查看: 1354|回复: 0
[招聘] 大厂 急招 MCU ASIC设计工程师 上海 北京
发表于 2022-2-24 13:41:10 | 显示全部楼层 |阅读模式
Staff ASIC Design Engineer (MCU)
JOB DESCRIPTION:
This position is for a digital-MCU design engineer to build next-gen automotive MCU chipsets.
As part of the MCU design team, the design engineer will mainly focus on following areas, but not limited to:
-Prepare micro-architecture specification for IP or subsystem design;
-Provide detailed technical documentation with specifications, block diagrams, and requirements to stakeholders
-RTL coding to verify against circuit implementation; Perform integration into MCUs.
- Module level Automotive functional safety related design and document
-Maintain the 3rd party IP from vendor and verify functions by creating test cases.
-Module level synthesize with sdc/upf; support chip level synthesis as IP owner.
-Assist with chip bring up and perform silicon/FPGA functional/performance validation.
-Assist with automotive functional safety (ISO26262) certification
-Define timing and power specifications and identify timing solutions.
-Assist with backend team on perform place-and-route and timing analysis of modules
JOB REQUIREMENTS:
- Master’s degree with at least 5 years’ experience in digital design;
- Proven track record for successful design of IC products in the past.
- Good background in C, Verilog, SystemVerilog and verification methodology.
- Knowledge and experience with Python/Tcl and Unix/Linux Makefile scripting strongly desired.
- A high-level of self-motivation and a proactive approach to solving problems.
- Familiar with AMBA AXI/AHB/APB spec.
- Familiar with the frontend ASIC design methodology/flow
Solid knowledge in one of the following areas is a plus:
-Knowledge of ARM cortex M or cortex R's MCU or SOC architecture;
-Knowledge of automotive function safety (ISO26262) design;
-Knowledge of security design;
-Knowledge of low power design;
-Knowledge or design experience of CAN_FD/LIN/USB/Ethernet/UFS/eMMC/EFALSH Controller;
企业优势
MCU产品线作为企业汽车电子芯片整体方案重要的产品线之一,设计世界领先的车用MCU芯片。车用MCU全球市场规模2020年预计会达到72亿美元,车用MCU芯片由于其高可靠性,高安全性一直作为芯片设计的制高点。企业在车规芯片设计上整合了较好的国内外的产业链,建立较好的汽车芯片设计平台,为车用MCU芯片设计打下较好的基础
上海,北京
联系方式: Mobile:18617135109  QQ:3434957652        WeChat:ivy13310878819
GMT+8, 2025-10-13 08:56 , Processed in 0.011771 second(s), 3 queries , Gzip On, Redis On.
