查看: 2536|回复: 2
[求助] 请问如何在Cadence IC618 layout的新增自己的菜单栏上,并且Skill脚本关联起来可以运用?
发表于 2022-2-28 14:51:54 | 显示全部楼层 |阅读模式
悬赏20资产未解决
请问如何在Cadence IC618 layout新增菜单栏并且可以关联Skill脚本运用?
发表于 2022-2-28 16:20:46 | 显示全部楼层
procedure( ddCreateLayoutPulldownMenu()
  if( boundp( 'ddLayoutPulldownMenu )
     then ddLayoutPulldownMenu
  else
    hiCreatePulldownMenu(
       "MenuName"  ; The munu name, U can named by your company name.
       list(
          hiCreateMenuItem( ; list of menu items
             ?name 'Item1
             ?itemText "Item1"
             ?callback   "println("Item One")"   ; Use you own function to define callback
             ?name 'Item2
             ?itemText "Item2"
             ?callback   "println("Item two")"
       ) ; list
    ) ; hiCreatePulldownMenu
  ) ; if
) ; procedure
procedure( ddUserPostInstallTrigger(args)
   hiInsertBannerMenu(
        args->window
        length( hiGetBannerMenus( args->window))
) ; procedure
;; Triggers for adding it to layout and VXL window
deRegUserTriggers("maskLayout" nil nil 'ddUserPostInstallTrigger)
deRegUserTriggers("maskLayoutXL" nil nil 'ddUserPostInstallTrigger)
;; Triggers for adding it to schematic window
deRegUserTriggers("schematic" nil nil 'ddUserPostInstallTrigger)
;; Trigger for adding it to schematic window in case of VXL mode
deRegUserTriggers( "schSynthesisXL" nil nil 'ddUserPostInstallTrigger)
发表于 2024-6-30 14:29:33 | 显示全部楼层
谢谢
GMT+8, 2025-12-13 06:35 , Processed in 0.013554 second(s), 4 queries , Gzip On, Redis On.
