查看: 2879|回复: 0
[原创] TETCOS NETSIM PRO 13.3 (2023) WITH FULL LICENSE AND TUTORIALS
发表于 2022-7-26 20:39:07 | 显示全部楼层 |阅读模式
TETCOS NETSIM PRO 13.3 (2023 VERSION)
Do you wish to accelerate network R&D and reduce your time-to-publish? NetSim Standard is smartly packaged for Network R&D at universities and comes loaded with almost all the features of NetSim Pro.
Netsim Standard is available as technology libraries from which users can choose and assemble.
It comes with source C code and allows users to:
  • Design new protocols and technologies, as well as evaluate changes to existing ones.
  • Test and demonstrate designs in realistic scenarios.
  • Optimize protocol and application performance.
  • Study the effect of real devices and transmit live traffic using NetSim Emulator. Emulator combines the real and virtual worlds to create scenarios that cannot be achieved in a lab environment
8 Reasons Why You Need NetSim
NetSim Standard Version
Open Source Simulators
1.
Easy to use GUI   allows users to simply drag and drop devices, links and applications
Write hundreds of lines of script code to create network scenarios
2.
Results dashboard   provides appealing simulation performance reports with tables & graphs
Analyse and write code to extract performance results from multi megabyte files
3.
Inbuilt graphing   with extensive formatting (axes, colours, zoom, titles etc)
Write programs on external tools for graphs
4.
Wide range of technologies   including the latest in IOT, WSN, MANET, Cognitive Radio, 802.11 n / ac, TCP, BIC / CUBIC, Rate adaptation with packet and event tracing
Limited technologies
5.
R & D projects   available with source C code and documentation to easily develop / improve on
Read through thousands of lines of C++ codes to figure out what to modify to do your research
6.
Online debug   capability and ability to "watch" all variables.
  Run animation   in parallel for immediate visual feedback
Code tens of printf statements to debug your code
7.
External interfaces   to external software like MATLAB®, SUMO and Wireshark
Spend many days researching how to link to external software
8.
Researchers trust NetSim   for simulating MANET radios, emulating huge distribution networks or simply presenting a report to management. A team of NetSim engineers continuously verify NetSim results through hundreds of tests every day.
Unsure of the quality of the build / patch you have used and if the results are even valid at the end
Featured Research Areas
Examples of Research Areas Using NetSim
  • 5G NR:   End to End simulation of 5G NR, Radio numerology and impact on latency, Channel models for FR1 and FR2
  • Internet of Things   - IOT Security, Energy management and sustainable operation, 6LOWPAN based IOT Design, RPL protocol in IOT - attacks in RPL, DODAG formation
  • Wireless Sensor Networks   Energy efficient, Routing, Clustering, LEACH, Localization
  • Cognitive Radio Networks:   Spectrum sensing and incumbent detection, Spectrum allocation, Interference analysis, spectrum usage
  • Mobile Adhoc Networks: Location based, power aware routing, Sink hole attack, Intrusion Detection system
  • VANETs   v2v and v2i communication, Mobility models and connectivity, Clustering and routing
  • Software Defined Networks (SDN)   SDN for Wired / Wireless / MANETs and VANETs, ​​​​Performance evaluation, SDN based traffic engineering and QoS
If you are interested in the full licensed software TETCOS NETSIM STANDARD 13.1 (2022 VERSION) with full feature license and tutorial examples, then do well to contact     fast.forever24@gmail.com
GMT+8, 2025-10-22 19:24 , Processed in 0.018171 second(s), 4 queries , Gzip On, Redis On.
