--color-prettylights-syntax-entity)]crc16_usb([color=var(--color-prettylights-syntax-constant)]uint8_t *data, [color=var(--color-prettylights-syntax-constant)]uint16_t length)
    [color=var(--color-prettylights-syntax-constant)]uint16_t crc = [color=var(--color-prettylights-syntax-constant)]0xffff;        [color=var(--color-prettylights-syntax-comment)]// Initial value
[color=var(--color-prettylights-syntax-comment)] * Name:    CRC-16/MODBUS       x16+x15+x2+1
[color=var(--color-prettylights-syntax-constant)]uint16_t [color=var(--color-prettylights-syntax-entity)]crc16_modbus([color=var(--color-prettylights-syntax-constant)]uint8_t *data, [color=var(--color-prettylights-syntax-constant)]uint16_t length)
[color=var(--color-prettylights-syntax-comment)] * Name:    CRC-16/CCITT        x16+x12+x5+1
[color=var(--color-prettylights-syntax-comment)] * Poly:    0x1021
[color=var(--color-prettylights-syntax-comment)] * Alias:   CRC-CCITT,CRC-16/CCITT-TRUE,CRC-16/KERMIT
[color=var(--color-prettylights-syntax-constant)]uint16_t [color=var(--color-prettylights-syntax-entity)]crc16_ccitt([color=var(--color-prettylights-syntax-constant)]uint8_t *data, [color=var(--color-prettylights-syntax-constant)]uint16_t length)
                crc = (crc >> [color=var(--color-prettylights-syntax-constant)]1) ^ [color=var(--color-prettylights-syntax-constant)]0x8408;        [color=var(--color-prettylights-syntax-comment)]// 0x8408 = reverse 0x1021
[color=var(--color-prettylights-syntax-comment)] * Name:    CRC-16/CCITT-FALSE   x16+x12+x5+1
[color=var(--color-prettylights-syntax-constant)]uint16_t [color=var(--color-prettylights-syntax-entity)]crc16_ccitt_false([color=var(--color-prettylights-syntax-constant)]uint8_t *data, [color=var(--color-prettylights-syntax-constant)]uint16_t length)
    [color=var(--color-prettylights-syntax-constant)]uint16_t crc = [color=var(--color-prettylights-syntax-constant)]0xffff;        [color=var(--color-prettylights-syntax-comment)]//Initial value
        crc ^= ([color=var(--color-prettylights-syntax-constant)]uint16_t)(*data++) << [color=var(--color-prettylights-syntax-constant)]8; [color=var(--color-prettylights-syntax-comment)]// crc ^= (uint6_t)(*data)<<8; data++;
            [color=var(--color-prettylights-syntax-keyword)]if ( crc & [color=var(--color-prettylights-syntax-constant)]0x8000 )
                crc = (crc << [color=var(--color-prettylights-syntax-constant)]1) ^ [color=var(--color-prettylights-syntax-constant)]0x1021;
[color=var(--color-prettylights-syntax-comment)] * Name:    CRC-16/X25          x16+x12+x5+1
[color=var(--color-prettylights-syntax-comment)] * Xorout:  0XFFFF
[color=var(--color-prettylights-syntax-constant)]uint16_t [color=var(--color-prettylights-syntax-entity)]crc16_x25([color=var(--color-prettylights-syntax-constant)]uint8_t *data, [color=var(--color-prettylights-syntax-constant)]uint16_t length)
    [color=var(--color-prettylights-syntax-keyword)]return ~crc;                [color=var(--color-prettylights-syntax-comment)]// crc^Xorout
[color=var(--color-prettylights-syntax-comment)] * Name:    CRC-16/XMODEM       x16+x12+x5+1
[color=var(--color-prettylights-syntax-comment)] * Alias:   CRC-16/ZMODEM,CRC-16/ACORN
[color=var(--color-prettylights-syntax-constant)]uint16_t [color=var(--color-prettylights-syntax-entity)]crc16_xmodem([color=var(--color-prettylights-syntax-constant)]uint8_t *data, [color=var(--color-prettylights-syntax-constant)]uint16_t length)
        crc ^= ([color=var(--color-prettylights-syntax-constant)]uint16_t)(*data++) << [color=var(--color-prettylights-syntax-constant)]8; [color=var(--color-prettylights-syntax-comment)]// crc ^= (uint16_t)(*data)<<8; data++;
[color=var(--color-prettylights-syntax-comment)] * Name:    CRC-16/DNP          x16+x13+x12+x11+x10+x8+x6+x5+x2+1
[color=var(--color-prettylights-syntax-comment)] * Poly:    0x3D65
[color=var(--color-prettylights-syntax-comment)] * Use:     M-Bus,ect.
[color=var(--color-prettylights-syntax-constant)]uint16_t [color=var(--color-prettylights-syntax-entity)]crc16_dnp([color=var(--color-prettylights-syntax-constant)]uint8_t *data, [color=var(--color-prettylights-syntax-constant)]uint16_t length)
                crc = (crc >> [color=var(--color-prettylights-syntax-constant)]1) ^ [color=var(--color-prettylights-syntax-constant)]0xA6BC;        [color=var(--color-prettylights-syntax-comment)]// 0xA6BC = reverse 0x3D65
[color=var(--color-prettylights-syntax-comment)] * Name:    CRC-32  x32+x26+x23+x22+x16+x12+x11+x10+x8+x7+x5+x4+x2+x+1
[color=var(--color-prettylights-syntax-comment)] * Poly:    0x4C11DB7
[color=var(--color-prettylights-syntax-comment)] * Init:    0xFFFFFFF
[color=var(--color-prettylights-syntax-comment)] * Xorout:  0xFFFFFFF
[color=var(--color-prettylights-syntax-comment)] * Alias:   CRC_32/ADCCP
[color=var(--color-prettylights-syntax-comment)] * Use:     WinRAR,ect.
[color=var(--color-prettylights-syntax-constant)]uint32_t [color=var(--color-prettylights-syntax-entity)]crc32([color=var(--color-prettylights-syntax-constant)]uint8_t *data, [color=var(--color-prettylights-syntax-constant)]uint16_t length)
    [color=var(--color-prettylights-syntax-constant)]uint32_t crc = [color=var(--color-prettylights-syntax-constant)]0xffffffff;        [color=var(--color-prettylights-syntax-comment)]// Initial value
                crc = (crc >> [color=var(--color-prettylights-syntax-constant)]1) ^ [color=var(--color-prettylights-syntax-constant)]0xEDB88320;[color=var(--color-prettylights-syntax-comment)]// 0xEDB88320= reverse 0x04C11DB7
[color=var(--color-prettylights-syntax-comment)] * Name:    CRC-32/MPEG-2  x32+x26+x23+x22+x16+x12+x11+x10+x8+x7+x5+x4+x2+x+1
[color=var(--color-prettylights-syntax-comment)] * Xorout:  0x0000000
[color=var(--color-prettylights-syntax-constant)]uint32_t [color=var(--color-prettylights-syntax-entity)]crc32_mpeg_2([color=var(--color-prettylights-syntax-constant)]uint8_t *data, [color=var(--color-prettylights-syntax-constant)]uint16_t length)
        crc ^= ([color=var(--color-prettylights-syntax-constant)]uint32_t)(*data++) << [color=var(--color-prettylights-syntax-constant)]24;[color=var(--color-prettylights-syntax-comment)]// crc ^=(uint32_t)(*data)<<24; data++;
            [color=var(--color-prettylights-syntax-keyword)]if ( crc & [color=var(--color-prettylights-syntax-constant)]0x80000000 )
                crc = (crc << [color=var(--color-prettylights-syntax-constant)]1) ^ [color=var(--color-prettylights-syntax-constant)]0x04C11DB7;
GMT+8, 2025-12-25 14:22 , Processed in 0.027838 second(s), 4 queries , Gzip On, Redis On.
