查看: 11783|回复: 38
Getting syn@psys tools newer than 2018 to properly work
发表于 2022-2-24 02:51:04 | 显示全部楼层 |阅读模式
It looks like there are still users who do not manage to get the most recent syn@psys tools (version newer than 2018.12) to properly work even after the great realease of the proper patcher (you can find it here https://bbs. eetop.cn/thread-879031-1-1.html). As a matter of fact, as explained in the "readme.txt" file found in the pubkey1.6 package, everything should go fairly smoothly by following the instructions but ... apparently not all the steps are included in the operation list !
Therefore, as done in the past for other tools, I decided to create a tutorial to succesfully apply the patch and create the license to finally clarify the complete procedure. The first 6 steps from the "readme.txt" are indeed correct:
  • [in linux box]Patch files. Goto your product directory (eg syn_vP-20yy.mm), run pubkey_verify -y
          - (where yy.mm indicates the year and the month, eg 20.12)
  • [in linux box]Patch files' checksum. Goto your product directory (e.g. syn_vP-20yy.mm), run synopsys_checksum -y
  • [in linux box]Repeat 1, 2 with all your $ynopsys , including the daemon scl_v2018.06 (or higher)
  • [in windows box]Generate license file(Synopsys.dat) with scl_keygen.exe
           - on first run this will generate the settings.ini file which you can edit to specify hostid and expiration date for the SSS feature
           - and the Synopsys.src file which includes the tools version (e.g., 2108.12) and the expiration date (31-dec-2020) on the INCREMENT lines and you have to
              modify those to match your tools and to set the desired expiration date (e.g., INCREMENT FEATURE_NAME snpslmd 2030.12 31-dec-2030 ...)
           - remember to add teh full path for the daemon line as: DAEMON snpslmd <full_path_to_daemon>/snplmd
  • [in windows box]Drap&drop the generated Synopsys.dat to fix.bat. This will add dummy SIGN= to the license file
  • Copy the license file to you linux box, and start the license daemon.
            - E.g. lmgrd -c <path_to_license_file>/license.dat
  • At this point the following unexpected message from the daemon may appear:
    (snpslmd) checking the integrity of the license file ...
    (snpslmd) The SSS features are garbled.
    (snpslmd) All revenue keys ("SN=RK:... " on feature line) have been excluded
    which will make your license file useless !!!
  • Luckily there is an easy solution: just reread the license with lmreread
            - Eg lmreread -c <path_to_license_file>/license.dat
    and all the features will be re-enable ad you will be all set !
Enjoy !
发表于 2022-2-24 14:23:44 | 显示全部楼层
Thanks a lot !!!
发表于 2022-2-24 14:37:45 | 显示全部楼层
thanks
发表于 2022-3-1 11:02:30 | 显示全部楼层
很奇怪,2019.06后的版本win license server 可以work,Linux不行。
发表于 2022-3-1 11:29:43 | 显示全部楼层
2019.03 之前的按照上面做法没问题。
发表于 2022-4-1 12:40:01 | 显示全部楼层
thank
发表于 2022-4-2 22:37:54 | 显示全部楼层
Thank you very much.
发表于 2023-1-9 16:36:52 | 显示全部楼层
thanks a lot
发表于 2023-1-16 16:56:47 | 显示全部楼层
这个步骤本身没问题
发表于 2023-3-4 20:41:54 | 显示全部楼层
有方法解决吗? 我就是 2018能起, 2019 起不来
点评
http://bbs.eetop.cn/thread-879031-1-1.html 这个页面删除了,大佬能分享下对应的patch 吗  发表于 2024-8-19 16:46
GMT+8, 2025-9-15 07:17 , Processed in 0.016910 second(s), 4 queries , Gzip On, Redis On.
