查看: 10225|回复: 20
[求助] LDO PSR的提升讨论
发表于 2022-5-8 14:34:36 | 显示全部楼层 |阅读模式
LDO的PSR的低频段可以通过提高环路增益来提升,但是高频段要怎么提升呢?由于不是capless结构,所以CL已经很大了,2uF多吧
发表于 2022-5-8 22:26:12 | 显示全部楼层
2020_2020_A 5.6uA Wide Bandwidth, High Power Supply Rejection Linear Low-Dropout Regulator with 68dB of PSR Up to 2MHz
Abstract
High power supply rejection (PSR) with a wide rejection frequency band is becoming a critical requirement in linear low-dropout regulators (LDOs) used in complex systems-on-chip (SOCs). Typical LDOs achieve higher PSR within their loop-bandwidth; however, their supply rejection performance degrades with reduced loop-gain outside their loop-bandwidth. Typical LDOs with external filtering capacitors may also have spectral peaking in their PSR response, causing excess system-level supply noise. This work presents an LDO design approach, which achieves a PSR of higher than 68 dB up to 2 MHz frequency and over a wide range of loads up to 250 mA. The wide PSR bandwidth is achieved using a current-mode feedforward ripple canceller (CFFRC) amplifier which provides up to 25 dB of PSR improvement. The feedforward path gain is inherently matched to the forward gain of the LDO, not requiring calibration. The LDO has a fast load transient response with a recovery time of 6.1 \mu \text {s} and has a quiescent current of 5.6 \mu \text {A}. For a full load transition, the LDO achieves settling with overshoot and undershoot voltages below 27.6 and 36.36 mV, respectively. The LDO is designed and fabricated in a 180 nm bipolar/CMOS/DMOS (BCD) technology. The CFFRC amplifier helps to achieve low quiescent power due to its inherent current mode nature, eliminating the need for supply ripple summing amplifiers and adaptive biasing.
发表于 2022-5-8 22:27:37 | 显示全部楼层
2018_A 65-nm CMOS Low Dropout Regulator Featuring -60-dB PSRR Over 10-MHz Frequency Range_JSSC
2018_A 65-nm CMOS Low Dropout Regulator Featuring -60-dB PSRR Over 10-MHz Freque.pdf
4.14 MB, 下载次数: 376 , 下载积分: 资产 -3 信元, 下载支出 3 信元
发表于 2022-5-8 22:29:00 | 显示全部楼层
2013_A 25mA CMOS LDO with -85dB PSRR at 2.5MHz_ASSCC 2013
2013_A 25mA CMOS LDO with -85dB PSRR at 2.5MHz_ASSCC.pdf
309.17 KB, 下载次数: 272 , 下载积分: 资产 -2 信元, 下载支出 2 信元
发表于 2022-5-8 22:29:59 | 显示全部楼层
2012_A 30-mA CMOS Low Dropout Regulator for WiMAX Analog Front Ends with 50 dB PSRR at 10 MHz
2012_A 30-mA CMOS Low Dropout Regulator for WiMAX Analog Front Ends with 50 dB P.pdf
1.01 MB, 下载次数: 168 , 下载积分: 资产 -2 信元, 下载支出 2 信元
发表于 2022-5-8 22:31:00 | 显示全部楼层
2009_A 25mA 0.13um CMOS LDO Regulator with PSR Better Than -56dB up to 10MHz Using Feedforward Ripple-Cancellation Technique_ISSCC 2009
2009_A 25mA 0.13um CMOS LDO Regulator with PSR Better Than -56dB up to 10MHz Usi.pdf
663.28 KB, 下载次数: 191 , 下载积分: 资产 -2 信元, 下载支出 2 信元
 楼主| 发表于 2022-5-14 16:03:20 | 显示全部楼层
sunjimmy 发表于 2022-5-8 22:31
2009_A 25mA 0.13um CMOS LDO Regulator with PSR Better Than -56dB up to 10MHz Using Feedforward Rippl ...
十分感谢,但是现在有个新的问题,由于我的输入电压只有1.65V,而输出要1.375V,在所有PVT corner下,均是在20mA loading的时候,PSR会掉到-19dB,电压太小使得很多结构无法使用,工艺里只提供了native PMOS(你前面发的文章里有需要用到native nmos的),所以现在很迷惑
发表于 2022-5-14 21:43:47 | 显示全部楼层
这是我以前写的关于PSRR的文章,要是你看明白了,就会对运放的PSRR有个基本的了解和分析
https://bbs.eetop.cn/forum.php?mod=viewthread&tid=300477
基本上第一条-20dB渐近线和补偿电容有关,如果能改进补偿,用更小的补偿电容,这条-20dB渐近线就会得到改善
稍微更新下文章
计算PSRR的新方法 20140709.pdf (663.82 KB , 下载次数: 346 )
发表于 2022-5-15 00:31:55 | 显示全部楼层
native NMOS is free device in most CMOS process node. NMOS without channel implant is native NMOS.
Most foundry didn't provide this model because they didn't characterize it and made a spice model for it. You may ask your foundry for it in case they had it already, but didn't release to customers.
Without native NMOS, you may try the architecture in "2013_A 25mA CMOS LDO with -85dB PSRR at 2.5MHz_ASSCC 2013". It seems that this architecture can fulfill your requirement.
 楼主| 发表于 2022-5-15 20:46:40 | 显示全部楼层
M ...
thanks a lot
GMT+8, 2025-9-27 09:31 , Processed in 0.020698 second(s), 4 queries , Gzip On, Redis On.
