查看: 5455|回复: 6
sentaurus安装license问题求教
发表于 2022-4-15 17:45:03 | 显示全部楼层 |阅读模式
vmware虚拟机安装centos7系统下安装sentaurus,license一直出问题,求大神指导一二。
提示找不到license文件,但是我在.bashrc文件已经定义了LM_LICENSE_FILE,bashrc文件如下
license内容如下
大神注意第三行,如果我把注释#去掉,错误变成如下
运行lmgrd,结果如下
[user1@localhost ~]$ lmgrd
[user1@localhost ~]$  5:41:25 (lmgrd) -----------------------------------------------
5:41:25 (lmgrd)   Please Note:
5:41:25 (lmgrd)
5:41:25 (lmgrd)   This log is intended for debug purposes only.
5:41:25 (lmgrd)   In order to capture accurate license
5:41:25 (lmgrd)   usage data into an organized repository,
5:41:25 (lmgrd)   please enable report logging. Use Flexera Software, Inc.'s
5:41:25 (lmgrd)   software license administration  solution,
5:41:25 (lmgrd)   FLEXnet Manager, to  readily gain visibility
5:41:25 (lmgrd)   into license usage data and to create
5:41:25 (lmgrd)   insightful reports on critical information like
5:41:25 (lmgrd)   license availability and usage. FLEXnet Manager
5:41:25 (lmgrd)   can be fully automated to run these reports on
5:41:25 (lmgrd)   schedule and can be used to track license
5:41:25 (lmgrd)   servers and usage across a heterogeneous
5:41:25 (lmgrd)   network of servers including Windows NT, Linux
5:41:25 (lmgrd)   and UNIX. Contact Flexera Software, Inc. at
5:41:25 (lmgrd)   www.flexerasoftware.com for more details on how to
5:41:25 (lmgrd)   obtain an evaluation copy of FLEXnet Manager
5:41:25 (lmgrd)   for your enterprise.
5:41:25 (lmgrd)
5:41:25 (lmgrd)
5:41:25 (lmgrd)
5:41:25 (lmgrd) FLEXnet Licensing (v11.10.0.3 build 96543 x64_lsb) started on localhost.localdomain (linux) (4/15/2022)
5:41:25 (lmgrd) Copyright (c) 1988-2011 Flexera Software, Inc. All Rights Reserved.
5:41:25 (lmgrd) US Patents 5,390,297 and 5,671,412.
5:41:25 (lmgrd) World Wide Web:  http://www.flexerasoftware.com
5:41:25 (lmgrd) License file(s): /opt/sentaurus/license/license.dat
5:41:25 (lmgrd) lmgrd tcp-port 27000
5:41:25 (lmgrd) Starting vendor daemons ...
5:41:25 (lmgrd) Started snpslmd (internet tcp_port 60820 pid 6447)
5:41:25 (snpslmd) FLEXnet Licensing version v11.9.1.5 build 104455 x64_lsb
5:41:26 (snpslmd) lmgrd version 11.10, snpslmd version 11.9
04/15/2022 05:41:26 (snpslmd) Synopsys Corporate Licensing (SCL) Release: version SCL_11.5
5:41:26 (snpslmd) EXPIRED: SSS
5:41:26 (snpslmd) Server started on localhost.localdomain for:        nanochar
5:41:26 (snpslmd) hspice_pack        cosmos_other        cxp
5:41:26 (snpslmd) Synopsys_VCS_cmv Design-Expert        him_mm_pi
5:41:26 (snpslmd) CXp_GUI                CXp_Analysis        CXp_CircuitEnvironment
5:41:26 (snpslmd) COSMOS_SCOPE        COSMOS_SCOPE        CmMonitor
5:41:26 (snpslmd) VCSiRuntimeLimited_Node VCSiRuntimeLimited_Net VMCCompiler_Node
5:41:26 (snpslmd) VMCRuntime_Node VMCEvaluation_Node VMCGeneratorUnlocked_Node
5:41:26 (snpslmd) VMCExpress_Compiler_Node VMCCompiler_Net VMCRuntime_Net
5:41:26 (snpslmd) VMCEvaluation_Net VMCGeneratorUnlocked_Net VMCExpress_Compiler_Net
5:41:26 (snpslmd) LMCSwift_Node        SNPS-Assertions VT_SystemVerilog
5:41:26 (snpslmd) VCSMXRunTime_Net VCSMXiRunTime_Net Magellan-Sim
5:41:26 (snpslmd) VT_SVAssertions VT_SVTestbench        VT_NativeTestbench
5:41:26 (snpslmd) VT_DVE                VT_UCLI                VT_LCA_Testbench
5:41:26 (snpslmd) PVCSCompiler_Net PVCSRuntime_Net VT_VCS_Power_Management
5:41:26 (snpslmd) VT_VCS_Checker        VT_VCS_Echo        RMAN_RUN
5:41:26 (snpslmd) VT_VCS_NTBE        XVVCDebugger        VT_UnifiedCoverage
5:41:26 (snpslmd) VT_64Bit        VT_OtherTechnology VT_NativeTBDebuggerGui
5:41:26 (snpslmd) VT_CBUG                VT_SVAssertionCompiler VT_SDebug
5:41:26 (snpslmd) VT_DVENTB        VT_Pioneer        VT_SYSTEMC21
5:41:26 (snpslmd) VT_LCA_Coverage VT_LCA_DEBUG        VT_LCA_Assertions
5:41:26 (snpslmd) VT_LCA_MixedSignal VT_DVE_COV        VT_VCS_Advanced_Features
5:41:26 (snpslmd) VT_VCS_BETA_Program VT_PVCSCompiler_Net DesignWare-ETHERNET
5:41:26 (snpslmd) DesignWare-ETHERNET Primepower        Primepower
5:41:26 (snpslmd) Primepower_gui        Primepower_gui        fpc_foundation
5:41:26 (snpslmd) fpc_pna                fpc_utils        fpc_special1
5:41:26 (snpslmd) fpc_special2        fpc_special3        Test-Validate
5:41:26 (snpslmd) Test-Accelerate-Max chiparch_migrate planet_migrate
5:41:26 (snpslmd) DesignWare-ARMCORES-tlm DesignWare-AMBA-tlm Test-LBIST-Integration
5:41:26 (snpslmd) VHDL-Compiler-Presto primepower_vcd        Test-Beta-7
5:41:26 (snpslmd) Test-Beta-8        Test-Beta-9        Test-STDVR
5:41:26 (snpslmd) Test-MBIST-Integration HDL-Compiler-SystemVerilog primepower_beta
5:41:26 (snpslmd) MV-Opt                PhysOpt-VH        Formality-TX
5:41:26 (snpslmd) Formality-Distributed PhysOpt-Integration PhysOpt-Beta-Milkyway
5:41:26 (snpslmd) PhysOpt-Beta-SI PhysOpt-Beta-CTS PhysOpt-Beta-Route
5:41:26 (snpslmd) Test-Fault-Max        PAW                PsynGui-ChipMap
5:41:26 (snpslmd) Formality-ESP        PhysOpt-XG        PsynGui-AARender
5:41:26 (snpslmd) Test-Compression-ATPG Test-Compression-Synthesis HDL-Compiler-Old
5:41:26 (snpslmd) VHDL-Compiler-Old Test-Mbist-Program Test-Mbist-Bitstream
5:41:26 (snpslmd) Galileo                Galileo-PSYN        Galileo-PnR
5:41:26 (snpslmd) Galileo-GUI        NanoTime        NanoTime-PathMill-Shared
5:41:26 (snpslmd) Galileo-Internal-Only PhysOpt-MV        Astro-MV
5:41:26 (snpslmd) Galaxy-GUI-PSYN Galaxy-GUI-PNR        Galaxy-Beta
5:41:26 (snpslmd) Galaxy-Internal-Only PrimeTime-New-Technology PrimeRail
5:41:26 (snpslmd) Power-Optimization-Beta1 Power-Optimization-Beta2 Formality-Beta1
5:41:26 (snpslmd) Formality-Beta2 Galaxy-MCMM        PrimeTime-PX
5:41:26 (snpslmd) DB-Mode                DC-Topographical snps_fs_nwave
5:41:26 (snpslmd) Pathmill-migrate Pathmill-plus-migrate NanoTime-ultra
5:41:26 (snpslmd) Galaxy-CCS        Galaxy_FP_Beta        Galaxy_MultiRoute4
5:41:26 (snpslmd) Galaxy_MultiRoute8 PrimeTime-VX        Galaxy-AdvRules
5:41:26 (snpslmd) Galaxy-FlipChip Galaxy-FP-Hier        Test-SDD-Timing
5:41:26 (snpslmd) Galaxy-AdvOpt        Galaxy-CTMesh        Galaxy-Zroute
5:41:26 (snpslmd) Test-Power        Test-Physical        DCT-Congestion
5:41:26 (snpslmd) DCT-GUI                DC-Extension        Galaxy-FP-MV
5:41:26 (snpslmd) Galaxy-FP-AdvCTS Galaxy-FP-AdvTech NCX
5:41:26 (snpslmd) Galaxy-SPG        PrimeTime-PX-Statistical PrimeTime-PX-New-Technology
5:41:26 (snpslmd) PrimeRail-New-Technology PrimeRail-static PrimeRail-adv
5:41:26 (snpslmd) Test-CompressionPlus-Syn Test-CompressionPlus-ATPG NCX-addon
5:41:26 (snpslmd) HERCULES_DEBUGGER HERCULES_DEBUGGER HERCULES_DEVICE
5:41:26 (snpslmd) HERCULES_DEVICE HERCULES_DRC        HERCULES_DRC
5:41:26 (snpslmd) HERCULES_ERC        HERCULES_ERC        HERCULES_HLPE
5:41:26 (snpslmd) HERCULES_HLPE        HERCULES_LVS        HERCULES_LVS
5:41:26 (snpslmd) HERCULES_MANAGER HERCULES_MANAGER HERCULES_MASK
5:41:26 (snpslmd) HERCULES_MASK        HERCULES_RCE        HERCULES_RCE
5:41:26 (snpslmd) HERCULES_VUE        HERCULES_VUE        LTL-100_GDS
5:41:26 (snpslmd) LTL-100_GDS        LTL-100_NDW        LTL-100_NDW
5:41:26 (snpslmd) MDataPrep        MDataPrep        MDynLink
5:41:26 (snpslmd) MDynLink        MVerilog        MVerilog
5:41:26 (snpslmd) Milkyway        Milkyway        NET-TRAN
5:41:26 (snpslmd) NET-TRAN        STAR-ASCII        STAR-ASCII
5:41:26 (snpslmd) STAR-CR                STAR-CR                STAR-EX
5:41:26 (snpslmd) STAR-EX                STAR-EX_ERC        STAR-EX_ERC
5:41:26 (snpslmd) STAR-FILTER        STAR-FILTER        STAR-GAZER
5:41:26 (snpslmd) STAR-GAZER        STAR-LD2LTL        STAR-LD2LTL
5:41:26 (snpslmd) STAR-R                STAR-R                STAR-RC2
5:41:26 (snpslmd) STAR-RC2        STAR-RC2-AEO        STAR-RC2-AEO
5:41:26 (snpslmd) STAR-RC2-DB        STAR-RC2-DB        STAR-RC2-DISTRIB10
5:41:26 (snpslmd) STAR-RC2-DISTRIB10 STAR-RC2-NETLIST STAR-RC2-NETLIST
5:41:26 (snpslmd) STAR-RC2-PROBER STAR-RC2-PROBER STAR-RC2-TCAD
5:41:26 (snpslmd) STAR-RC2-TCAD        STAR-RC2-VIEWER STAR-RC2-VIEWER
5:41:26 (snpslmd) STAR-RC2-XSTOR1 STAR-RC2-XSTOR1 STAR-RC2-XSTOR2
5:41:26 (snpslmd) STAR-RC2-XSTOR2 STAR-RC2-XTR-AEO STAR-RC2-XTR-AEO
5:41:26 (snpslmd) STAR-RC2-XTRACT STAR-RC2-XTRACT STAR-RC2_MANAGER
5:41:26 (snpslmd) STAR-RC2_MANAGER STAR-SYN2STAR        STAR-SYN2STAR
5:41:26 (snpslmd) STAR-TCAD        STAR-TCAD        STAR-XREF
5:41:26 (snpslmd) STAR-XREF        SynopsysCustomICCLink SynopsysCustomLayout
5:41:26 (snpslmd) SynopsysCustomSAE SynopsysCustomSAEBatch SynopsysCustomSDL
5:41:26 (snpslmd) SynopsysCustomSchematic cdsaawaves        cdsaawaves
5:41:26 (snpslmd) encrypt                encrypt                fullhspice
5:41:26 (snpslmd) hspice                hspice                hspice3des
5:41:26 (snpslmd) hspice3des        hspicecmidev        hspicecmidev
5:41:26 (snpslmd) hspicecmirt        hspicecmirt        hspicerf
5:41:26 (snpslmd) hspicerf        hspiceva        hspiceva
5:41:26 (snpslmd) metaencrypt3des metaencrypt3des nanosim
5:41:26 (snpslmd) nanosim                ace_cosim        simif
5:41:26 (snpslmd) simif                simif                spice_parser
5:41:26 (snpslmd) spice_parser        sx_wva                sx_wva
5:41:26 (snpslmd) xsim                COSMOS_VO        COSMOS_VO
5:41:26 (snpslmd) CPI-100                CPI-100                EV-ACCESS
5:41:26 (snpslmd) EV-ACCESS        EV-ACCESS_UTIL        EV-ACCESS_UTIL
5:41:26 (snpslmd) Enterprise_VO        Enterprise_VO        HERCULES-CRYPT_XREF_DATA
5:41:26 (snpslmd) HERCULES-CRYPT_XREF_DATA HERCULES-DP_MT        HERCULES-DP_MT
5:41:26 (snpslmd) HERCULES-EXPLORER_DRC HERCULES-EXPLORER_DRC HERCULES-EXPLORER_FILTERS
5:41:26 (snpslmd) HERCULES-EXPLORER_FILTERS HERCULES-EXPLORER_LVS HERCULES-EXPLORER_LVS
5:41:26 (snpslmd) HERCULES-NETLIST HERCULES-NETLIST HERCULES-RUN_TRAN
5:41:26 (snpslmd) HERCULES-RUN_TRAN DC-FPGA-Add-On-to-DC DC-FPGA-Add-On-to-DC
5:41:26 (snpslmd) DESIGNWARE-AMBA-VIP DESIGNWARE-AMBA-VIP DESIGNWARE-I2C-VIP
5:41:26 (snpslmd) DESIGNWARE-I2C-VIP DESIGNWARE-REGRESSION DESIGNWARE-REGRESSION
5:41:26 (snpslmd) DESIGNWARE-SIO-VIP DESIGNWARE-SIO-VIP DESIGNWARE-VERIFICATION
5:41:26 (snpslmd) DESIGNWARE-VERIFICATION DWC-AHB-ICTL-Source DWC-AHB-ICTL-Source
5:41:26 (snpslmd) DWC-AHB-Source        DWC-AHB-Source        DWC-AMBA-Fabric-Source
5:41:26 (snpslmd) DWC-AMBA-Fabric-Source DWC-APB-Advanced-Source DWC-APB-Advanced-Source
5:41:26 (snpslmd) DWC-APB-ICTL-Source DWC-APB-ICTL-Source DWC-APB-Periph-Source
5:41:26 (snpslmd) DWC-APB-Periph-Source DWC-DMA-Controller-Source DWC-DMA-Controller-Source
5:41:26 (snpslmd) DWC-DMAC-Source DWC-DMAC-Source DWC-GPIO-Source
5:41:26 (snpslmd) DWC-GPIO-Source DWC-I2C-Source        DWC-I2C-Source
5:41:26 (snpslmd) DWC-INTC-CNTL-Source DWC-INTC-CNTL-Source DWC-MEMCTL-Source
5:41:26 (snpslmd) DWC-MEMCTL-Source DWC-RAP-Source        DWC-RAP-Source
5:41:26 (snpslmd) DWC-RTC-Source        DWC-RTC-Source        DWC-SSI-Source
5:41:26 (snpslmd) DWC-SSI-Source        DWC-TIMERS-Source DWC-TIMERS-Source
5:41:26 (snpslmd) DWC-UART-SRC        DWC-UART-SRC        DWC-UART-Source
5:41:26 (snpslmd) DWC-UART-Source DWC-WDT-Source        DWC-WDT-Source
5:41:26 (snpslmd) DesignWare-MEMCTL-Source DesignWare-MEMCTL-Source JupiterXT_VF
5:41:26 (snpslmd) JupiterXT_VF        SABER_GUIDE        SABER_GUIDE
5:41:26 (snpslmd) VT_LCA_Language VT_LCA_Language VT_NTB
5:41:26 (snpslmd) VT_NTB                VT_SVDesign        VT_SVDesign
5:41:26 (snpslmd) aPrv                aPrv                aPrv
5:41:26 (snpslmd) sharp                sharp                VHDLAMS_TAURILI
5:41:26 (snpslmd) VHDLAMS_TAURI        MODPEX_AWB        MODPEX_CTC
5:41:26 (snpslmd) MODPEX_ELDO        MODPEX_MARELLI        MODPEX_NOPOWER
5:41:26 (snpslmd) MODPEX_PTFT        MODPEX_SABER        MODPEX_STATIS
5:41:26 (snpslmd) MODPEX_TVS        MONTE_CARLO        MONTE_CARLO_MEMSSE
5:41:26 (snpslmd) MOS_TOOL        MOS_TOOL_MEMSSE MOTOR_DCPM_TOOL
5:41:26 (snpslmd) MOTOR_DCPM_TOOL_MEMSSE OPT_TEMPLATE_LIB_MEMSSE PLACEHOLDER
5:41:26 (snpslmd) PNET_LIBRARY        PNEUM_HYD_PRG1        PNEU_HYD_LIBRARY
5:41:26 (snpslmd) POLARIS_SCOPE        POLARIS_X        POWER_EXPRESS
5:41:26 (snpslmd) SABER_SKETCH_NETLISTER SABER_SKETCH_NETLISTER_MEMSSE SABER_TSP
5:41:26 (snpslmd) SABER_VERILOG_MM SABER_VERILOG_MM_MEMSSE SABER_VHDLAMS
5:41:26 (snpslmd) SABER_VHDLAMS_MEMSSE SABER_VIEWSIM_MM SABER_VIEWSIM_MM_MEMSSE
5:41:26 (snpslmd) SCAN_TOOL        SCAN_TOOL_MEMSSE SENSITIVITY
5:41:26 (snpslmd) SENSITIVITY_MEMSSE SJCL_LIBRARY        SPECTRAL
5:41:26 (snpslmd) SPECTRAL_MEMSSE STATEBENCH        STRESS
5:41:26 (snpslmd) STRESS_MEMSSE        SYMLIB                SYMLIB_JAPANESE
5:41:26 (snpslmd) SYMLIB_JAPANESE_MEMSSE SYMLIB_MEMSSE        SYMLIB_PLUS
5:41:26 (snpslmd) SYMLIB_PLUS_MEMSSE SABERRT_ADI        SABERRT_ADI_MEMSSE
5:41:26 (snpslmd) SABERRT_AP2633        SABERRT_FE        SABERRT_FE_MEMSSE
5:41:26 (snpslmd) SABERRT_HIL        SABERRT_HIL_MEMSSE SABER_DEV_MM
5:41:26 (snpslmd) SABER_GUIDE_MEMSSE SABER_INTERFACE_MEMSSE SABER_LEAPFROG_MM
5:41:26 (snpslmd) SABER_MODELSIM_MM SABER_MODELSIM_MM_MEMSSE SABER_MODELSIM_PLUS_MM
5:41:26 (snpslmd) SABER_MODELSIM_PLUS_MM_MEMSSE SABER_MODELSIM_VHDL_MM SABER_MODELSIM_VHDL_MM_MEMSSE
5:41:26 (snpslmd) SABER_MODELSIM_VLOG_MM SABER_PLUGNSIM_MM SABER_QSIM_MM
5:41:26 (snpslmd) SABER_QVSPRO_MM SABER_RT_MM        SABER_RT_MM_MEMSSE
5:41:26 (snpslmd) SABER_RUNTIME        SABER_SCOPE_MEMSSE SABER_SIMMATRIX_MM
5:41:26 (snpslmd) SABER_SIMULATOR_MEMSSE SABER_SKETCH_MEMSSE SYMLIB_POWER
5:41:26 (snpslmd) SYMLIB_POWER_MEMSSE TESTIFY                TESTIFY_MEMSSE
5:41:26 (snpslmd) TESTIFY_NETLISTER_MEMSSE THERM_TOOL        THERM_TOOL_MEMSSE
5:41:26 (snpslmd) TLU_TOOL        TLU_TOOL_MEMSSE TR_ANALYSIS
5:41:26 (snpslmd) TR_ANALYSIS_MEMSSE VEHICLE_ELECTRIC_LIB_MEMSSE VENDOR_LIBRARY
5:41:26 (snpslmd) VENDOR_LIBRARY_MEMSSE VERIAS_HSPICE_COMPILER VERIAS_SIMULATOR
5:41:26 (snpslmd) VIEWLOGIC_FRAMEWAY VIEWLOGIC_FRAMEWAY_MEMSSE VIEWLOGIC_NET_MEMSSE
5:41:26 (snpslmd) WF_API_HSPICE        WF_API_HSPICE_MEMSSE WF_API_MEMSSE
5:41:26 (snpslmd) WF_API_STARSIM        WF_API_STARSIM_MEMSSE EDIF_NETLISTER
5:41:26 (snpslmd) EDIF_NETLISTER_MEMSSE EXPT_EDITOR        MAST_COMPILER
5:41:26 (snpslmd) MEASURE                MEASURE_MEMSSE        MEMS
5:41:26 (snpslmd) MENTOR_FRAMEWAY MENTOR_FRAMEWAY_MEMSSE MENTOR_NETLISTER
5:41:26 (snpslmd) MENTOR_NETLISTER_MEMSSE MICROCOSM_LIB        MICROCOSM_LIB2
5:41:26 (snpslmd) MICROCOSM_LIB2_MEMSSE MICROCOSM_LIB3        MICROCOSM_LIB3_MEMSSE
5:41:26 (snpslmd) MICROCOSM_LIB4        MICROCOSM_LIB4_MEMSSE MICROCOSM_LIB5
5:41:26 (snpslmd) MICROCOSM_LIB5_MEMSSE MICROCOSM_LIB6        MICROCOSM_LIB6_MEMSSE
5:41:26 (snpslmd) MICROCOSM_LIB7        MICROCOSM_LIB7_MEMSSE MICROCOSM_LIB_MEMSSE
5:41:26 (snpslmd) MODEL_ARCHITECT MODEL_ENCRYPTION_MEMSSE MODEL_SYNTHESIS_MEMSSE
5:41:26 (snpslmd) MODPEX                MODPEX_AQUEDUCT MODPEX_ASIM
5:41:26 (snpslmd) MODPEX_ATFT        HARNESS_CATIA        HARNESS_MCADREAD
5:41:26 (snpslmd) HARNESS_PROCABLE HARNESS_UNIGRAPHICS HSPICE_MODEL_LIBRARY_MEMSSE
5:41:26 (snpslmd) IC_DESIGN_LIB        IMECH_LIBRARY        IQBUS_AUTHOR_MEMSSE
5:41:26 (snpslmd) IQBUS_DESIGNER        IQBUS_LIB_MEMSSE LINK_MATLAB
5:41:26 (snpslmd) LINK_MATLAB_MEMSSE LINK_XMATH        LOAD_TOOL
5:41:26 (snpslmd) LOAD_TOOL_MEMSSE LSA_MEMSSE        LSA
5:41:26 (snpslmd) LTX_LIBRARY        COVENTOR_LIB10        COVENTOR_LIB10_MEMSSE
5:41:26 (snpslmd) COVENTOR_LIB11        COVENTOR_LIB11_MEMSSE COVENTOR_LIB12
5:41:26 (snpslmd) COVENTOR_LIB12_MEMSSE COVENTOR_LIB13        COVENTOR_LIB13_MEMSSE
5:41:26 (snpslmd) COVENTOR_LIB14        COVENTOR_LIB14_MEMSSE COVENTOR_LIB15
5:41:26 (snpslmd) COVENTOR_LIB15_MEMSSE COVENTOR_LIB8        COVENTOR_LIB8_MEMSSE
5:41:26 (snpslmd) COVENTOR_LIB9        COVENTOR_LIB9_MEMSSE DESIGNSTAR
5:41:26 (snpslmd) DESIGNSTAR_NET        DIODE_TOOL        DIODE_TOOL_MEMSSE
5:41:26 (snpslmd) DRCYCLE_TOOL        DRCYCLE_TOOL_MEMSSE ABB_CHCRC_LIBRARY
5:41:26 (snpslmd) AIM_DEBUG_MEMSSE AIM_DEVELOPER_MEMSSE AUT_NUMBER_MAJOR_PACKAGES
5:41:26 (snpslmd) BASIC_ANALYSES        BASIC_ANALYSES_MEMSSE BATCH_MEASURE
5:41:26 (snpslmd) BATCH_MEASURE_MEMSSE BATT_TOOL        BATT_TOOL_MEMSSE
5:41:26 (snpslmd) BETA_LIBRARY        BUILD_DATE        BUILD_NUMBER
5:41:26 (snpslmd) BUNDLE_MCAD_PROJECTION CADENCE_DIVA_NETLISTER CADENCE_FRAMEWAY
5:41:26 (snpslmd) CADENCE_FRAMEWAY_MEMSSE CADENCE_NETLISTER CADENCE_NETLISTER_MEMSSE
5:41:26 (snpslmd) COMPONENT_LIBRARY_MEMSSE CONCEPT_FRAMEWAY CONCEPT_NETLISTER
5:41:26 (snpslmd) CORENL_CHAR        CORENL_CHAR_MEMSSE COSMOS_GUIDE
5:41:26 (snpslmd) COSMOS_SKETCH        COSMOS_SKETCH_BACK_ANN COSMOS_SKETCH_NETLISTER
5:41:26 (snpslmd) EXPT_EDITOR_MEMSSE EXPT_EDITOR_PLUS EXPT_EDITOR_PLUS_MEMSSE
5:41:26 (snpslmd) FAILURE_MODE        FAILURE_MODE_MEMSSE FASTPARTS
5:41:26 (snpslmd) FUSE_CHAR        FUSE_CHAR_MEMSSE XC4000E
5:41:26 (snpslmd) XC4000EX        XC4000L                XC4000XL
5:41:26 (snpslmd) XC4000XLA        XC4000XV        XC5200
5:41:26 (snpslmd) XC9500                XC9500XL        XC9500XV
5:41:26 (snpslmd) xp                XVCSDebugger        XVCSiDebugger
5:41:26 (snpslmd) VSS-CompiledSim VSS-Debugger        VSS-Falcon-Interface
5:41:26 (snpslmd) VSS-GateSim        VSS-LAI-Models        VSS-Lib-Tools
5:41:26 (snpslmd) VSS-LMSI        VSS-Model-Developer VSS-NEC-Tran
5:41:26 (snpslmd) VSS-SDF-Interface VSS-SGE-Tool        VSS-Simulator
5:41:26 (snpslmd) VSS-SmartModels VSS-SPC                VSS-Tran
5:41:26 (snpslmd) VSS-Utilities        VSS-Verilog-PLI VSS-VIP-Interface
5:41:26 (snpslmd) VSS-Wave-Display VSS-XP-Accelerator VT_AssertionIP
5:41:26 (snpslmd) VT_Assertions        VT_AssertionsRuntime VT_Coverage
5:41:26 (snpslmd) VT_CoverageRuntime VT_CoverageURG        VT_Testbench
5:41:26 (snpslmd) VT_TestbenchRuntime VT_VCS_BETA_Features VT_VCS_LCA_Features
5:41:26 (snpslmd) VT_Visual        vtran                WhatIfAnalysis
5:41:26 (snpslmd) WRITE                XC3000                XC4000
5:41:26 (snpslmd) VIRTEXE                VIRTEXEA        Vivace-Code-Generator
5:41:26 (snpslmd) Vivace-Core        Vivace-Debug        Vivace-Elaborator
5:41:26 (snpslmd) Vivace-Expert        Vivace-Express        Vivace-GUI
5:41:26 (snpslmd) Vivace-HDL-Analyzer Vivace-Model-Compiler Vivace-Pro
5:41:26 (snpslmd) Vivace-Simulator Vivace-VHDL-Analyzer vlog_epic_pif
5:41:26 (snpslmd) vlog2e                vlsi2000        vlsi500
5:41:26 (snpslmd) VMCCompiler        VMCCore                VMCEvaluation
5:41:26 (snpslmd) VMCExpress_Compiler VMCGeneratorUnlocked VMCRuntime
5:41:26 (snpslmd) VPC                vsea-calib_all        VSP_DRIVER
5:41:26 (snpslmd) VSS-Analyzer        VSS-Backplane        VSS-Cadence-Interface
5:41:26 (snpslmd) VSS-CLI                vera_comp        vera_debug
5:41:26 (snpslmd) vera_ip                vera_rtime        Verdi
5:41:26 (snpslmd) Verification-Token Verilog                verilog_writer
5:41:26 (snpslmd) Verilog-Netlist-Writer Verilog-Parser        Verilog-To-BE
5:41:26 (snpslmd) Verilog-VirSim        vertue                vhdl_compiler
5:41:26 (snpslmd) VHDL-Analyzer        VHDL-Compiler        VHDL-Cycle-Sim
5:41:26 (snpslmd) VHDL-Elaborator VHDL-Event-Sim        VHDLi-Elaborator
5:41:26 (snpslmd) VHDLi-Event-Sim VHDL-Netlist-Writer VHDL-ScSim
5:41:26 (snpslmd) VHDL-To-BE        VHDL-Tools        VHDL-VirSim
5:41:26 (snpslmd) VHMC-Eval        VHMC-GenUnlocked VHMC-Runtime
5:41:26 (snpslmd) viewlogic        viewlogic_epic        VIEWLOGIC_NET
5:41:26 (snpslmd) VirSim                VIRTEX                VIRTEX2
5:41:26 (snpslmd) VIRTEX2P        VCSNativeCode        VCSNativeCode_Net
5:41:26 (snpslmd) VCSNativeCode_Node VCSOldPostProcDebugger_Net VCSOldPostProcDebugger_Node
5:41:26 (snpslmd) VCSParallelCompiler VCSParallelCompiler_Net VCSParallelCompiler_Node
5:41:26 (snpslmd) VCSParallelRuntime VCSParallelRuntime_Net VCSParallelRuntime_Node
5:41:26 (snpslmd) VCSParallelThread VCSParallelThread_Net VCSParallelThread_Node
5:41:26 (snpslmd) VCSPostProcDebugger VCSPostProcDebugger_Net VCSPostProcDebugger_Node
5:41:26 (snpslmd) VCSRuntime        VCSRuntime_Net        VCSRuntime_Node
5:41:26 (snpslmd) VCSRuntimeLimited VCSRuntimeLimited_Net VCSRuntimeLimited_Node
5:41:26 (snpslmd) VCSStd                VCSStd_Net        VCSStd_Node
5:41:26 (snpslmd) VCSTools        VCSTools_Net        VCSTools_Node
5:41:26 (snpslmd) VDesktop-Debug        VDesktop-GUI        VDesktop-VCDTrans
5:41:26 (snpslmd) VDesktop-Verilog VDesktop-VHDL        VEHICLE_ELECTRIC_LIB
5:41:26 (snpslmd) Vera                Ultra37000        VANTIS
5:41:26 (snpslmd) vcd2e                vcsace                VCSAMSCompiler
5:41:26 (snpslmd) VCSAMSCompiler_Net VCSAMSRuntime        VCSAMSRuntime_Net
5:41:26 (snpslmd) VCSCompile        VCSCompile_Net        VCSCompile_Node
5:41:26 (snpslmd) VCSCompiler        VCSCompiler_Net VCSCompiler_Node
5:41:26 (snpslmd) VCSDebugger        VCSDebugger_Net VCSDebugger_Node
5:41:26 (snpslmd) VCS-Express-Compile VCS-Express-Runtime VCSiCompile
5:41:26 (snpslmd) VCSiCompile_Net VCSiCompile_Node VCSiCompiler
5:41:26 (snpslmd) VCSiCompiler_Net VCSiCompiler_Node VCSiDebugger
5:41:26 (snpslmd) VCSiDebugger_Net VCSiDebugger_Node VCSiRuntime
5:41:26 (snpslmd) VCSiRuntime_Net VCSiRuntime_Net(3) VCSiRuntime_Node
5:41:26 (snpslmd) VCSiRuntimeLimited VCSlm_Hm        VCSlm_Hm_Net
5:41:26 (snpslmd) VCSlm_Hm_Node        Test-Mbist-Algorithm Test-Mbist-CAM
5:41:26 (snpslmd) Test-Mbist-Diagnosis Test-Mbist-DRAM Test-Mbist-FLASH
5:41:26 (snpslmd) Test-Mbist-Multiport Test-PR-1        Test-PR-2
5:41:26 (snpslmd) Test-PR-3        Test-PR-4        Test-RTL-Check
5:41:26 (snpslmd) Test-RTL-Tristate Test-ScanRoute        TestSim
5:41:26 (snpslmd) TestVE                tfm                timemill
5:41:26 (snpslmd) timemill/ace        timemill/av        timemill/bcx
5:41:26 (snpslmd) timemill/bdc        timemill/beta_status timemill/btm
5:41:26 (snpslmd) timemill/csx        timemill/internal_use timemill/msx
5:41:26 (snpslmd) timemill/nsaddon TimingAnalysis        TLM_Synthesis
5:41:26 (snpslmd) TRUE                tSchema                turboSchema
5:41:26 (snpslmd) turboState        turboTracer        TurboWave
5:41:26 (snpslmd) turbowave_epic        Test-BIST        Test-BSDL
5:41:26 (snpslmd) Test-CA                Test-CA-2        Test-CA-3
5:41:26 (snpslmd) Test-CA-4        Test-Compile        Test-Compile-Max
5:41:26 (snpslmd) Test-Compiler        Test-Compile-Remodel Test-Compiler-Plus
5:41:26 (snpslmd) Test-Compiler-Remodel Test-Compile-Share Test-Core-Integration
5:41:26 (snpslmd) Test-Core-Wrapper Test-CTL-Model        Test-Custom-Protocols
5:41:26 (snpslmd) Test-Delay        TestDesignCorrelation Test-DFTC-TMAX
5:41:26 (snpslmd) Test-DFT-Top        Test-Diagnosis        Test-Eval
5:41:26 (snpslmd) Test-Faultsim        Test-Faultsim-8L Test-Format
5:41:26 (snpslmd) Test-IDDQ        Test-IEEE-Std-1149-1 TESTIFY_NETLISTER
5:41:26 (snpslmd) testing                Test-LBIST-ATPG Test-LBIST-Synthesis
5:41:26 (snpslmd) Test-Library        TestManager        Test-Map
5:41:26 (snpslmd) Test-Mbist        SynLib-Seq        SynLib-VerilogSimMdl
5:41:26 (snpslmd) SynLib-VHDLSimMdl Synopsys        Synopsys-Queue
5:41:26 (snpslmd) Synopsys-Release TBM-Manager-UI        TBM-VSS-Check
5:41:26 (snpslmd) TBS                TC-Beta                TDL-Interface
5:41:26 (snpslmd) TDL-Reader        TDL-Writer        Tdx_all
5:41:26 (snpslmd) techviewer        Tecplot_all        TecplotSmall_all
5:41:26 (snpslmd) Ted_all                TedSmall_all        Test-Accelerator
5:41:26 (snpslmd) Test-Analysis        Test-Analysis-GUI Test-Analysis-RTL
5:41:26 (snpslmd) Test-ATPG        Test-ATPG-30        Test-ATPG-Limited
5:41:26 (snpslmd) Test-ATPG-Max        Test-ATPG-PRO        Test-ATPG-Ultra
5:41:26 (snpslmd) Test-ATPG-XP        Test-Beta        Test-Beta-2
5:41:26 (snpslmd) Test-Beta-3        Test-Beta-4        Test-Beta-5
5:41:26 (snpslmd) Test-Beta-6        stars_aryred        stars_cmi
5:41:26 (snpslmd) stars_csdf        stars_hsplnk        stars_ish
5:41:26 (snpslmd) stars_linred        stars_mr        stars_wsf
5:41:26 (snpslmd) starsim                starsimxt        start_aed
5:41:26 (snpslmd) start_analysis        start_bin        startime
5:41:26 (snpslmd) StarXtract        sup2lig_all        swb_all
5:41:26 (snpslmd) swb-advanced_all svisual_all        sx_cdslink
5:41:26 (snpslmd) sx_chip                sx_daiclink        sx_drc
5:41:26 (snpslmd) Sxtract_all        SYNARIO                SynLib-AdvMath
5:41:26 (snpslmd) SynLib-ALU        SynLib-Control        SynLib-DSPFIR
5:41:26 (snpslmd) SynLib-Eval        SynLib-FltTol        SynLib-PCIbasic
5:41:26 (snpslmd) Syn-Library-Compiler sprocessmpp_all sprocess-parallel_all
5:41:26 (snpslmd) sprocess-parallel4_all sptopography2d_all ST_LIBRARY
5:41:26 (snpslmd) Stamp-Compiler        STAR-DC                STAR-RC
5:41:26 (snpslmd) STAR-RC2-ANAL        STAR-RC2-ASCII        STAR-RC2-CLOCK
5:41:26 (snpslmd) STAR-RC2-GUI        STAR-RC-GUI        STAR-R-GUI
5:41:26 (snpslmd) stars_analog        SGE-Tool        SGE-Verilog-Interface
5:41:26 (snpslmd) SGE-VHDL-Interface ShortCut-DC-Expert ShortCut-DC-Pro
5:41:26 (snpslmd) Shortcut-FPGA        Siloti                Siloti_fe
5:41:26 (snpslmd) Siloti_o2        SilVE                SimVE
5:41:26 (snpslmd) simwave                simwave_epic        SKDB_Import
5:41:26 (snpslmd) SNPS-CSL        SNPS-Keygen        SNPS-MOTIVE
5:41:26 (snpslmd) SolarGAII        SolarII                sparallel_all
5:41:26 (snpslmd) SPARTAN                SPARTAN2        SPARTAN2E
5:41:26 (snpslmd) SPARTANXL        spcmcalib_all        spcmstd_all
5:41:26 (snpslmd) spice_explorer        sprocess_all        sprocess2d_all
5:41:26 (snpslmd) sprocess2dmc_all sprocess3d_all        sprocess3dmc_all
5:41:26 (snpslmd) sprocess-an-imp3d_all sprocesskmc_all sprocessmc_all
5:41:26 (snpslmd) SC-HLS                scratch                SC-RTL
5:41:26 (snpslmd) sda                sde_all                sde3d_all
5:41:26 (snpslmd) sdevcie-laser_all sdevice_all        sdevice-3d_all
5:41:26 (snpslmd) sdevice-densitygrad_all sdevice-ferro_all sdevice-floatinggate_all
5:41:26 (snpslmd) sdevice-gateleakage_all sdevice-hetero_all sdevice-hydro_all
5:41:26 (snpslmd) sdevice-kpgain_all sdevice-laser_all sdevice-led_all
5:41:26 (snpslmd) sdevice-mixedmode_all sdevicemonosemicond_all sdevice-montecarlo_all
5:41:26 (snpslmd) sdevice-noise_all sdevice-optic_all sdevice-parallel_all
5:41:26 (snpslmd) sdevice-parallel4_all sdevice-pmi_all sdevice-radiation_all
5:41:26 (snpslmd) sdevice-reliability_all sdevice-schroedinger_all sdevice-sige_all
5:41:26 (snpslmd) sdevice-thermo_all sdevice-traps_all sdevice-vectoroptic_all
5:41:26 (snpslmd) SEU                SGE-DC-Interface SGE-EDIF-Interface
5:41:26 (snpslmd) railmill/gbx        railmill/internal_use railmill/msx
5:41:26 (snpslmd) railmill/power        railmill/rvfp        railmill/snx
5:41:26 (snpslmd) railmill/spnx        railmill/ssnx        RCXTEO
5:41:26 (snpslmd) Reusner                rm_eee                route66
5:41:26 (snpslmd) RouteCompiler        rslv3d                rslv3dviewer
5:41:26 (snpslmd) RT54SXS                RTL-Analyzer        RTL-Analyzer-DAP
5:41:26 (snpslmd) RTL-Analyzer-Shell RTL-Analyzer-Shell-DAP RtlGateCorrelation
5:41:26 (snpslmd) RTL-Power-Analysis SABER_BUNDLE        SABER_DEV_MMP
5:41:26 (snpslmd) SABER_HARNESS        SABER_HARNESS_NETLISTER SABER_IF
5:41:26 (snpslmd) SABER_INTERFACE SABER_SCOPE        SABER_SCOPE_NETLIST
5:41:26 (snpslmd) SABER_SIMULATOR SABER_SKETCH        SABER_SKETCH_NETLIST
5:41:26 (snpslmd) SC-BC                SC-COSIM        SC-FPGA
5:41:26 (snpslmd) PPPRT                PrimeTime        PrimeTime_gui
5:41:26 (snpslmd) PrimeTime-Plus        PrimeTime-SI        prmspx_visual_all
5:41:26 (snpslmd) Prolyt_all        ProMA-L1        ProMA-L2
5:41:26 (snpslmd) ProMA-LD        ProMA-P1        ProMA-P2
5:41:26 (snpslmd) ProMA-PD        Protocol-Compiler-Analysis Protocol-Compiler-COutput
5:41:26 (snpslmd) Protocol-Compiler-FML Protocol-Compiler-Synth Protocol-Compiler-UI
5:41:26 (snpslmd) provhdl_checker PS_CTS                PS_Extraction
5:41:26 (snpslmd) PS_Noise_Optimization psf                PSG-SDE
5:41:26 (snpslmd) pwga                QLOGIC                Quantum38k
5:41:26 (snpslmd) rad                RailMacro        railmill
5:41:26 (snpslmd) railmill/ace        railmill/av        railmill/bcx
5:41:26 (snpslmd) railmill/beta_status PhysOpt-Extraction PhysOpt-GUI
5:41:26 (snpslmd) PhysOpt-Hierarchy PhysOpt-Onroute PhysOpt-Parallel
5:41:26 (snpslmd) PhysOpt-Route        PhysOpt-Route-TD PhysOpt-Routing
5:41:26 (snpslmd) PhysOpt-SI        PhysOpt-Ultra        PlanetPL
5:41:26 (snpslmd) PlanetRTL        pmga                polaris-cbs
5:41:26 (snpslmd) polaris-com        polaris-int        polaris-mt
5:41:26 (snpslmd) polaris-signalscan Power-Analysis        powerarc
5:41:26 (snpslmd) powergate        Power-Optimization Power-Optimization-Upgrade
5:41:26 (snpslmd) primerail_hsim        powrmill        powrmill/ace
5:41:26 (snpslmd) powrmill/av        powrmill/bcx        powrmill/beta_status
5:41:26 (snpslmd) powrmill/btm        powrmill/csx        powrmill/internal_use
5:41:26 (snpslmd) powrmill/msx        powrmill/nsaddon powrmill/power
5:41:26 (snpslmd) powrmill/svcz        powrmill/vlog_a nProp
5:41:26 (snpslmd) nSC                nSchema                nSchemaOnly
5:41:26 (snpslmd) nState                nTE                nTiming
5:41:26 (snpslmd) nTrace                nTree                nTX
5:41:26 (snpslmd) nWave                OPT_TEMPLATE_LIB OptimISE-DOE_all
5:41:26 (snpslmd) OptimISE-Iterative_all OptimISE-RSMOpt_all OptimISE-Statistical_all
5:41:26 (snpslmd) ORCA2A                ORCA2TB                ORCA3C
5:41:26 (snpslmd) ORCA3FPSC        ORCA3L                ORCA4E
5:41:26 (snpslmd) ParDiSo_all        Parse-Tree-Translator pathfinder
5:41:26 (snpslmd) pathmill        pathmill/cso        pathmill/ctx
5:41:26 (snpslmd) pathmill/dsx        pathmill/pfx        pathmill/sfx
5:41:26 (snpslmd) pathmill_plus        PC-Expert        PhysOpt
5:41:26 (snpslmd) PhysOpt-Beta        PhysOpt-ClockTree MWAPIaccess
5:41:26 (snpslmd) MWAPIdev        nAnalyzer        nanosim/ace
5:41:26 (snpslmd) nanosim/ace_cosim nanosim/av        nanosim/bcx
5:41:26 (snpslmd) nanosim/bdc        nanosim/beta_status nanosim/btm
5:41:26 (snpslmd) nanosim/gui        nanosim/internal_use nanosim/msx
5:41:26 (snpslmd) nanosim/postlayout_har nanosim/power        nanosim/vlog_a
5:41:26 (snpslmd) nBench                nClock                nCompare
5:41:26 (snpslmd) nECO                nESL                nlcc
5:41:26 (snpslmd) nLint                nLint_either        nLint_mixed
5:41:26 (snpslmd) nLint_sv        nLint_verilog        nLint_vhdl
5:41:26 (snpslmd) nMonitor        Noffset-2D_all        Noffset-3D_all
5:41:26 (snpslmd) Nova-ExploreRTL-Verilog npi                MC-Pro-RP
5:41:26 (snpslmd) MC-Retime        MDataCheck        MEMPRO
5:41:26 (snpslmd) MEMPRO-LIB        mentor/f        Mentor-Interface
5:41:26 (snpslmd) MERCURY                Mesh1D_all        Mesh2D_all
5:41:26 (snpslmd) Mesh3D_all        metawaves        metawaveswin
5:41:26 (snpslmd) mg_falcon_epic        MIF-Reader        MIF-Writer
5:41:26 (snpslmd) Milkyway-Interface Millennium-ATPG-EE Millennium-ATPG-STD
5:41:26 (snpslmd) Millennium-Beta Millennium-DRC        Millennium-Eval
5:41:26 (snpslmd) Millennium-FS        milltools        misc
5:41:26 (snpslmd) Mixed-Language        Mixed-Paradigm        MODEL_ENCRYPTION
5:41:26 (snpslmd) MODEL_SYNTHESIS MOTIVE-PrimeTime mti_epic
5:41:26 (snpslmd) MV-Astro-Opt        LigamentFE_all        LINYE
5:41:26 (snpslmd) LMCSwift        LMCSwift_Net        LSI-Interface
5:41:26 (snpslmd) lsim_parser        LSS4E                LTL-100
5:41:26 (snpslmd) LTL-100_CIF        MACH1                MACH2
5:41:26 (snpslmd) MACH4                MACH5                MAdv
5:41:26 (snpslmd) Mars                MAX3000A        MAX7000
5:41:26 (snpslmd) MAX7000A        MAX7000AE        MAX7000B
5:41:26 (snpslmd) MAX7000E        MAX7000S        MAX9000
5:41:26 (snpslmd) MCD                MCE                MCE-Base
5:41:26 (snpslmd) MCE-Eval        MCE-Lib-ALU        MCE-Lib-Arith1
5:41:26 (snpslmd) MCE-Lib-Arith2        MCE-Lib-Arith3        MCE-Lib-Logic
5:41:26 (snpslmd) MC-Pro                ispLSI5K        ispLSI6K
5:41:26 (snpslmd) ispLSI8K        ispMACH4000        JUAdvOptA
5:41:26 (snpslmd) JUAdvOptB        JUAOPAS                JUAPlan
5:41:26 (snpslmd) JUATime                JUAUD                JUClock
5:41:26 (snpslmd) JUDP                JUOPAS                Jupiter
5:41:26 (snpslmd) JupiterXT        JUPlan                JUTime
5:41:26 (snpslmd) JUUD                JUVS                Key-Generator
5:41:26 (snpslmd) Laker_AMS        Laker_iDRC        Laker_iLVS
5:41:26 (snpslmd) Laker_L1        Laker_L2        Laker_L3
5:41:26 (snpslmd) Laker_T1        Laker_T1_LE        Laker_Viewer
5:41:26 (snpslmd) Leakage-Power        leda_checker        leda_mx
5:41:26 (snpslmd) leda-mx                libarc                Library-Compiler
5:41:26 (snpslmd) Ligament_all        HLS-FPGA-SystemC HLS-SystemC
5:41:26 (snpslmd) hsim                hsim-cosim        hsim-xl
5:41:26 (snpslmd) hspice_adv        hspice_cosim        hspice_gui
5:41:26 (snpslmd) HSPICE_MODEL_LIBRARY hspice_mt        hspice_rf
5:41:26 (snpslmd) hspice_rf_char        hspicemt        hspicewin
5:41:26 (snpslmd) hspice-XO        hspicext        hsptest
5:41:26 (snpslmd) hspui                Hsp-vacomp        ICInteractive
5:41:26 (snpslmd) Inspect_all        Interface-Shell Interfise_all
5:41:26 (snpslmd) IQBUS_AUTHOR        IQBUS_LIB        IROI
5:41:26 (snpslmd) ISExtract_all        ispLSI1K        ispLSI2K
5:41:26 (snpslmd) ispLSI2KE        ispLSI3K        ispLSI5000S
5:41:26 (snpslmd) ispLSI5000SE        HERCULES_HLVS        HERCULES_HLVS-DEBUG
5:41:26 (snpslmd) HERCULES_HLVS-HTML HERCULES-DISTRIBUTED HERCULES-DISTRIBUTED-2
5:41:26 (snpslmd) HERCULES-DISTRIBUTED-24 HERCULES-DISTRIBUTED-24/2000.4 HERCULES-DISTRIBUTED-4
5:41:26 (snpslmd) HERCULES-FINDSHORT hicdr_test        hicdr_test/test1
5:41:26 (snpslmd) hicdr_test/test2 hicdr_test/test3 hicdr_test/test4
5:41:26 (snpslmd) hicdr_test/test5 hicdr_test/test6 hicdr_test/test7
5:41:26 (snpslmd) hicdr_test/test8 HighLevel-Power-Analysis HighLevel-Power-Optimization
5:41:26 (snpslmd) him_mb                him_mb_dsml        him_mod
5:41:26 (snpslmd) him_sml                Gsim_framework_basic Gsim_snapshot
5:41:26 (snpslmd) Gsim_wave        GuidedTraceAnalysis hd_foundation
5:41:26 (snpslmd) hd_pna                hd_special1        hd_special2
5:41:26 (snpslmd) hd_special3        hd_utils        HDL
5:41:26 (snpslmd) HDL2SC_mixed        HDL2SC_verilog        HDL2SC_vhdl
5:41:26 (snpslmd) HDL-Advisor        HDL-Advisor-Estimator HDL-Advisor-Estimator-Package
5:41:26 (snpslmd) HDL-Advisor-Package HDL-Advisor-Shell HDL-Advisor-Shell-Estimator
5:41:26 (snpslmd) HDL-Advisor-Shell-Estm-Package HDL-Advisor-Shell-Package HDL-Compiler
5:41:26 (snpslmd) hdlin                hdlin_mixed        hdlin_verilog
5:41:26 (snpslmd) hdlin_vhdl        HERCULES_HDRC        HERCULES_HDRC-HTML
5:41:26 (snpslmd) HERCULES_HERC-ADV HERCULES_HERC-BASIC FPGA-Library-Compiler
5:41:26 (snpslmd) FPGA-Option        FPGA-VHDL-Bundle FPPRT
5:41:26 (snpslmd) FPTA                FPTime                Fridge-GUI
5:41:26 (snpslmd) Fridge-Interpolator Fridge-Simulation FSM-Reader
5:41:26 (snpslmd) FSM-Writer        FusionVantageLmcInterface Gaia
5:41:26 (snpslmd) Galaxy-AdvCTS        Galaxy-AdvTech        Galaxy-Common
5:41:26 (snpslmd) Galaxy-DFT        Galaxy-DFY        Galaxy-FP
5:41:26 (snpslmd) Galaxy-ICC        Galaxy-IU        Galaxy-MV
5:41:26 (snpslmd) Galaxy-PNR        Galaxy-Power        Galaxy-Prototype
5:41:26 (snpslmd) Galaxy-PSYN        Gate2LayoutCorrelation Gate2RTLCorrelation
5:41:26 (snpslmd) gemini_hspice        GENERICVSP        GENESISe_all
5:41:26 (snpslmd) gentech                GRAPHICS_INTERFACE Gsim_dump_advance
5:41:26 (snpslmd) Gsim_dump_basic Gsim_framework_advance FPGA-Express-A42MX-Optimizer
5:41:26 (snpslmd) FPGA-Express-A54SX-Optimizer FPGA-Express-APEX2-Optimizer FPGA-Express-APROA-Optimizer
5:41:26 (snpslmd) FPGA-Express-Constraint-Mgr FPGA-Express-EP20k-Optimizer FPGA-Express-EPF10k-Optimizer
5:41:26 (snpslmd) FPGA-Express-EPF6k-Optimizer FPGA-Express-EPF8k-Optimizer FPGA-Express-EPM7k-Optimizer
5:41:26 (snpslmd) FPGA-Express-EPM9k-Optimizer FPGA-Express-GAT FPGA-Express-isp1K-Optimizer
5:41:26 (snpslmd) FPGA-Express-isp2K-Optimizer FPGA-Express-isp3K-Optimizer FPGA-Express-ISP4000-Optimizer
5:41:26 (snpslmd) FPGA-Express-isp4K-Optimizer FPGA-Express-ISP5000-Optimizer FPGA-Express-isp5K-Optimizer
5:41:26 (snpslmd) FPGA-Express-isp6K-Optimizer FPGA-Express-isp7K-Optimizer FPGA-Express-isp8K-Optimizer
5:41:26 (snpslmd) FPGA-Express-MERCURY-Optimizer FPGA-Express-Open-Optimizer FPGA-Express-ORCA2-Optimizer
5:41:26 (snpslmd) FPGA-Express-ORCA3-Optimizer FPGA-Express-Synario-Optimizer FPGA-Express-VHDL-Base
5:41:26 (snpslmd) FPGA-Express-VHDL-Training FPGA-Express-VIRTEX-Optimizer FPGA-Express-VLOG-Base
5:41:26 (snpslmd) FPGA-Express-XC3k-Optimizer FPGA-Express-XC4k-Optimizer FPGA-Express-XC5k-Optimizer
5:41:26 (snpslmd) FPGA-Express-XC9k-Optimizer FPGA-HDL-Bundle ficdr_test/tio
5:41:26 (snpslmd) FL_cosim_run        FL_ice_run        FL_multichip_partition
5:41:26 (snpslmd) FL_recalc        Flash370i        FLE_main
5:41:26 (snpslmd) FLEX10K                FLEX10KA        FLEX10KB
5:41:26 (snpslmd) FLEX10KE        FLEX6000        FLEX8000
5:41:26 (snpslmd) Floops-1D_all        Floops-1D-MC_all Floops-2D_all
5:41:26 (snpslmd) Floops-2D-MC_all Floops-3D_all        Floops-3D-MC_all
5:41:26 (snpslmd) Floops-Parallel_all Floops-Parallel4_all Floorplan-Management
5:41:26 (snpslmd) Formality        Formality-DV        Formality-E1
5:41:26 (snpslmd) Formality-TransForm Formality-Transit FPABP
5:41:26 (snpslmd) FPDP                FPGA_Express-APROA-Optimizer FPGA-Compiler
5:41:26 (snpslmd) FPGA-Express        FPGA-Express-32OODx-Optimizer FPGA-Express-A1200XL-Optimizer
5:41:26 (snpslmd) FPGA-Express-A1400-Optimizer FPGA-Express-A3200DX-Optimizer emw-uniform-2d_all
5:41:26 (snpslmd) emw-uniform-3d_all ENACE                ENACS
5:41:26 (snpslmd) encore                Enterprise        Equation-Reader
5:41:26 (snpslmd) Equation-Writer Espresso-Reader Espresso-Writer
5:41:26 (snpslmd) EssentialSignalAnalysis Estm-HDL-Advisor Estm-HDL-Advisor-Package
5:41:26 (snpslmd) etran                Eview                eX
5:41:26 (snpslmd) example_feature EXCALIBUR_ARM        EXCALIBUR_MIPS
5:41:26 (snpslmd) Extraction        FCII-Altera-Edition FCO
5:41:26 (snpslmd) features        ficdr_test        ficdr_test/gds
5:41:26 (snpslmd) ficdr_test/goa        ficdr_test/io        ficdr_test/nc
5:41:26 (snpslmd) ficdr_test/poly ficdr_test/size ficdr_test/sizeOr
5:41:26 (snpslmd) ficdr_test/stmp DW-IP-Consultant DW-IP-DEBUG
5:41:26 (snpslmd) DW-IP-Developer E5                E502
5:41:26 (snpslmd) E505                E520                Early-Access-Technology
5:41:26 (snpslmd) ECL-Compiler        ECO-Compiler        edif2e
5:41:26 (snpslmd) EDIF-Netlist-Read-DC EDIF-Netlist-Write-DC EDIF-Netlist-Writer
5:41:26 (snpslmd) EDIF-Reader        EDIF-Schematic-Writer electromigration_drc
5:41:26 (snpslmd) ELGRECO_Davis        ELGRECO_DesignCenter ELGRECO_Simulator
5:41:26 (snpslmd) Emlab_all        Emlab-Dessis_all Emlab-Farfield_all
5:41:26 (snpslmd) Emlab-Nonuniform-2D_all Emlab-Nonuniform-3D_all Emlab-Static_all
5:41:26 (snpslmd) Emlab-Thermal_all Emlab-Uniform-2D_all Emlab-Uniform-3D_all
5:41:26 (snpslmd) emw_all                emw-farfield_all emw-nonuniform-2d_all
5:41:26 (snpslmd) emw-nonuniform-3d_all emw-sdevice_all emw-static_all
5:41:26 (snpslmd) emw-thermal_all Dessis-Optic_all Dessis-Parallel_all
5:41:26 (snpslmd) Dessis-Parallel4_all Dessis-PMI_all        Dessis-Radiation_all
5:41:26 (snpslmd) Dessis-Reliability_all Dessis-Schroedinger_all Dessis-SiGe_all
5:41:26 (snpslmd) Dessis-Thermo_all Dessis-Traps_all Dessis-VectorOptic_all
5:41:26 (snpslmd) Devise_all        Devise-3D_all        Dfisetools_all
5:41:26 (snpslmd) Dfisetools-Topo_all Dios_all        Dios-3D_all
5:41:26 (snpslmd) Dios-MC_all        Dios-PDEF_all        Dios-SDO_all
5:41:26 (snpslmd) DiosSmall_all        Dip_all                DIRECTMEM
5:41:26 (snpslmd) DS-Schem-Gen        DS-Schem-Gen-Estimator-Pa DS-Schem-Gen-Estimator-Package
5:41:26 (snpslmd) DS-Schem-Gen-Package DS-Verinet        DS-Verinet-Estimator-Pack
5:41:26 (snpslmd) DS-Verinet-Estimator-Package DS-Verinet-Package DS-Vhdlnet
5:41:26 (snpslmd) DS-Vhdlnet-Estimator-Pack DS-Vhdlnet-Estimator-Package DS-Vhdlnet-Package
5:41:26 (snpslmd) DW-Developer        DesignWare-MPEG2 DesignWare-MPEG2-Source
5:41:26 (snpslmd) DesignWare-MPEG2-VDEC DesignWare-MPEG2-VDEC-Source DesignWare-MPEG-Source
5:41:26 (snpslmd) DesignWare-Package DesignWare-PCI        DesignWare-PCIbasic
5:41:26 (snpslmd) DesignWare-PCI-Source DesignWare-PCI-X DesignWare-PCI-X-Source
5:41:26 (snpslmd) DesignWare-SystemIO DesignWare-SystemIO-Source DesignWare-TCA
5:41:26 (snpslmd) DesignWare-TCA-Source DesignWare-USB        DesignWare-USB2
5:41:26 (snpslmd) DesignWare-USB2-Source DesignWare-USB-Source DesignWare-VERA
5:41:26 (snpslmd) Dessis_all        Dessis-3D_all        Dessis-BONSIM_all
5:41:26 (snpslmd) Dessis-DensityGrad_all Dessis-Ferro_all Dessis-FloatingGate_all
5:41:26 (snpslmd) Dessis-GateLeakage_all Dessis-Hetero_all Dessis-Hydro_all
5:41:26 (snpslmd) Dessis-kpGain_all Dessis-Laser_all Dessis-LED_all
5:41:26 (snpslmd) Dessis-MixedMode_all Dessis-Mono-Semicond_all Dessis-MonteCarlo_all
5:41:26 (snpslmd) Dessis-Noise_all Design-Budgeting Design-Compiler
5:41:26 (snpslmd) Design-Estimator Design-Estimator-FPI DesignSource
5:41:26 (snpslmd) DesignSource-Estimator-Package DesignSource-Package DesignTime
5:41:26 (snpslmd) Design-Vision        DesignWare        DesignWare-1394
5:41:26 (snpslmd) DesignWare-1394-Source DesignWare-6811-Source DesignWare-8051
5:41:26 (snpslmd) DesignWare-8051MCU DesignWare-8051-Source Designware-Basic
5:41:26 (snpslmd) DesignWare-BIST DesignWare-BIST-Source DesignWare-Cardbus
5:41:26 (snpslmd) Designware-Developer DesignWare-Developer-MGI DesignWare-ETHERNET-Source
5:41:26 (snpslmd) DesignWare-FloatingPoint DesignWare-Foundation DesignWare-Foundation-Exp
5:41:26 (snpslmd) DesignWare-Foundation-Expert DesignWare-Foundation-Power DesignWare-Foundation-Ultra
5:41:26 (snpslmd) Designware-FPGA-Basic DesignWare-ISA-PnP DesignWare-MemoryBist
5:41:26 (snpslmd) DesignWare-MemoryBist-Source DesignWare-MGI        DesignWare-MPEG
5:41:26 (snpslmd) Cyclone-Elaborator Cyclone-GUI        Cyclone-HDL-Analyzer
5:41:26 (snpslmd) Cyclone-Simulator Cyclone-VHDL-Analyzer CYPRESS
5:41:26 (snpslmd) DataExpansion        DataExpansionCoverage DataExpansionSim
5:41:26 (snpslmd) DATAIO                DataReplay        DataReplaySim
5:41:26 (snpslmd) DC64                DC-Beta                DC-Cadence-Interface
5:41:26 (snpslmd) DC-Expert        DCExpert-PrimeTime DC-Falcon-Interface
5:41:26 (snpslmd) DC-FPGA-Accelerator DC-FPGA-Add-On        DC-FPGA-Features
5:41:26 (snpslmd) DC-Layout-Interface DCM-Delay-Calculation DC-Min-Area-Retime
5:41:26 (snpslmd) DC-SDF-Interface DC-Ultra        DC-Ultra-Features
5:41:26 (snpslmd) DC-Ultra-Opt        DC-XG                Debussy
5:41:26 (snpslmd) Debussy_shared        delaymill        Delta39k
5:41:26 (snpslmd) DEMO                Design-Analyzer Design-Analyzer-DAP
5:41:26 (snpslmd) COSSAP_matlab        COSSAP_mfd        COSSAP_mpeg2
5:41:26 (snpslmd) COSSAP_pdc        COSSAP_qed        COSSAP_sds
5:41:26 (snpslmd) COSSAP_srcfd        COSSAP_vcg_generic COSSAP_vcg_synopsys
5:41:26 (snpslmd) COSSAP_vcg_vantage COSSAP_vdefcg        COSSAP_vdefcg_vlgxl
5:41:26 (snpslmd) COSSAP_vsiccg        COSSAP_vsiccg_cyc COSSAP_vsiccg_mti
5:41:26 (snpslmd) COSSAP_vsiccg_mtivlg COSSAP_vsiccg_vcs COSSAP_vsiccg_vlgxl
5:41:26 (snpslmd) COSSAP_vsivcg        COSSAP_vsivcg_vlgxl COSSAP_xdcg
5:41:26 (snpslmd) COSSAP_xvcg        COSSAP_xvsi        CoverMeter
5:41:26 (snpslmd) CoverMeterOBC        CoverMeterOBCVCSAMSCompiler CRS_COVERMETER
5:41:26 (snpslmd) CRS_VCM                CRS_VCS                CRS_VCSi
5:41:26 (snpslmd) CTV-Interface        CUSTOM_LIB        Cyclone-Code-Generator
5:41:26 (snpslmd) Cyclone-Core        Cyclone-cosim        COSSAP_cw_filter_sds
5:41:26 (snpslmd) COSSAP_dab        COSSAP_dcg_ad21020 COSSAP_dcg_ansic
5:41:26 (snpslmd) COSSAP_dcg_ariel32c COSSAP_dcg_fe        COSSAP_dcg_gc
5:41:26 (snpslmd) COSSAP_dcg_krc        COSSAP_dcg_lsic30s COSSAP_dcg_m96000
5:41:26 (snpslmd) COSSAP_dcg_mp        COSSAP_ddk_arm        COSSAP_ddk_devlp
5:41:26 (snpslmd) COSSAP_ddk_dsp16000 COSSAP_ddk_dsp1610 COSSAP_ddk_hawk
5:41:26 (snpslmd) COSSAP_ddk_nec        COSSAP_ddk_oak        COSSAP_ddk_pine
5:41:26 (snpslmd) COSSAP_ddk_ssp16xx COSSAP_ddk_tic5x COSSAP_ddk_tic5xx
5:41:26 (snpslmd) COSSAP_dect        COSSAP_dvb        COSSAP_ecc
5:41:26 (snpslmd) COSSAP_gsmdve        COSSAP_gsmdve_utils COSSAP_gsmefrsc
5:41:26 (snpslmd) COSSAP_gsmeq        COSSAP_gsmfrcc        COSSAP_gsmfrsc
5:41:26 (snpslmd) COSSAP_gsmhrcc        COSSAP_gsmhrsc        COSSAP_gsmphy
5:41:26 (snpslmd) COSSAP_is136        COSSAP_is95        CoCentric-SYS-Davis
5:41:26 (snpslmd) CoCentric-SYS-DesignCenter CoCentric-SYS-HWflow CoCentric-SYS-HWSimIF
5:41:26 (snpslmd) CoCentric-SYS-RDK-adsl CoCentric-SYS-RDK-cdma2000 CoCentric-SYS-RDK-docsis
5:41:26 (snpslmd) CoCentric-SYS-Simulator Columbia        ColumbiaTE
5:41:26 (snpslmd) COMPONENT_LIBRARY Constraint_Translation Converter
5:41:26 (snpslmd) COOLRUNNER        COOLRUNNER2        coreAssembler
5:41:26 (snpslmd) coreBuilder        coreConsultant        coremill
5:41:26 (snpslmd) coreSynthesis        COSIM-LFG        COSIM-MTI
5:41:26 (snpslmd) COSIM-NCV        COSIM-SRO        COSIM-VCS
5:41:26 (snpslmd) COSIM-VXL        COSSAP_adpcm        COSSAP_adsl
5:41:26 (snpslmd) COSSAP_amr        COSSAP_arm        COSSAP_bde
5:41:26 (snpslmd) COSSAP_celp        COSSAP_chart        COSSAP_cw_filter_hdl
5:41:26 (snpslmd) CBA-Logical-MA        CBA-Physical-DS CBA-Physical-MA
5:41:26 (snpslmd) CBA-Transport        CD-Compiled-Lib-Gen CD-Compiled-Sys-Gen
5:41:26 (snpslmd) CD-GDI                CD-GDII-Link        CD-Model-Developer
5:41:26 (snpslmd) CD-MSSC-Cross-Probe CD-MSSC-Netlist CD-Present-Builder
5:41:26 (snpslmd) CD-Present-Layer-Gen CD-REX                cdsaavmx
5:41:26 (snpslmd) cdsmetalib        cdsnet                CD-Vhdlgen-Gen
5:41:26 (snpslmd) CD-Vhdlgen-GUI        chipviewer        cmod
5:41:26 (snpslmd) cmod/ax                cmod/cbx        cmod/drc
5:41:26 (snpslmd) cmod/gx                cmod/gxadv        cmod/hdrc
5:41:26 (snpslmd) cmod/hlvs        cmod/ipc        cmod/lvs
5:41:26 (snpslmd) cmod/viewer        CmView                CoCentric-FXD-GUI
5:41:26 (snpslmd) CoCentric-FXD-Interpolator CoCentric-FXD-Simulation avanwaveswin
5:41:26 (snpslmd) awe_rcr                BC-FPGA                BC-FPGA-HDL
5:41:26 (snpslmd) BC-FPGA-VHDL        BC-HDL                BC-Schedule
5:41:26 (snpslmd) BC-VHDL                Behavioral-Analyzer Behavioral-Compiler
5:41:26 (snpslmd) BOA-BRT                c_exe_ax        c_exe_cbx
5:41:26 (snpslmd) c_exe_drc        c_exe_gx        c_exe_ipc
5:41:26 (snpslmd) c_exe_lvs        CA-Chip-Edit        CA-CP-Advanced
5:41:26 (snpslmd) CA-CP-Basic        CA-CP-Standard        cadence
5:41:26 (snpslmd) cadence_epic        CA-Foundation        CA-Frame
5:41:26 (snpslmd) CA-Hier-Timer        CA-Optimization CA-Timer
5:41:26 (snpslmd) CA-Utils        CBA-ApolloGA-Interface CBA-Blk-Export
5:41:26 (snpslmd) CBA-Blk-Import        CBA-CadenceSE-Interface CBA-DS-Beta
5:41:26 (snpslmd) CBA-Frame        CBA-Logical-DS        arc/ppx
5:41:26 (snpslmd) arc/pro                arc/r3x                arc1
5:41:26 (snpslmd) arc2                arcexpert        arcfc
5:41:26 (snpslmd) arcviewer        arcviewer/raph        arcxl
5:41:26 (snpslmd) ARKOS-A                ARKOS-B                ARKOS-C
5:41:26 (snpslmd) ARKOS-D                ARKOS-E                ARKOS-Ice
5:41:26 (snpslmd) ARKOS-Mcomp        ARKOS-Rtlcomp        ARKOS-Scomp
5:41:26 (snpslmd) ARKOS-Simul        ARM7TDMI        Astro
5:41:26 (snpslmd) AstroBeta        AstroExp        Astro-Express
5:41:26 (snpslmd) AstroGA                AstroRail        Astro-Rail
5:41:26 (snpslmd) AstroRailSA        AstroSpecialBeta AstroXtalk
5:41:26 (snpslmd) Astro-Xtalk        ATMEL                ATMWB_ATMLAYER
5:41:26 (snpslmd) ATMWB_UTOPIA        avanwaves        APACM
5:41:26 (snpslmd) APATD                APCS                APDP
5:41:26 (snpslmd) APEX20K                APEX20KC        APEX20KE
5:41:26 (snpslmd) APEXII                APGA4AP                APGACS
5:41:26 (snpslmd) APGADP                APGAHPO                APGApwr
5:41:26 (snpslmd) APGASolar        APGASolarII        APGATime
5:41:26 (snpslmd) APHPO                Apollo                ApolloGA
5:41:26 (snpslmd) APPower                APpwr                APSolar
5:41:26 (snpslmd) APSolarII        APTime                APXtalk
5:41:26 (snpslmd) arc                arc/bcx                arc/c2x
5:41:26 (snpslmd) arc/c3x                arc/cns                arc/dnx
5:41:26 (snpslmd) arc/dpx                arc/gds2        arc/giper
5:41:26 (snpslmd) arc/lefdef        A3200DX                A42MX
5:41:26 (snpslmd) A500K                A54SX                A54SXA
5:41:26 (snpslmd) A7                AARKOS-A        ace_core
5:41:26 (snpslmd) acega                acehdl                acehdl/beta_status
5:41:26 (snpslmd) acehdl/internal_use acehdl_beta        acehdl_gui
5:41:26 (snpslmd) ACEX1K                ACS                ACT2-1200XL
5:41:26 (snpslmd) ACT3                AdvanceCalibration_all AdvancedCalibration_all
5:41:26 (snpslmd) AIM_DEBUG        AIM_DECRYPT        AIM_DEVELOPER
5:41:26 (snpslmd) AIM_ENCRYPT        aiu_foundation        alien2lig_all
5:41:26 (snpslmd) ALTGEN1                ALTGEN2                amat-calib_all
5:41:26 (snpslmd) amga                amps                amps/cso
5:41:26 (snpslmd) amps/pfx        amps/tr                AN-Impl3D_all
5:41:26 (snpslmd) any_technology
5:41:26 (snpslmd)
5:41:26 (snpslmd) Licenses are case sensitive for TE_CATS
5:41:26 (snpslmd)
5:41:26 (snpslmd) EXTERNAL FILTERS are OFF
5:41:26 (lmgrd) snpslmd using TCP-port 60820
5:41:26 (snpslmd) Serving features for the following vendor names:
snpslmd  ACAD  adalmd  anagram  arcd  archprod  avantd  CADABRA  chrysalisd  cowared  EPIC  everest  extremed  hscd  innologd  ISE-TCADd  la_dmon  leda  magma  metasoftd  mwflexd  nassd  nsysnvs  numeritchd  pdld  riod  saber_dmn  sandwork  sigmacd  slat  snpsOEM1  snpsOEM2  snpsOEM3  snpsOEM4  snpsOEM5  snpsOEM6  snpsOEM7  snpsOEM8  snpsOEM9  ssilmd  synforad  synopsysd  synplctyd  TAVEREN  TE_CATS  tmald  vastlmd  vcsd
04/15/2022 05:41:27 (snpslmd) ------------------------------------------------------------------
04/15/2022 05:41:27 (snpslmd) Checking the integrity of the license file...
04/15/2022 05:41:31 (snpslmd) Dates out of range.
04/15/2022 05:41:31 (snpslmd) This feature is required to enable other keys in your license file.
04/15/2022 05:41:31 (snpslmd) All revenue keys ("SN=RK:..." on feature line) have been excluded.
04/15/2022 05:41:31 (snpslmd) ------------------------------------------------------------------
04/15/2022 05:41:33 (snpslmd) EXPIRATION WARNING: SSS                  2F94A6AFD422B9444E87 31-Dec-2020
求大神指教指教
发表于 2022-4-15 21:36:15 | 显示全部楼层
发表于 2022-4-15 21:37:32 | 显示全部楼层
 楼主| 发表于 2022-4-16 11:40:04 | 显示全部楼层
怎么解决呢,大佬,已经安装站里的内容修改到期日期至2030年了
发表于 2022-4-18 08:11:47 | 显示全部楼层
重新生成一个吧,在生成的过程中将31-dec-2020改成新的日期就可以。
发表于 2023-12-6 20:44:34 | 显示全部楼层
解决了吗
发表于 2023-12-19 14:40:28 | 显示全部楼层
请问有pkg吗?
GMT+8, 2025-12-22 17:10 , Processed in 0.021585 second(s), 4 queries , Gzip On, Redis On.
