查看: 4153|回复: 6
virtuoso启动ADE Explorer报错
发表于 2021-11-25 17:19:47 | 显示全部楼层 |阅读模式
新建matsero视图没问题,但是只要打开以后的视图就报错,错误如下:
*Error* eval: undefined function - _axlDebugprintf
*WARNING* (DEBASE-102079): A SKILL error occurred in function _axlDataTrigger
*WARNING* (DEBASE-102084): Data trigger for viewType maestro failed.
哪位大神知道解决方法吗?
发表于 2022-7-14 23:55:14 来自手机 | 显示全部楼层
Hi, I have same problem.  id you find the cause of this problem?
发表于 2022-7-15 00:14:46 来自手机 | 显示全部楼层
Hi, I have same problem ! Did you find the cause of this problem?
 楼主| 发表于 2022-7-15 08:32:04 | 显示全部楼层
是版本的问题,我这里运行130版本就有上述问题,升级到更高的版本就没问题了。
发表于 2022-7-15 22:30:08 | 显示全部楼层
Did you say 130 ?
My Virtuoso version é : IC6.1.8-64b-500.16
Could you explain better?
 楼主| 发表于 2022-7-16 09:12:31 | 显示全部楼层
leonard30 发表于 2022-7-15 22:30
Did you say 130 ?
my 160 version work well.
发表于 2022-7-18 23:58:16 来自手机 | 显示全部楼层
To me too work well. Problem happen when I try to create cell to simulation on ADE Explorer. I have created an op amp using gpdk v6.0 from Cadence. Could be the pdk, the problem ?
GMT+8, 2025-12-27 21:08 , Processed in 0.019229 second(s), 4 queries , Gzip On, Redis On.
