查看: 2579|回复: 4
[原创] 检测50Ghz PAM4信号的最大峰值
发表于 2021-12-26 18:15:46 | 显示全部楼层 |阅读模式
检测50Ghz  PAM4信号的最大峰值,如何设计CMOS峰值检测电路
发表于 2021-12-26 21:53:04 | 显示全部楼层
just search papers. you can find many topos in the paper for optical communication.
 楼主| 发表于 2021-12-27 00:06:58 | 显示全部楼层
okk,thanks
发表于 2021-12-28 16:08:59 | 显示全部楼层
It's not easy to do this, if you want to detect the 50 GHz signal with good accuracy. Think in the frequency domain. You can try to detect at lower band if you use PRBS data.
 楼主| 发表于 2021-12-28 22:23:32 | 显示全部楼层
evlvu 发表于 2021-12-28 16:08
It's not easy to do this, if you want to detect the 50 GHz signal with good accuracy. Think in the f ...
50Ghz PAM4是甲方要求的input signal
GMT+8, 2025-12-19 00:32 , Processed in 0.017874 second(s), 4 queries , Gzip On, Redis On.
