查看: 4413|回复: 2
vcs2017在ubuntu20.04LTS中编译时出现错误:Failed to make rmapats.so
发表于 2022-7-8 15:49:52 | 显示全部楼层 |阅读模式
各位大神,在ubuntu20.04 LTS中使用vcs编译时出现以下问题,请问有人遇到过,或者有解决方案吗?
已经试过gcc 4.8.5和gcc4.4.7两个版本都不行,全网搜,也没找到相关的帖子。
This program is proprietary and confidential information of Synopsys Inc.
and may be used and disclosed only as authorized in a license agreement
controlling such use and disclosure.
15:48:01 (snpslmd) OUT: "VCSCompiler_Net" ThinkBook-14-G2-ARE  [snps_checkout_1657266481]
Parsing design file './sim.v'
Parsing design file './AsyncCmp.sv'
Parsing design file './FifoRam.sv'
Parsing design file './MyAsyncFifo.sv'
Parsing design file './RdPointer.sv'
Parsing design file './WrPointer.sv'
Top Level Modules:
       sim
TimeScale is 1 ns / 1 ps
Starting vcs inline pass...
1 module and 0 UDP read.
    However, due to incremental compilation, no re-compilation is necessary.
15:48:01 (snpslmd) IN: "VCSCompiler_Net" ThinkBook-14-G2-ARE  [snps_checkout_1657266481]
/usr/bin/ld: rmapats_mop.o: .symtab local symbol at index 23 (>= sh_info of 1)
/usr/bin/ld: rmapats_mop.o: error adding symbols: bad value
collect2: ld returned 1 exit status
make: *** [Makefile.hsopt:47: rmapats.so] Error 1
Error: Failed to make rmapats.so @ simv.daidir/rmapats.so
发表于 2022-7-8 23:32:07 | 显示全部楼层
-fPIC ?
发表于 2023-5-25 17:37:49 | 显示全部楼层
楼主这个解决了吗,怎么搞的。
GMT+8, 2025-12-31 02:55 , Processed in 0.019288 second(s), 5 queries , Gzip On, Redis On.
