查看: 2771|回复: 2
[Req] Siemens Oasys-RTL Synthesis
发表于 2022-2-2 10:27:37 | 显示全部楼层 |阅读模式
Oasys-RTL Synthesis
Oasys-RTL addresses the need for higher capacity, faster runtimes, improved QoR, and physical awareness by optimizing at a higher level of abstraction and using integrated floorplanning and placement capabilities.
Fast, High-Quality Physical RTL Synthesis
Oasys-RTL provides better quality of results by enabling physical accuracy, floorplanning, and fast optimization iterations to get to design closure on time.
LOW POWER
Power-Aware Synthesis
The power-aware synthesis capabilities include support for multi-threshold libraries, automatic clock gating, and UPF based Multi-VDD flow. During synthesis Oasys-RTL inserts all the appropriate level shifters, isolation cells and retention registers depending on the power intent as defined in the UPF.
RTL FLOORPLANNING
Create a Floorplan Directly From RTL
Oasys-RTL can create a floorplan directly from the design RTL using design dataflow and timing, power, area, and congestion constraints. It considers regions, fences, blockages and other physical guidance using the advanced floorplan editing tools and automatically places macros, pins, and pads.
HIGHEST QUALITY
Unique Placement-First Method
Rather than synthesizing first, then trying to optimize the gates, Oasys-RTL concurrently optimizes higher-level RTL partitions where it has a greater ability to converge on the best solution.
Home:
https://eda.sw.siemens.com/en-US/ic/oasys-rtl/
发表于 2023-7-2 11:55:08 | 显示全部楼层
anyone ?
发表于 2023-7-3 03:55:39 | 显示全部楼层
qq 1208629794
GMT+8, 2025-12-26 03:37 , Processed in 0.018553 second(s), 5 queries , Gzip On, Redis On.
