查看: 3560|回复: 6
vc-static启动报错求解
发表于 2021-11-22 11:15:45 | 显示全部楼层 |阅读模式
# vc_static_shell
                   VC Static UI Shell (vcst)
       Version: O-2018.09-SP2-2 for linux64 -- May 08, 2019
             Copyright (c) 2010-2019 by Synopsys, Inc.
This software and the associated documentation are confidential and
proprietary to Synopsys, Inc. Your use or disclosure of this software
is subject to the terms and conditions of a written license agreement
between you, or your company, and Synopsys, Inc.
Connect Error: Connection refused
[Error] (State:4) unable to connect ctrl/data sockets to VC Static Server. Exiting VC Static...
[Info] Ctrl channel connected: false
[Info] MSDU channel connected: false
[Info] SRC  channel connected: false
[Info] SQL  channel connected: false
license日志输出:11:09:33 (snpslmd) OUT: "VC-STATIC-COMPILE" root@server  [-7670825745167872893_1]
                         11:10:05 (snpslmd) IN: "VC-STATIC-COMPILE" root@server  [-7670825745167872893_1]
发表于 2021-12-2 02:21:26 | 显示全部楼层
您好,我也遇到类似的问题了,解决了吗? 谢谢啦
发表于 2021-12-2 11:35:16 来自手机 | 显示全部楼层
断网使用
发表于 2023-4-7 10:18:21 | 显示全部楼层
大佬,这个版本的安装包可以分享一波么
发表于 2024-6-3 10:32:12 | 显示全部楼层
这个问题怎么解决的?有大佬说下嘛
发表于 2024-6-3 19:33:20 | 显示全部楼层
在/etc/hosts中加入:127.0.0.1 hostname就可以了
发表于 2024-6-6 09:33:15 | 显示全部楼层
Thanks
GMT+8, 2025-12-4 06:15 , Processed in 0.015178 second(s), 3 queries , Gzip On, Redis On.
