查看: 1715|回复: 0
REMCOM WAVEFARER RADAR SIMULATION SOFTWARE 2.1 (2022 VERSION) WITH LICENSE AND EXAMPLES
发表于 2022-7-26 19:29:01 | 显示全部楼层 |阅读模式
WaveFarer® is a high-fidelity radar simulator that accounts for multipath and scattering from structures and vehicles in the immediate environment of a radar system as well as key atmospheric and scattering effects for frequencies up to and beyond 100 GHz. Applications include simulation of automotive drive scenarios, indoor sensors, and far field radar cross section (RCS).
Applications
WaveFarer is designed to support all applications relevant for simulation and analysis of a radar system. For automotive radar, this includes evaluating radar sensor placement and target returns within a simulated drive scenario environment. For surveillance radar applications, this includes analysis of target radar cross section (RCS) and the impact of materials on results. For a variety of other radar and sensor applications, WaveFarer can be used to determine how the placement of a sensor and the presence of various nearby structures might affect the radar returns.
Features
WaveFarer's features enable fast and accurate analysis of scenarios with radars in close proximity to structures, targets, and other features in a simulated environment. Key features include the following:
Near field propagation method Calculate scattering off target surfaces, including multipath interactions with ground reflections, using ray-tracing algorithms and physics-based calculations.
Targeted ray casting  Efficiently produce high fidelity returns by fully-illuminating targets.
Diffuse Scattering Calculate contribution of scattering from rough surfaces to radar clutter.
Dynamic scenario Apply movement to radar sensors, target vehicles, and other scatterers in your drive test simulations.
User defined antennas Import measured or simulated radiation patterns.
Scripts for chirp waveforms and range-Doppler Use WaveFarer scripts and utilities to simulate chirp waveforms, and post-process results to provide range-Doppler and other outputs.
Shared platform with XFdtd Integrated solution promotes productivity.
If you are interested in the full licensed software   REMCOM WAVEFARER RADAR 2.1 (2022 VERSION) with full feature license and examples, then do well to contact    fast.forever24@gmail.com
GMT+8, 2025-12-23 01:58 , Processed in 0.020450 second(s), 4 queries , Gzip On, Redis On.
