查看: 2536|回复: 2
[讨论] Tetramax patterns and images
发表于 2022-1-24 13:58:05 | 显示全部楼层 |阅读模式
I am doing ATPG for various fault models like stuck-at, at-speed, IDDQ
Q1: should I get a single pattern file for each fault model or there is a way to merge them in a single file and remove redundant patterns?
Q2: I generate an image file for later diagnosis on tester reports, should I also generate an image file for each fault
as it also contains DRC setting which kinda varies from one fault to another
eg >> in stuck At at-speed
--> add_pi_constraints 0 scan_enable
--> add_pi_constraints 0 reset
At at-fault, we don't add these constraints
Thanks in advance
发表于 2022-2-11 14:39:56 | 显示全部楼层
Usually different type of patterns need different test mode setup sequence. So
Q1&Q2: each pattern has its own pattern file and image.
 楼主| 发表于 2022-2-12 09:45:11 | 显示全部楼层
that's very helpful, thank you
GMT+8, 2025-12-22 05:58 , Processed in 0.012921 second(s), 3 queries , Gzip On, Redis On.
