查看: 31338|回复: 105
Synopsys EDA Tools docker image
发表于 2021-12-25 20:14:25 | 显示全部楼层 |阅读模式
bugfix: Formality SIGSEGV error with the version of K-2015.06-SP4, update to O-2018.06-SP1.  (2023-2-16)
Tool name
Version
Design Compiler
L-2016.03-SP1
VCS MX
O-2018.09-SP2-2
Verdi
O-2018.09-SP2-2
VC Static
O-2018.09-SP2-2
Formality
O-2018.06-SP1
Library Compiler
M-2016.12
PrimeTime
M-2016.12-SP1
IC Compiler
L-2016.03-SP1
HSPICE
L-2016.06-SP1
CustomExplorer
K-2015.06
License will expire on 30-dec-2030.
open terminal and run command:
docker run -it --hostname lizhen --mac-address 02:42:ac:11:00:02 phyzli/ubuntu18.04_xfce4_vnc4server_synopsys
It will pull the docker image automatically.
OOTB.
发表于 2021-12-26 00:11:42 | 显示全部楼层
谢谢分享
发表于 2021-12-26 01:50:55 | 显示全部楼层
感谢大佬一直维护这个docker
发表于 2021-12-26 06:38:47 | 显示全部楼层
Thank you for this. I have some questions. What OS is required for this? Does this command have to be run every time I want to run the tools? What is "OOTB"?
发表于 2021-12-26 15:04:30 | 显示全部楼层
Thanks
发表于 2021-12-27 10:38:01 来自手机 | 显示全部楼层
还有vc formal么?
 楼主| 发表于 2021-12-27 11:09:21 | 显示全部楼层
gliss6306 发表于 2021-12-26 06:38
Thank you for this. I have some questions. What OS is required for this? Does this command have to b ...
1. Docker is an application that uses the OS-level virtualization technique. You can install docker on many OS like Windows, Linux, and macOS. As long as you have docker installed, you can use the image. The image itself is built from ubuntu18.04.2. You need to learn how to use docker. Once you know how to use docker, you know the answer to this question.
3. "An out-of-the-box feature, particularly in software, is a feature or functionality of a product that works immediately after or even without any special installation without any configuration or modification." You just need to run the command, and all mentioned tools are available without any configuration.
发表于 2021-12-27 13:57:20 来自手机 | 显示全部楼层
谢谢分享
发表于 2021-12-27 14:10:37 | 显示全部楼层
在哪里
发表于 2021-12-27 22:44:40 | 显示全部楼层
安装好docker,用楼主的command就会自动下载了
GMT+8, 2025-9-15 19:57 , Processed in 0.016411 second(s), 3 queries , Gzip On, Redis On.
