查看: 5592|回复: 7
[解决] IC617数模混合仿真的解决办法
发表于 2022-4-1 15:57:03 | 显示全部楼层 |阅读模式
在cadence中进行AMS仿真的时候报错,原因如下:
irun: *E,SPCERR: The program encountered one or more errors while processing the input SPICE file(s) in the AMSD flow. For details, see the following messages.
amsspice: *Error: terminated with error code 127
TOOL: irun(64) 14.10-s014: Exiting on Mar 29, 2022 at 21:09:05 CST (total: 00:00:00)
如若出现以上错误,可能原因是(1)lib manager 中不存在connect.lib;(2)incisive中缺so文件
解决办法:(1)打开virtuoso目录下的cds.lib文件,手动添加:SOFTINCLUDE /opt/Cadence/Incisive14/tools.lnx86/affirma_ams/etc/connect_lib/cds.lib
                (2)在终端上运行命令:
                        cd  /lib64
                        ln  -s  libreadline.so.6  libreadline.so.5
                        cd  /usr/lib64
                        ln  -s  libhistory.so.6  libhistory.so.5
如果运行命令的时候显示Permission denied
解决办法:先运行su命令或者sudo命令,获得root权限,再输入上述命令
发表于 2023-4-17 17:47:31 | 显示全部楼层
赞赞赞
发表于 2024-2-19 08:11:30 | 显示全部楼层
牛牛牛
发表于 2024-8-14 16:17:53 | 显示全部楼层
谢谢分享!
发表于 2024-8-15 16:06:23 | 显示全部楼层
感谢
发表于 2024-11-18 18:32:58 | 显示全部楼层
兄弟我试了这两种都解决不了可能是啥原因呀。
*ERROR*: Error encountered while registering text designs in the configuration.
        Refer to the following messages and correct the errors.
xrun: *E,SPCERR: The program encountered one or more errors while processing the input SPICE file(s) in the AMSD flow. For details, see the following messages.
发表于 2025-4-7 21:47:50 | 显示全部楼层
*ERROR*: Error encountered while registering text designs ...
兄弟你解决了吗
发表于 5 天前 | 显示全部楼层
yjy123 发表于 2025-4-7 21:47
兄弟你解决了吗
file irun,看下incisive是64位还是32位,32位需安装对应32位的库
GMT+8, 2025-11-5 09:07 , Processed in 0.017409 second(s), 3 queries , Gzip On, Redis On.
