查看: 1848|回复: 7
[求助] 求个JSSC 2022年2月的合集
发表于 2022-2-7 09:54:21 | 显示全部楼层 |阅读模式
先行谢过了
发表于 2022-2-7 11:41:10 | 显示全部楼层
A_0.4-mA-Quiescent-Current_0.00091-THDN_Class-D_Audio_Amplifier_With_Low-Complex.pdf (5.46 MB , 下载次数: 8 )
A_0.45-THz_2-D_Scalable_Radiator_Array_With_28.2-dBm_EIRP_Using_an_Elliptical_Te.pdf (9.39 MB , 下载次数: 6 )
A_0.0285-mm2_0.68-pJ_bit_Single-Loop_Full-Rate_Bang-Bang_CDR_Without_Reference_a.pdf (12.8 MB , 下载次数: 9 )
A_1.73.6_GHz_20_MHz-Bandwidth_Channel-Selection_N-Path_Passive-LNA_Using_a_Switc.pdf (2.24 MB , 下载次数: 9 )
A_6-Gb_s_Inductively-Powered_Non-Contact_Connector_With_Rotatable_Transmission_L.pdf (6.91 MB , 下载次数: 7 )
A_12.5-GHz_Fractional-N_Type-I_Sampling_PLL_Achieving_58-fs_Integrated_Jitter.pdf (3.56 MB , 下载次数: 15 )
A_56-Gb_s_PAM-4_Receiver_Using_Time-Based_LSB_Decoder_and_S_H_Technique_for_Robu.pdf (5.69 MB , 下载次数: 5 )
A_510-pW_32-kHz_Crystal_Oscillator_With_High_Energy-to-Noise-Ratio_Pulse_Injection.pdf (5.61 MB , 下载次数: 9 )
A_Charge-Sharing_Locking_Technique_With_a_General_Phase_Noise_Theory_of_Injectio.pdf (4.23 MB , 下载次数: 10 )
A_Compact_0.20.3-V_Inverse-Class-F23_Oscillator_for_Low_1_f3_Noise_Over_Wide_Tun.pdf (5.86 MB , 下载次数: 7 )
A_High-Efficiency_142182-GHz_SiGe_BiCMOS_Power_Amplifier_With_Broadband_Slotline.pdf (12.92 MB , 下载次数: 8 )
A_Ka-Band_SATCOM_Transceiver_in_65-nm_CMOS_With_High-Linearity_TX_and_Dual-Chann.pdf (4.91 MB , 下载次数: 8 )
A_Low-Jitter_and_Low-Spur_Charge-Sampling_PLL.pdf (3.56 MB , 下载次数: 16 )
A_Method_for_Mitigation_of_Droop_Timing_Errors_Including_a_500_MHz_Droop_Detecto.pdf (5.15 MB , 下载次数: 6 )
A_Pipelined_Point_Cloud_Based_Neural_Network_Processor_for_3-D_Vision_With_Large.pdf (3.38 MB , 下载次数: 5 )
A_Wide-Lock-In-Range_and_Low-Jitter_1214.5_GHz_SSPLL_Using_a_Low-Power_Frequency.pdf (5.24 MB , 下载次数: 11 )
An_Eight-Element_140-GHz_Wafer-Scale_IF_Beamforming_Phased-Array_Receiver_With_6.pdf (6 MB , 下载次数: 8 )
An_Embedded_nand_Flash-Based_Compute-In-Memory_Array_Demonstrated_in_a_Standard_.pdf (5.37 MB , 下载次数: 6 )
An_ISI_Scrambling_Technique_for_Dynamic_Element_Matching_Current-Steering_DACs.pdf (2.27 MB , 下载次数: 9 )
Design_Margin_Reduction_Through_Completion_Detection_in_a_28-nm_Near-Threshold_D.pdf (3.84 MB , 下载次数: 5 )
Design_of_Sub-10-W_Sub-0.1_THD_Sinusoidal_Current_Generator_IC_for_Bio-Impedance.pdf (4.22 MB , 下载次数: 8 )
Design_Techniques_for_a_6.432-Gb_s_0.96-pJ_b_Continuous-Rate_CDR_With_Stochastic.pdf (3.33 MB , 下载次数: 7 )
Dual-Band_Two-Layer_Millimeter-Wave_Transceiver_for_Hybrid_MIMO_Systems.pdf (6.97 MB , 下载次数: 5 )
Erratum_to_A_Nonlinear_Receiver_Leveraging_Cascaded_Inverter-Based_Envelope-Bias.pdf (230.56 KB , 下载次数: 5 )
IEEE_JOURNAL_OF_SOLID-STATE_CIRCUITS.pdf (81.26 KB , 下载次数: 6 )
Information_For_Authors.pdf (80.39 KB , 下载次数: 4 )
SMIV_A_16-nm_25-mm_SoC_for_IoT_With_Arm_Cortex-A53_eFPGA_and_Coherent_Accelerators.pdf (3.48 MB , 下载次数: 5 )
Table_of_Contents (2).pdf (205.59 KB , 下载次数: 5 )
Table_of_Contents.pdf (169.76 KB , 下载次数: 4 )
TechRxiv_Share_Your_Preprint_Research_with_the_World.pdf (379.08 KB , 下载次数: 5 )
Two-Way_Transpose_Multibit_6T_SRAM_Computing-in-Memory_Macro_for_Inference-Train.pdf (8.23 MB , 下载次数: 7 )
 楼主| 发表于 2022-2-7 15:50:23 | 显示全部楼层
发表于 2022-2-7 17:17:29 | 显示全部楼层
thanks
发表于 2022-2-8 19:26:02 | 显示全部楼层
ganxie
发表于 2022-2-22 15:52:34 | 显示全部楼层
看看
发表于 2022-3-27 12:06:44 | 显示全部楼层
发表于 2022-3-28 20:45:50 | 显示全部楼层
thanks a lot !
GMT+8, 2025-12-25 10:25 , Processed in 0.022618 second(s), 5 queries , Gzip On, Redis On.
