查看: 4928|回复: 9
请教一个 ic complier 安装后出现的问题<Galaxy-Common+Galaxy-ICC is not enabled>
发表于 2021-10-26 11:11:21 | 显示全部楼层 |阅读模式
我最近试着在服务器上安装synopsys软件;系统是Cent OS Linux7的, 已经成功安装了:DC  FM   PT;    但在安装好ICC后,并设置好了环境变量;
在运行的时候出现以下问题:
bash-4.2# icc_shell
Fatal: Galaxy-Common+Galaxy-ICC is not enabled. (DCSH-1)
Exit IC Compiler!
请问一下,这是什么原因呢!
忘高手指教!!
我觉得不是license的问题吧,同一个license生成软件生成的license在另一台服务器上使用没问题,但是在这边就会遇到这个
发表于 2021-10-26 18:52:18 | 显示全部楼层
感觉很像lic问题,看一下lic的log文件
 楼主| 发表于 2021-10-26 18:59:47 | 显示全部楼层
bash-4.2# lmgrd_synopsys
10:45:51 (lmgrd) -----------------------------------------------
10:45:51 (lmgrd)   Please Note:
10:45:51 (lmgrd)
10:45:51 (lmgrd)   This log is intended for debug purposes only.
10:45:51 (lmgrd)   In order to capture accurate license
10:45:51 (lmgrd)   usage data into an organized repository,
10:45:51 (lmgrd)   please enable report logging. Use Flexera Software LLC's
10:45:51 (lmgrd)   software license administration  solution,
10:45:51 (lmgrd)   FlexNet Manager, to  readily gain visibility
10:45:51 (lmgrd)   into license usage data and to create
10:45:51 (lmgrd)   insightful reports on critical information like
10:45:51 (lmgrd)   license availability and usage. FlexNet Manager
10:45:51 (lmgrd)   can be fully automated to run these reports on
10:45:51 (lmgrd)   schedule and can be used to track license
10:45:51 (lmgrd)   servers and usage across a heterogeneous
10:45:51 (lmgrd)   network of servers including Windows NT, Linux
10:45:51 (lmgrd)   and UNIX.
10:45:51 (lmgrd)
10:45:51 (lmgrd)
10:45:51 (lmgrd)
10:45:51 (lmgrd) Server's System Date and Time: Tue Oct 26 2021 10:45:51 CST
10:45:51 (lmgrd) SLOG: Summary LOG statistics is enabled.
10:45:51 (lmgrd) The license server manager (lmgrd) running as root:
10:45:51 (lmgrd)         This is a potential security problem
10:45:51 (lmgrd)         and is not recommended.
bash-4.2# 10:45:51 (lmgrd) FlexNet Licensing (v11.14.1.3 build 212549 x64_lsb) started on local (linux) (10/26/2021)
10:45:51 (lmgrd) Copyright (c) 1988-2017 Flexera Software LLC. All Rights Reserved.
10:45:51 (lmgrd) World Wide Web:  http://www.flexerasoftware.com
10:45:51 (lmgrd) License file(s): /opt/sybop1/Synopsys.dat
10:45:51 (lmgrd) lmgrd tcp-port 27000
10:45:51 (lmgrd) (@lmgrd-SLOG@) ===============================================
10:45:51 (lmgrd) (@lmgrd-SLOG@) === LMGRD ===
10:45:51 (lmgrd) (@lmgrd-SLOG@) Start-Date: Tue Oct 26 2021 10:45:51 CST
10:45:51 (lmgrd) (@lmgrd-SLOG@) PID: 30809
10:45:51 (lmgrd) (@lmgrd-SLOG@) LMGRD Version: v11.14.1.3 build 212549 x64_lsb ( build 212549 (ipv6))
10:45:51 (lmgrd) (@lmgrd-SLOG@) === Network Info ===
10:45:51 (lmgrd) (@lmgrd-SLOG@) Listening port: 27000
10:45:51 (lmgrd) (@lmgrd-SLOG@) === Startup Info ===
10:45:51 (lmgrd) (@lmgrd-SLOG@) Server Configuration: Single Server
10:45:51 (lmgrd) (@lmgrd-SLOG@) Command-line options used at LS startup: -c /opt/sybop1/Synopsys.dat
10:45:51 (lmgrd) (@lmgrd-SLOG@) License file(s) used:  /opt/sybop1/Synopsys.dat
10:45:51 (lmgrd) Starting vendor daemons ...
10:45:51 (lmgrd) Started snpslmd (internet tcp_port 48068 pid 30810)
10:45:51 (snpslmd) FlexNet Licensing version v11.14.1.3 build 212549 x64_lsb
10/26/2021 10:45:51 (snpslmd) INFO: Pooling on VENDOR_STRING is Disabled (to enable, set SCL_POOL_VS=1)
10/26/2021 10:45:51 (snpslmd) Synopsys Corporate Licensing (SCL) Release: version SCL_2018.06
10/26/2021 10:45:52 (snpslmd) [SCL] File descriptor limit (soft, hard) for snpslmd: 4096, 4096
10/26/2021 10:45:52 (snpslmd) INFO: [SCL] TCP - tcp_keepalive_time - 7200 | tcp_keepalive_intvl - 75 | tcp_keepalive_probes - 9 | tcp_fin_timeout - 60
10:45:52 (snpslmd) SLOG: Summary LOG statistics is enabled.
10:45:52 (snpslmd) SLOG: FNPLS-INTERNAL-CKPT1
10:45:52 (snpslmd) SLOG: VM Status: 0
10:45:52 (snpslmd) Server started on local for:        SSS
10:45:52 (snpslmd) nanochar        hspice_pack        cosmos_other
10:45:52 (snpslmd) cxp                Synopsys_VCS_cmv Design-Expert
10:45:52 (snpslmd) him_mm_pi        CXp_GUI                CXp_Analysis
10:45:52 (snpslmd) CXp_CircuitEnvironment COSMOS_SCOPE        COSMOS_SCOPE
10:45:52 (snpslmd) CmMonitor        VCSiRuntimeLimited_Node VCSiRuntimeLimited_Net
10:45:52 (snpslmd) VMCCompiler_Node VMCRuntime_Node VMCEvaluation_Node
10:45:52 (snpslmd) VMCGeneratorUnlocked_Node VMCExpress_Compiler_Node VMCCompiler_Net
10:45:52 (snpslmd) VMCRuntime_Net        VMCEvaluation_Net VMCGeneratorUnlocked_Net
10:45:52 (snpslmd) VMCExpress_Compiler_Net LMCSwift_Node        SNPS-Assertions
10:45:52 (snpslmd) VT_SystemVerilog VCSMXRunTime_Net VCSMXiRunTime_Net
10:45:52 (snpslmd) Magellan-Sim        VT_SVAssertions VT_SVTestbench
10:45:52 (snpslmd) VT_NativeTestbench VT_DVE                VT_UCLI
10:45:52 (snpslmd) VT_LCA_Testbench PVCSCompiler_Net PVCSRuntime_Net
10:45:52 (snpslmd) VT_VCS_Power_Management VT_VCS_Checker        VT_VCS_Echo
10:45:52 (snpslmd) RMAN_RUN        VT_VCS_NTBE        XVVCDebugger
10:45:52 (snpslmd) VT_UnifiedCoverage VT_64Bit        VT_OtherTechnology
10:45:52 (snpslmd) VT_NativeTBDebuggerGui VT_CBUG                VT_SVAssertionCompiler
10:45:52 (snpslmd) VT_SDebug        VT_DVENTB        VT_Pioneer
10:45:52 (snpslmd) VT_SYSTEMC21        VT_LCA_Coverage VT_LCA_DEBUG
10:45:52 (snpslmd) VT_LCA_Assertions VT_LCA_MixedSignal VT_DVE_COV
10:45:52 (snpslmd) VT_VCS_Advanced_Features VT_VCS_BETA_Program VT_PVCSCompiler_Net
10:45:52 (snpslmd) DesignWare-ETHERNET DesignWare-ETHERNET Primepower
10:45:52 (snpslmd) Primepower        Primepower_gui        Primepower_gui
10:45:52 (snpslmd) fpc_foundation        fpc_pna                fpc_utils
10:45:52 (snpslmd) fpc_special1        fpc_special2        fpc_special3
10:45:52 (snpslmd) Test-Validate        Test-Accelerate-Max chiparch_migrate
10:45:52 (snpslmd) planet_migrate        DesignWare-ARMCORES-tlm DesignWare-AMBA-tlm
10:45:52 (snpslmd) Test-LBIST-Integration VHDL-Compiler-Presto primepower_vcd
10:45:52 (snpslmd) Test-Beta-7        Test-Beta-8        Test-Beta-9
10:45:52 (snpslmd) Test-STDVR        Test-MBIST-Integration HDL-Compiler-SystemVerilog
10:45:52 (snpslmd) primepower_beta MV-Opt                PhysOpt-VH
10:45:52 (snpslmd) Formality-TX        Formality-Distributed PhysOpt-Integration
10:45:52 (snpslmd) PhysOpt-Beta-Milkyway PhysOpt-Beta-SI PhysOpt-Beta-CTS
10:45:52 (snpslmd) PhysOpt-Beta-Route Test-Fault-Max        PAW
10:45:52 (snpslmd) PsynGui-ChipMap Formality-ESP        PhysOpt-XG
10:45:52 (snpslmd) PsynGui-AARender Test-Compression-ATPG Test-Compression-Synthesis
10:45:52 (snpslmd) HDL-Compiler-Old VHDL-Compiler-Old Test-Mbist-Program
10:45:52 (snpslmd) Test-Mbist-Bitstream Galileo                Galileo-PSYN
10:45:52 (snpslmd) Galileo-PnR        Galileo-GUI        NanoTime
10:45:52 (snpslmd) NanoTime-PathMill-Shared Galileo-Internal-Only PhysOpt-MV
10:45:52 (snpslmd) Astro-MV        Galaxy-GUI-PSYN Galaxy-GUI-PNR
10:45:52 (snpslmd) Galaxy-Beta        Galaxy-Internal-Only PrimeTime-New-Technology
10:45:52 (snpslmd) PrimeRail        Power-Optimization-Beta1 Power-Optimization-Beta2
10:45:52 (snpslmd) Formality-Beta1 Formality-Beta2 Galaxy-MCMM
10:45:52 (snpslmd) PrimeTime-PX        DB-Mode                DC-Topographical
10:45:52 (snpslmd) snps_fs_nwave        Pathmill-migrate Pathmill-plus-migrate
10:45:52 (snpslmd) NanoTime-ultra        Galaxy-CCS        Galaxy_FP_Beta
10:45:52 (snpslmd) Galaxy_MultiRoute4 Galaxy_MultiRoute8 PrimeTime-VX
10:45:52 (snpslmd) Galaxy-AdvRules Galaxy-FlipChip Galaxy-FP-Hier
10:45:52 (snpslmd) Test-SDD-Timing Galaxy-AdvOpt        Galaxy-CTMesh
10:45:52 (snpslmd) Galaxy-Zroute        Test-Power        Test-Physical
10:45:52 (snpslmd) DCT-Congestion        DCT-GUI                DC-Extension
10:45:52 (snpslmd) Galaxy-FP-MV        Galaxy-FP-AdvCTS Galaxy-FP-AdvTech
10:45:52 (snpslmd) NCX                Galaxy-SPG        PrimeTime-PX-Statistical
10:45:52 (snpslmd) PrimeTime-PX-New-Technology PrimeRail-New-Technology PrimeRail-static
10:45:52 (snpslmd) PrimeRail-adv        Test-CompressionPlus-Syn Test-CompressionPlus-ATPG
10:45:52 (snpslmd) NCX-addon        HERCULES_DEBUGGER HERCULES_DEBUGGER
10:45:52 (snpslmd) HERCULES_DEVICE HERCULES_DEVICE HERCULES_DRC
10:45:52 (snpslmd) HERCULES_DRC        HERCULES_ERC        HERCULES_ERC
10:45:52 (snpslmd) HERCULES_HLPE        HERCULES_HLPE        HERCULES_LVS
10:45:52 (snpslmd) HERCULES_LVS        HERCULES_MANAGER HERCULES_MANAGER
10:45:52 (snpslmd) HERCULES_MASK        HERCULES_MASK        HERCULES_RCE
10:45:52 (snpslmd) HERCULES_RCE        HERCULES_VUE        HERCULES_VUE
10:45:52 (snpslmd) LTL-100_GDS        LTL-100_GDS        LTL-100_NDW
10:45:52 (snpslmd) LTL-100_NDW        MDataPrep        MDataPrep
10:45:52 (snpslmd) MDynLink        MDynLink        MVerilog
10:45:52 (snpslmd) MVerilog        Milkyway        Milkyway
10:45:52 (snpslmd) NET-TRAN        NET-TRAN        STAR-ASCII
10:45:52 (snpslmd) STAR-ASCII        STAR-CR                STAR-CR
10:45:52 (snpslmd) STAR-EX                STAR-EX                STAR-EX_ERC
10:45:52 (snpslmd) STAR-EX_ERC        STAR-FILTER        STAR-FILTER
10:45:52 (snpslmd) STAR-GAZER        STAR-GAZER        STAR-LD2LTL
10:45:52 (snpslmd) STAR-LD2LTL        STAR-R                STAR-R
10:45:52 (snpslmd) STAR-RC2        STAR-RC2        STAR-RC2-AEO
10:45:52 (snpslmd) STAR-RC2-AEO        STAR-RC2-DB        STAR-RC2-DB
10:45:52 (snpslmd) STAR-RC2-DISTRIB10 STAR-RC2-DISTRIB10 STAR-RC2-NETLIST
10:45:52 (snpslmd) STAR-RC2-NETLIST STAR-RC2-PROBER STAR-RC2-PROBER
10:45:52 (snpslmd) STAR-RC2-TCAD        STAR-RC2-TCAD        STAR-RC2-VIEWER
10:45:52 (snpslmd) STAR-RC2-VIEWER STAR-RC2-XSTOR1 STAR-RC2-XSTOR1
10:45:52 (snpslmd) STAR-RC2-XSTOR2 STAR-RC2-XSTOR2 STAR-RC2-XTR-AEO
10:45:52 (snpslmd) STAR-RC2-XTR-AEO STAR-RC2-XTRACT STAR-RC2-XTRACT
10:45:52 (snpslmd) STAR-RC2_MANAGER STAR-RC2_MANAGER STAR-SYN2STAR
10:45:52 (snpslmd) STAR-SYN2STAR        STAR-TCAD        STAR-TCAD
10:45:52 (snpslmd) STAR-XREF        STAR-XREF        SynopsysCustomICCLink
10:45:52 (snpslmd) SynopsysCustomLayout SynopsysCustomSAE SynopsysCustomSAEBatch
10:45:52 (snpslmd) SynopsysCustomSDL SynopsysCustomSchematic cdsaawaves
10:45:52 (snpslmd) cdsaawaves        encrypt                encrypt
10:45:52 (snpslmd) fullhspice        hspice                hspice
10:45:52 (snpslmd) hspice3des        hspice3des        hspicecmidev
10:45:52 (snpslmd) hspicecmidev        hspicecmirt        hspicecmirt
10:45:52 (snpslmd) hspicerf        hspicerf        hspiceva
10:45:52 (snpslmd) hspiceva        metaencrypt3des metaencrypt3des
10:45:52 (snpslmd) nanosim                nanosim                ace_cosim
10:45:52 (snpslmd) simif                simif                simif
10:45:52 (snpslmd) spice_parser        spice_parser        sx_wva
10:45:52 (snpslmd) sx_wva                xsim                COSMOS_VO
10:45:52 (snpslmd) COSMOS_VO        CPI-100                CPI-100
10:45:52 (snpslmd) EV-ACCESS        EV-ACCESS        EV-ACCESS_UTIL
10:45:52 (snpslmd) EV-ACCESS_UTIL        Enterprise_VO        Enterprise_VO
10:45:52 (snpslmd) HERCULES-CRYPT_XREF_DATA HERCULES-CRYPT_XREF_DATA HERCULES-DP_MT
10:45:52 (snpslmd) HERCULES-DP_MT        HERCULES-EXPLORER_DRC HERCULES-EXPLORER_DRC
10:45:52 (snpslmd) HERCULES-EXPLORER_FILTERS HERCULES-EXPLORER_FILTERS HERCULES-EXPLORER_LVS
10:45:52 (snpslmd) HERCULES-EXPLORER_LVS HERCULES-NETLIST HERCULES-NETLIST
10:45:52 (snpslmd) HERCULES-RUN_TRAN HERCULES-RUN_TRAN MD
10:45:52 (snpslmd) S4                CKTSIMMC        FSPRO
10:45:52 (snpslmd) FSPRO2XSIM        CKTWAVE                svisual_all
10:45:52 (snpslmd) DC-FPGA-Add-On-to-DC DC-FPGA-Add-On-to-DC DESIGNWARE-AMBA-VIP
10:45:52 (snpslmd) DESIGNWARE-AMBA-VIP DESIGNWARE-I2C-VIP DESIGNWARE-I2C-VIP
10:45:52 (snpslmd) DESIGNWARE-REGRESSION DESIGNWARE-REGRESSION DESIGNWARE-SIO-VIP
10:45:52 (snpslmd) DESIGNWARE-SIO-VIP DESIGNWARE-VERIFICATION DESIGNWARE-VERIFICATION
10:45:52 (snpslmd) DWC-AHB-ICTL-Source DWC-AHB-ICTL-Source DWC-AHB-Source
10:45:52 (snpslmd) DWC-AHB-Source        DWC-AMBA-Fabric-Source DWC-AMBA-Fabric-Source
10:45:52 (snpslmd) DWC-APB-Advanced-Source DWC-APB-Advanced-Source DWC-APB-ICTL-Source
10:45:52 (snpslmd) DWC-APB-ICTL-Source DWC-APB-Periph-Source DWC-APB-Periph-Source
10:45:52 (snpslmd) DWC-DMA-Controller-Source DWC-DMA-Controller-Source DWC-DMAC-Source
10:45:52 (snpslmd) DWC-DMAC-Source DWC-GPIO-Source DWC-GPIO-Source
10:45:52 (snpslmd) DWC-I2C-Source        DWC-I2C-Source        DWC-INTC-CNTL-Source
10:45:52 (snpslmd) DWC-INTC-CNTL-Source DWC-MEMCTL-Source DWC-MEMCTL-Source
10:45:52 (snpslmd) DWC-RAP-Source        DWC-RAP-Source        DWC-RTC-Source
10:45:52 (snpslmd) DWC-RTC-Source        DWC-SSI-Source        DWC-SSI-Source
10:45:52 (snpslmd) DWC-TIMERS-Source DWC-TIMERS-Source DWC-UART-SRC
10:45:52 (snpslmd) DWC-UART-SRC        DWC-UART-Source DWC-UART-Source
10:45:52 (snpslmd) DWC-WDT-Source        DWC-WDT-Source        DesignWare-MEMCTL-Source
10:45:52 (snpslmd) DesignWare-MEMCTL-Source JupiterXT_VF        JupiterXT_VF
10:45:52 (snpslmd) SABER_GUIDE        SABER_GUIDE        VT_LCA_Language
10:45:52 (snpslmd) VT_LCA_Language VT_NTB                VT_NTB
10:45:52 (snpslmd) VT_SVDesign        VT_SVDesign        aPrv
10:45:52 (snpslmd) aPrv                aPrv                sharp
10:45:52 (snpslmd) sharp                VHDLAMS_TAURILI VHDLAMS_TAURI
10:45:52 (snpslmd) MODPEX_AWB        MODPEX_CTC        MODPEX_ELDO
10:45:52 (snpslmd) MODPEX_MARELLI        MODPEX_NOPOWER        MODPEX_PTFT
10:45:52 (snpslmd) MODPEX_SABER        MODPEX_STATIS        MODPEX_TVS
10:45:52 (snpslmd) MONTE_CARLO        MONTE_CARLO_MEMSSE MOS_TOOL
10:45:52 (snpslmd) MOS_TOOL_MEMSSE MOTOR_DCPM_TOOL MOTOR_DCPM_TOOL_MEMSSE
10:45:52 (snpslmd) OPT_TEMPLATE_LIB_MEMSSE PLACEHOLDER        PNET_LIBRARY
10:45:52 (snpslmd) PNEUM_HYD_PRG1        PNEU_HYD_LIBRARY POLARIS_SCOPE
10:45:52 (snpslmd) POLARIS_X        POWER_EXPRESS        SABER_SKETCH_NETLISTER
10:45:52 (snpslmd) SABER_SKETCH_NETLISTER_MEMSSE SABER_TSP        SABER_VERILOG_MM
10:45:52 (snpslmd) SABER_VERILOG_MM_MEMSSE SABER_VHDLAMS        SABER_VHDLAMS_MEMSSE
10:45:52 (snpslmd) SABER_VIEWSIM_MM SABER_VIEWSIM_MM_MEMSSE SCAN_TOOL
10:45:52 (snpslmd) SCAN_TOOL_MEMSSE SENSITIVITY        SENSITIVITY_MEMSSE
10:45:52 (snpslmd) SJCL_LIBRARY        SPECTRAL        SPECTRAL_MEMSSE
10:45:52 (snpslmd) STATEBENCH        STRESS                STRESS_MEMSSE
10:45:52 (snpslmd) SYMLIB                SYMLIB_JAPANESE SYMLIB_JAPANESE_MEMSSE
10:45:52 (snpslmd) SYMLIB_MEMSSE        SYMLIB_PLUS        SYMLIB_PLUS_MEMSSE
10:45:52 (snpslmd) SABERRT_ADI        SABERRT_ADI_MEMSSE SABERRT_AP2633
10:45:52 (snpslmd) SABERRT_FE        SABERRT_FE_MEMSSE SABERRT_HIL
10:45:52 (snpslmd) SABERRT_HIL_MEMSSE SABER_DEV_MM        SABER_GUIDE_MEMSSE
10:45:52 (snpslmd) SABER_INTERFACE_MEMSSE SABER_LEAPFROG_MM SABER_MODELSIM_MM
10:45:52 (snpslmd) SABER_MODELSIM_MM_MEMSSE SABER_MODELSIM_PLUS_MM SABER_MODELSIM_PLUS_MM_MEMSSE
10:45:52 (snpslmd) SABER_MODELSIM_VHDL_MM SABER_MODELSIM_VHDL_MM_MEMSSE SABER_MODELSIM_VLOG_MM
10:45:52 (snpslmd) SABER_PLUGNSIM_MM SABER_QSIM_MM        SABER_QVSPRO_MM
10:45:52 (snpslmd) SABER_RT_MM        SABER_RT_MM_MEMSSE SABER_RUNTIME
10:45:52 (snpslmd) SABER_SCOPE_MEMSSE SABER_SIMMATRIX_MM SABER_SIMULATOR_MEMSSE
10:45:52 (snpslmd) SABER_SKETCH_MEMSSE SYMLIB_POWER        SYMLIB_POWER_MEMSSE
10:45:52 (snpslmd) TESTIFY                TESTIFY_MEMSSE        TESTIFY_NETLISTER_MEMSSE
10:45:52 (snpslmd) THERM_TOOL        THERM_TOOL_MEMSSE TLU_TOOL
10:45:52 (snpslmd) TLU_TOOL_MEMSSE TR_ANALYSIS        TR_ANALYSIS_MEMSSE
10:45:52 (snpslmd) VEHICLE_ELECTRIC_LIB_MEMSSE VENDOR_LIBRARY        VENDOR_LIBRARY_MEMSSE
10:45:52 (snpslmd) VERIAS_HSPICE_COMPILER VERIAS_SIMULATOR VIEWLOGIC_FRAMEWAY
10:45:52 (snpslmd) VIEWLOGIC_FRAMEWAY_MEMSSE VIEWLOGIC_NET_MEMSSE WF_API_HSPICE
10:45:52 (snpslmd) WF_API_HSPICE_MEMSSE WF_API_MEMSSE        WF_API_STARSIM
10:45:52 (snpslmd) WF_API_STARSIM_MEMSSE EDIF_NETLISTER        EDIF_NETLISTER_MEMSSE
10:45:52 (snpslmd) EXPT_EDITOR        MAST_COMPILER        MEASURE
10:45:52 (snpslmd) MEASURE_MEMSSE        MEMS                MENTOR_FRAMEWAY
10:45:52 (snpslmd) MENTOR_FRAMEWAY_MEMSSE MENTOR_NETLISTER MENTOR_NETLISTER_MEMSSE
10:45:52 (snpslmd) MICROCOSM_LIB        MICROCOSM_LIB2        MICROCOSM_LIB2_MEMSSE
10:45:52 (snpslmd) MICROCOSM_LIB3        MICROCOSM_LIB3_MEMSSE MICROCOSM_LIB4
10:45:52 (snpslmd) MICROCOSM_LIB4_MEMSSE MICROCOSM_LIB5        MICROCOSM_LIB5_MEMSSE
10:45:52 (snpslmd) MICROCOSM_LIB6        MICROCOSM_LIB6_MEMSSE MICROCOSM_LIB7
10:45:52 (snpslmd) MICROCOSM_LIB7_MEMSSE MICROCOSM_LIB_MEMSSE MODEL_ARCHITECT
10:45:52 (snpslmd) MODEL_ENCRYPTION_MEMSSE MODEL_SYNTHESIS_MEMSSE MODPEX
10:45:52 (snpslmd) MODPEX_AQUEDUCT MODPEX_ASIM        MODPEX_ATFT
10:45:52 (snpslmd) HARNESS_CATIA        HARNESS_MCADREAD HARNESS_PROCABLE
10:45:52 (snpslmd) HARNESS_UNIGRAPHICS HSPICE_MODEL_LIBRARY_MEMSSE IC_DESIGN_LIB
10:45:52 (snpslmd) IMECH_LIBRARY        IQBUS_AUTHOR_MEMSSE IQBUS_DESIGNER
10:45:52 (snpslmd) IQBUS_LIB_MEMSSE LINK_MATLAB        LINK_MATLAB_MEMSSE
10:45:52 (snpslmd) LINK_XMATH        LOAD_TOOL        LOAD_TOOL_MEMSSE
10:45:52 (snpslmd) LSA_MEMSSE        LSA                LTX_LIBRARY
10:45:52 (snpslmd) COVENTOR_LIB10        COVENTOR_LIB10_MEMSSE COVENTOR_LIB11
10:45:52 (snpslmd) COVENTOR_LIB11_MEMSSE COVENTOR_LIB12        COVENTOR_LIB12_MEMSSE
10:45:52 (snpslmd) COVENTOR_LIB13        COVENTOR_LIB13_MEMSSE COVENTOR_LIB14
10:45:52 (snpslmd) COVENTOR_LIB14_MEMSSE COVENTOR_LIB15        COVENTOR_LIB15_MEMSSE
10:45:52 (snpslmd) COVENTOR_LIB8        COVENTOR_LIB8_MEMSSE COVENTOR_LIB9
10:45:52 (snpslmd) COVENTOR_LIB9_MEMSSE DESIGNSTAR        DESIGNSTAR_NET
10:45:52 (snpslmd) DIODE_TOOL        DIODE_TOOL_MEMSSE DRCYCLE_TOOL
10:45:52 (snpslmd) DRCYCLE_TOOL_MEMSSE ABB_CHCRC_LIBRARY AIM_DEBUG_MEMSSE
10:45:52 (snpslmd) AIM_DEVELOPER_MEMSSE AUT_NUMBER_MAJOR_PACKAGES BASIC_ANALYSES
10:45:52 (snpslmd) BASIC_ANALYSES_MEMSSE BATCH_MEASURE        BATCH_MEASURE_MEMSSE
10:45:52 (snpslmd) BATT_TOOL        BATT_TOOL_MEMSSE BETA_LIBRARY
10:45:52 (snpslmd) BUILD_DATE        BUILD_NUMBER        BUNDLE_MCAD_PROJECTION
10:45:52 (snpslmd) CADENCE_DIVA_NETLISTER CADENCE_FRAMEWAY CADENCE_FRAMEWAY_MEMSSE
10:45:52 (snpslmd) CADENCE_NETLISTER CADENCE_NETLISTER_MEMSSE COMPONENT_LIBRARY_MEMSSE
10:45:52 (snpslmd) CONCEPT_FRAMEWAY CONCEPT_NETLISTER CORENL_CHAR
10:45:52 (snpslmd) CORENL_CHAR_MEMSSE COSMOS_GUIDE        COSMOS_SKETCH
10:45:52 (snpslmd) COSMOS_SKETCH_BACK_ANN COSMOS_SKETCH_NETLISTER EXPT_EDITOR_MEMSSE
10:45:52 (snpslmd) EXPT_EDITOR_PLUS EXPT_EDITOR_PLUS_MEMSSE FAILURE_MODE
10:45:52 (snpslmd) FAILURE_MODE_MEMSSE FASTPARTS        FUSE_CHAR
10:45:52 (snpslmd) FUSE_CHAR_MEMSSE XC4000E                XC4000EX
10:45:52 (snpslmd) XC4000L                XC4000XL        XC4000XLA
10:45:52 (snpslmd) XC4000XV        XC5200                XC9500
10:45:52 (snpslmd) XC9500XL        XC9500XV        xp
10:45:52 (snpslmd) XVCSDebugger        XVCSiDebugger        VSS-CompiledSim
10:45:52 (snpslmd) VSS-Debugger        VSS-Falcon-Interface VSS-GateSim
10:45:52 (snpslmd) VSS-LAI-Models        VSS-Lib-Tools        VSS-LMSI
10:45:52 (snpslmd) VSS-Model-Developer VSS-NEC-Tran        VSS-SDF-Interface
10:45:52 (snpslmd) VSS-SGE-Tool        VSS-Simulator        VSS-SmartModels
10:45:52 (snpslmd) VSS-SPC                VSS-Tran        VSS-Utilities
10:45:52 (snpslmd) VSS-Verilog-PLI VSS-VIP-Interface VSS-Wave-Display
10:45:52 (snpslmd) VSS-XP-Accelerator VT_AssertionIP        VT_Assertions
10:45:52 (snpslmd) VT_AssertionsRuntime VT_Coverage        VT_CoverageRuntime
10:45:52 (snpslmd) VT_CoverageURG        VT_Testbench        VT_TestbenchRuntime
10:45:52 (snpslmd) VT_VCS_BETA_Features VT_VCS_LCA_Features VT_Visual
10:45:52 (snpslmd) vtran                WhatIfAnalysis        WRITE
10:45:52 (snpslmd) XC3000                XC4000                VIRTEXE
10:45:52 (snpslmd) VIRTEXEA        Vivace-Code-Generator Vivace-Core
10:45:52 (snpslmd) Vivace-Debug        Vivace-Elaborator Vivace-Expert
10:45:52 (snpslmd) Vivace-Express        Vivace-GUI        Vivace-HDL-Analyzer
10:45:52 (snpslmd) Vivace-Model-Compiler Vivace-Pro        Vivace-Simulator
10:45:52 (snpslmd) Vivace-VHDL-Analyzer vlog_epic_pif        vlog2e
10:45:52 (snpslmd) vlsi2000        vlsi500                VMCCompiler
10:45:52 (snpslmd) VMCCore                VMCEvaluation        VMCExpress_Compiler
10:45:52 (snpslmd) VMCGeneratorUnlocked VMCRuntime        VPC
10:45:52 (snpslmd) vsea-calib_all        VSP_DRIVER        VSS-Analyzer
10:45:52 (snpslmd) VSS-Backplane        VSS-Cadence-Interface VSS-CLI
10:45:52 (snpslmd) vera_comp        vera_debug        vera_ip
10:45:52 (snpslmd) vera_rtime        Verdi                Verification-Token
10:45:52 (snpslmd) Verilog                verilog_writer        Verilog-Netlist-Writer
10:45:52 (snpslmd) Verilog-Parser        Verilog-To-BE        Verilog-VirSim
10:45:52 (snpslmd) vertue                vhdl_compiler        VHDL-Analyzer
10:45:52 (snpslmd) VHDL-Compiler        VHDL-Cycle-Sim        VHDL-Elaborator
10:45:52 (snpslmd) VHDL-Event-Sim        VHDLi-Elaborator VHDLi-Event-Sim
10:45:52 (snpslmd) VHDL-Netlist-Writer VHDL-ScSim        VHDL-To-BE
10:45:52 (snpslmd) VHDL-Tools        VHDL-VirSim        VHMC-Eval
10:45:52 (snpslmd) VHMC-GenUnlocked VHMC-Runtime        viewlogic
10:45:52 (snpslmd) viewlogic_epic        VIEWLOGIC_NET        VirSim
10:45:52 (snpslmd) VIRTEX                VIRTEX2                VIRTEX2P
10:45:52 (snpslmd) VCSNativeCode        VCSNativeCode_Net VCSNativeCode_Node
10:45:52 (snpslmd) VCSOldPostProcDebugger_Net VCSOldPostProcDebugger_Node VCSParallelCompiler
10:45:52 (snpslmd) VCSParallelCompiler_Net VCSParallelCompiler_Node VCSParallelRuntime
10:45:52 (snpslmd) VCSParallelRuntime_Net VCSParallelRuntime_Node VCSParallelThread
10:45:52 (snpslmd) VCSParallelThread_Net VCSParallelThread_Node VCSPostProcDebugger
10:45:52 (snpslmd) VCSPostProcDebugger_Net VCSPostProcDebugger_Node VCSRuntime
10:45:52 (snpslmd) VCSRuntime_Net        VCSRuntime_Node VCSRuntimeLimited
10:45:52 (snpslmd) VCSRuntimeLimited_Net VCSRuntimeLimited_Node VCSStd
10:45:52 (snpslmd) VCSStd_Net        VCSStd_Node        VCSTools
10:45:52 (snpslmd) VCSTools_Net        VCSTools_Node        VDesktop-Debug
10:45:52 (snpslmd) VDesktop-GUI        VDesktop-VCDTrans VDesktop-Verilog
10:45:52 (snpslmd) VDesktop-VHDL        VEHICLE_ELECTRIC_LIB Vera
10:45:52 (snpslmd) Ultra37000        VANTIS                vcd2e
10:45:52 (snpslmd) vcsace                VCSAMSCompiler        VCSAMSCompiler_Net
10:45:52 (snpslmd) VCSAMSRuntime        VCSAMSRuntime_Net VCSCompile
10:45:52 (snpslmd) VCSCompile_Net        VCSCompile_Node VCSCompiler
10:45:52 (snpslmd) VCSCompiler_Net VCSCompiler_Node VCSDebugger
10:45:52 (snpslmd) VCSDebugger_Net VCSDebugger_Node VCS-Express-Compile
10:45:52 (snpslmd) VCS-Express-Runtime VCSiCompile        VCSiCompile_Net
10:45:52 (snpslmd) VCSiCompile_Node VCSiCompiler        VCSiCompiler_Net
10:45:52 (snpslmd) VCSiCompiler_Node VCSiDebugger        VCSiDebugger_Net
10:45:52 (snpslmd) VCSiDebugger_Node VCSiRuntime        VCSiRuntime_Net
10:45:52 (snpslmd) VCSiRuntime_Net(3) VCSiRuntime_Node VCSiRuntimeLimited
10:45:52 (snpslmd) VCSlm_Hm        VCSlm_Hm_Net        VCSlm_Hm_Node
10:45:52 (snpslmd) Test-Mbist-Algorithm Test-Mbist-CAM        Test-Mbist-Diagnosis
10:45:52 (snpslmd) Test-Mbist-DRAM Test-Mbist-FLASH Test-Mbist-Multiport
10:45:52 (snpslmd) Test-PR-1        Test-PR-2        Test-PR-3
10:45:52 (snpslmd) Test-PR-4        Test-RTL-Check        Test-RTL-Tristate
10:45:52 (snpslmd) Test-ScanRoute        TestSim                TestVE
10:45:52 (snpslmd) tfm                timemill        timemill/ace
10:45:52 (snpslmd) timemill/av        timemill/bcx        timemill/bdc
10:45:52 (snpslmd) timemill/beta_status timemill/btm        timemill/csx
10:45:52 (snpslmd) timemill/internal_use timemill/msx        timemill/nsaddon
10:45:52 (snpslmd) TimingAnalysis        TLM_Synthesis        TRUE
10:45:52 (snpslmd) tSchema                turboSchema        turboState
10:45:52 (snpslmd) turboTracer        TurboWave        turbowave_epic
10:45:52 (snpslmd) Test-BIST        Test-BSDL        Test-CA
10:45:52 (snpslmd) Test-CA-2        Test-CA-3        Test-CA-4
10:45:52 (snpslmd) Test-Compile        Test-Compile-Max Test-Compiler
10:45:52 (snpslmd) Test-Compile-Remodel Test-Compiler-Plus Test-Compiler-Remodel
10:45:52 (snpslmd) Test-Compile-Share Test-Core-Integration Test-Core-Wrapper
10:45:52 (snpslmd) Test-CTL-Model        Test-Custom-Protocols Test-Delay
10:45:52 (snpslmd) TestDesignCorrelation Test-DFTC-TMAX        Test-DFT-Top
10:45:52 (snpslmd) Test-Diagnosis        Test-Eval        Test-Faultsim
10:45:52 (snpslmd) Test-Faultsim-8L Test-Format        Test-IDDQ
10:45:52 (snpslmd) Test-IEEE-Std-1149-1 TESTIFY_NETLISTER testing
10:45:52 (snpslmd) Test-LBIST-ATPG Test-LBIST-Synthesis Test-Library
10:45:52 (snpslmd) TestManager        Test-Map        Test-Mbist
10:45:52 (snpslmd) SynLib-Seq        SynLib-VerilogSimMdl SynLib-VHDLSimMdl
10:45:52 (snpslmd) Synopsys        Synopsys-Queue        Synopsys-Release
10:45:52 (snpslmd) TBM-Manager-UI        TBM-VSS-Check        TBS
10:45:52 (snpslmd) TC-Beta                TDL-Interface        TDL-Reader
10:45:52 (snpslmd) TDL-Writer        Tdx_all                techviewer
10:45:52 (snpslmd) Tecplot_all        TecplotSmall_all Ted_all
10:45:52 (snpslmd) TedSmall_all        Test-Accelerator Test-Analysis
10:45:52 (snpslmd) Test-Analysis-GUI Test-Analysis-RTL Test-ATPG
10:45:52 (snpslmd) Test-ATPG-30        Test-ATPG-Limited Test-ATPG-Max
10:45:52 (snpslmd) Test-ATPG-PRO        Test-ATPG-Ultra Test-ATPG-XP
10:45:52 (snpslmd) Test-Beta        Test-Beta-2        Test-Beta-3
10:45:52 (snpslmd) Test-Beta-4        Test-Beta-5        Test-Beta-6
10:45:52 (snpslmd) stars_aryred        stars_cmi        stars_csdf
10:45:52 (snpslmd) stars_hsplnk        stars_ish        stars_linred
10:45:52 (snpslmd) stars_mr        stars_wsf        starsim
10:45:52 (snpslmd) starsimxt        start_aed        start_analysis
10:45:52 (snpslmd) start_bin        startime        StarXtract
10:45:52 (snpslmd) sup2lig_all        swb_all                swb-advanced_all
10:45:52 (snpslmd) sx_cdslink        sx_chip                sx_daiclink
10:45:52 (snpslmd) sx_drc                Sxtract_all        SYNARIO
10:45:52 (snpslmd) SynLib-AdvMath        SynLib-ALU        SynLib-Control
10:45:52 (snpslmd) SynLib-DSPFIR        SynLib-Eval        SynLib-FltTol
10:45:52 (snpslmd) SynLib-PCIbasic Syn-Library-Compiler sprocessmpp_all
10:45:52 (snpslmd) sprocess-parallel_all sprocess-parallel4_all sptopography2d_all
10:45:52 (snpslmd) ST_LIBRARY        Stamp-Compiler        STAR-DC
10:45:52 (snpslmd) STAR-RC                STAR-RC2-ANAL        STAR-RC2-ASCII
10:45:52 (snpslmd) STAR-RC2-CLOCK        STAR-RC2-GUI        STAR-RC-GUI
10:45:52 (snpslmd) STAR-R-GUI        stars_analog        SGE-Tool
10:45:52 (snpslmd) SGE-Verilog-Interface SGE-VHDL-Interface ShortCut-DC-Expert
10:45:52 (snpslmd) ShortCut-DC-Pro Shortcut-FPGA        Siloti
10:45:52 (snpslmd) Siloti_fe        Siloti_o2        SilVE
10:45:52 (snpslmd) SimVE                simwave                simwave_epic
10:45:52 (snpslmd) SKDB_Import        SNPS-CSL        SNPS-Keygen
10:45:52 (snpslmd) SNPS-MOTIVE        SolarGAII        SolarII
10:45:52 (snpslmd) sparallel_all        SPARTAN                SPARTAN2
10:45:52 (snpslmd) SPARTAN2E        SPARTANXL        spcmcalib_all
10:45:52 (snpslmd) spcmstd_all        spice_explorer        sprocess_all
10:45:52 (snpslmd) sprocess2d_all        sprocess2dmc_all sprocess3d_all
10:45:52 (snpslmd) sprocess3dmc_all sprocess-an-imp3d_all sprocesskmc_all
10:45:52 (snpslmd) sprocessmc_all        SC-HLS                scratch
10:45:52 (snpslmd) SC-RTL                sda                sde_all
10:45:52 (snpslmd) sde3d_all        sdevcie-laser_all sdevice_all
10:45:52 (snpslmd) sdevice-3d_all        sdevice-densitygrad_all sdevice-ferro_all
10:45:52 (snpslmd) sdevice-floatinggate_all sdevice-gateleakage_all sdevice-hetero_all
10:45:52 (snpslmd) sdevice-hydro_all sdevice-kpgain_all sdevice-laser_all
10:45:52 (snpslmd) sdevice-led_all sdevice-mixedmode_all sdevicemonosemicond_all
10:45:52 (snpslmd) sdevice-montecarlo_all sdevice-noise_all sdevice-optic_all
10:45:52 (snpslmd) sdevice-parallel_all sdevice-parallel4_all sdevice-pmi_all
10:45:52 (snpslmd) sdevice-radiation_all sdevice-reliability_all sdevice-schroedinger_all
10:45:52 (snpslmd) sdevice-sige_all sdevice-thermo_all sdevice-traps_all
10:45:52 (snpslmd) sdevice-vectoroptic_all SEU                SGE-DC-Interface
10:45:52 (snpslmd) SGE-EDIF-Interface railmill/gbx        railmill/internal_use
10:45:52 (snpslmd) railmill/msx        railmill/power        railmill/rvfp
10:45:52 (snpslmd) railmill/snx        railmill/spnx        railmill/ssnx
10:45:52 (snpslmd) RCXTEO                Reusner                rm_eee
10:45:52 (snpslmd) route66                RouteCompiler        rslv3d
10:45:52 (snpslmd) rslv3dviewer        RT54SXS                RTL-Analyzer
10:45:52 (snpslmd) RTL-Analyzer-DAP RTL-Analyzer-Shell RTL-Analyzer-Shell-DAP
10:45:52 (snpslmd) RtlGateCorrelation RTL-Power-Analysis SABER_BUNDLE
10:45:52 (snpslmd) SABER_DEV_MMP        SABER_HARNESS        SABER_HARNESS_NETLISTER
10:45:52 (snpslmd) SABER_IF        SABER_INTERFACE SABER_SCOPE
10:45:52 (snpslmd) SABER_SCOPE_NETLIST SABER_SIMULATOR SABER_SKETCH
10:45:52 (snpslmd) SABER_SKETCH_NETLIST SC-BC                SC-COSIM
10:45:52 (snpslmd) SC-FPGA                PPPRT                PrimeTime
10:45:52 (snpslmd) PrimeTime_gui        PrimeTime-Plus        PrimeTime-SI
10:45:52 (snpslmd) prmspx_visual_all Prolyt_all        ProMA-L1
10:45:52 (snpslmd) ProMA-L2        ProMA-LD        ProMA-P1
10:45:52 (snpslmd) ProMA-P2        ProMA-PD        Protocol-Compiler-Analysis
10:45:52 (snpslmd) Protocol-Compiler-COutput Protocol-Compiler-FML Protocol-Compiler-Synth
10:45:52 (snpslmd) Protocol-Compiler-UI provhdl_checker PS_CTS
10:45:52 (snpslmd) PS_Extraction        PS_Noise_Optimization psf
10:45:52 (snpslmd) PSG-SDE                pwga                QLOGIC
10:45:52 (snpslmd) Quantum38k        rad                RailMacro
10:45:52 (snpslmd) railmill        railmill/ace        railmill/av
10:45:52 (snpslmd) railmill/bcx        railmill/beta_status PhysOpt-Extraction
10:45:52 (snpslmd) PhysOpt-GUI        PhysOpt-Hierarchy PhysOpt-Onroute
10:45:52 (snpslmd) PhysOpt-Parallel PhysOpt-Route        PhysOpt-Route-TD
10:45:52 (snpslmd) PhysOpt-Routing PhysOpt-SI        PhysOpt-Ultra
10:45:52 (snpslmd) PlanetPL        PlanetRTL        pmga
10:45:52 (snpslmd) polaris-cbs        polaris-com        polaris-int
10:45:52 (snpslmd) polaris-mt        polaris-signalscan Power-Analysis
10:45:52 (snpslmd) powerarc        powergate        Power-Optimization
10:45:52 (snpslmd) Power-Optimization-Upgrade primerail_hsim        powrmill
10:45:52 (snpslmd) powrmill/ace        powrmill/av        powrmill/bcx
10:45:52 (snpslmd) powrmill/beta_status powrmill/btm        powrmill/csx
10:45:52 (snpslmd) powrmill/internal_use powrmill/msx        powrmill/nsaddon
10:45:52 (snpslmd) powrmill/power        powrmill/svcz        powrmill/vlog_a
10:45:52 (snpslmd) nProp                nSC                nSchema
10:45:52 (snpslmd) nSchemaOnly        nState                nTE
10:45:52 (snpslmd) nTiming                nTrace                nTree
10:45:52 (snpslmd) nTX                nWave                OPT_TEMPLATE_LIB
10:45:52 (snpslmd) OptimISE-DOE_all OptimISE-Iterative_all OptimISE-RSMOpt_all
10:45:52 (snpslmd) OptimISE-Statistical_all ORCA2A                ORCA2TB
10:45:52 (snpslmd) ORCA3C                ORCA3FPSC        ORCA3L
10:45:52 (snpslmd) ORCA4E                ParDiSo_all        Parse-Tree-Translator
10:45:52 (snpslmd) pathfinder        pathmill        pathmill/cso
10:45:52 (snpslmd) pathmill/ctx        pathmill/dsx        pathmill/pfx
10:45:52 (snpslmd) pathmill/sfx        pathmill_plus        PC-Expert
10:45:52 (snpslmd) PhysOpt                PhysOpt-Beta        PhysOpt-ClockTree
10:45:52 (snpslmd) MWAPIaccess        MWAPIdev        nAnalyzer
10:45:52 (snpslmd) nanosim/ace        nanosim/ace_cosim nanosim/av
10:45:52 (snpslmd) nanosim/bcx        nanosim/bdc        nanosim/beta_status
10:45:52 (snpslmd) nanosim/btm        nanosim/gui        nanosim/internal_use
10:45:52 (snpslmd) nanosim/msx        nanosim/postlayout_har nanosim/power
10:45:52 (snpslmd) nanosim/vlog_a        nBench                nClock
10:45:52 (snpslmd) nCompare        nECO                nESL
10:45:52 (snpslmd) nlcc                nLint                nLint_either
10:45:52 (snpslmd) nLint_mixed        nLint_sv        nLint_verilog
10:45:52 (snpslmd) nLint_vhdl        nMonitor        Noffset-2D_all
10:45:52 (snpslmd) Noffset-3D_all        Nova-ExploreRTL-Verilog npi
10:45:52 (snpslmd) MC-Pro-RP        MC-Retime        MDataCheck
10:45:52 (snpslmd) MEMPRO                MEMPRO-LIB        mentor/f
10:45:52 (snpslmd) Mentor-Interface MERCURY                Mesh1D_all
10:45:52 (snpslmd) Mesh2D_all        Mesh3D_all        metawaves
10:45:52 (snpslmd) metawaveswin        mg_falcon_epic        MIF-Reader
10:45:52 (snpslmd) MIF-Writer        Milkyway-Interface Millennium-ATPG-EE
10:45:52 (snpslmd) Millennium-ATPG-STD Millennium-Beta Millennium-DRC
10:45:52 (snpslmd) Millennium-Eval Millennium-FS        milltools
10:45:52 (snpslmd) misc                Mixed-Language        Mixed-Paradigm
10:45:52 (snpslmd) MODEL_ENCRYPTION MODEL_SYNTHESIS MOTIVE-PrimeTime
10:45:52 (snpslmd) mti_epic        MV-Astro-Opt        LigamentFE_all
10:45:52 (snpslmd) LINYE                LMCSwift        LMCSwift_Net
10:45:52 (snpslmd) LSI-Interface        lsim_parser        LSS4E
10:45:52 (snpslmd) LTL-100                LTL-100_CIF        MACH1
10:45:52 (snpslmd) MACH2                MACH4                MACH5
10:45:52 (snpslmd) MAdv                Mars                MAX3000A
10:45:52 (snpslmd) MAX7000                MAX7000A        MAX7000AE
10:45:52 (snpslmd) MAX7000B        MAX7000E        MAX7000S
10:45:52 (snpslmd) MAX9000                MCD                MCE
10:45:52 (snpslmd) MCE-Base        MCE-Eval        MCE-Lib-ALU
10:45:52 (snpslmd) MCE-Lib-Arith1        MCE-Lib-Arith2        MCE-Lib-Arith3
10:45:52 (snpslmd) MCE-Lib-Logic        MC-Pro                ispLSI5K
10:45:52 (snpslmd) ispLSI6K        ispLSI8K        ispMACH4000
10:45:52 (snpslmd) JUAdvOptA        JUAdvOptB        JUAOPAS
10:45:52 (snpslmd) JUAPlan                JUATime                JUAUD
10:45:52 (snpslmd) JUClock                JUDP                JUOPAS
10:45:52 (snpslmd) Jupiter                JupiterXT        JUPlan
10:45:52 (snpslmd) JUTime                JUUD                JUVS
10:45:52 (snpslmd) Key-Generator        Laker_AMS        Laker_iDRC
10:45:52 (snpslmd) Laker_iLVS        Laker_L1        Laker_L2
10:45:52 (snpslmd) Laker_L3        Laker_T1        Laker_T1_LE
10:45:52 (snpslmd) Laker_Viewer        Leakage-Power        leda_checker
10:45:52 (snpslmd) leda_mx                leda-mx                libarc
10:45:52 (snpslmd) Library-Compiler Ligament_all        HLS-FPGA-SystemC
10:45:52 (snpslmd) HLS-SystemC        hsim                hsim-cosim
10:45:52 (snpslmd) hsim-xl                hspice_adv        hspice_cosim
10:45:52 (snpslmd) hspice_gui        HSPICE_MODEL_LIBRARY hspice_mt
10:45:52 (snpslmd) hspice_rf        hspice_rf_char        hspicemt
10:45:52 (snpslmd) hspicewin        hspice-XO        hspicext
10:45:52 (snpslmd) hsptest                hspui                Hsp-vacomp
10:45:52 (snpslmd) ICInteractive        Inspect_all        Interface-Shell
10:45:52 (snpslmd) Interfise_all        IQBUS_AUTHOR        IQBUS_LIB
10:45:52 (snpslmd) IROI                ISExtract_all        ispLSI1K
10:45:52 (snpslmd) ispLSI2K        ispLSI2KE        ispLSI3K
10:45:52 (snpslmd) ispLSI5000S        ispLSI5000SE        HERCULES_HLVS
10:45:52 (snpslmd) HERCULES_HLVS-DEBUG HERCULES_HLVS-HTML HERCULES-DISTRIBUTED
10:45:52 (snpslmd) HERCULES-DISTRIBUTED-2 HERCULES-DISTRIBUTED-24 HERCULES-DISTRIBUTED-24/2000.4
10:45:52 (snpslmd) HERCULES-DISTRIBUTED-4 HERCULES-FINDSHORT hicdr_test
10:45:52 (snpslmd) hicdr_test/test1 hicdr_test/test2 hicdr_test/test3
10:45:52 (snpslmd) hicdr_test/test4 hicdr_test/test5 hicdr_test/test6
10:45:52 (snpslmd) hicdr_test/test7 hicdr_test/test8 HighLevel-Power-Analysis
10:45:52 (snpslmd) HighLevel-Power-Optimization him_mb                him_mb_dsml
10:45:52 (snpslmd) him_mod                him_sml                Gsim_framework_basic
10:45:52 (snpslmd) Gsim_snapshot        Gsim_wave        GuidedTraceAnalysis
10:45:52 (snpslmd) hd_foundation        hd_pna                hd_special1
10:45:52 (snpslmd) hd_special2        hd_special3        hd_utils
10:45:52 (snpslmd) HDL                HDL2SC_mixed        HDL2SC_verilog
10:45:52 (snpslmd) HDL2SC_vhdl        HDL-Advisor        HDL-Advisor-Estimator
10:45:52 (snpslmd) HDL-Advisor-Estimator-Package HDL-Advisor-Package HDL-Advisor-Shell
10:45:52 (snpslmd) HDL-Advisor-Shell-Estimator HDL-Advisor-Shell-Estm-Package HDL-Advisor-Shell-Package
10:45:52 (snpslmd) HDL-Compiler        hdlin                hdlin_mixed
10:45:52 (snpslmd) hdlin_verilog        hdlin_vhdl        HERCULES_HDRC
10:45:52 (snpslmd) HERCULES_HDRC-HTML HERCULES_HERC-ADV HERCULES_HERC-BASIC
10:45:52 (snpslmd) FPGA-Library-Compiler FPGA-Option        FPGA-VHDL-Bundle
10:45:52 (snpslmd) FPPRT                FPTA                FPTime
10:45:52 (snpslmd) Fridge-GUI        Fridge-Interpolator Fridge-Simulation
10:45:52 (snpslmd) FSM-Reader        FSM-Writer        FusionVantageLmcInterface
10:45:52 (snpslmd) Gaia                Galaxy-AdvCTS        Galaxy-AdvTech
10:45:52 (snpslmd) Galaxy-Common        Galaxy-DFT        Galaxy-DFY
10:45:52 (snpslmd) Galaxy-FP        Galaxy-ICC        Galaxy-IU
10:45:52 (snpslmd) Galaxy-MV        Galaxy-PNR        Galaxy-Power
10:45:52 (snpslmd) Galaxy-Prototype Galaxy-PSYN        Gate2LayoutCorrelation
10:45:52 (snpslmd) Gate2RTLCorrelation gemini_hspice        GENERICVSP
10:45:52 (snpslmd) GENESISe_all        gentech                GRAPHICS_INTERFACE
10:45:52 (snpslmd) Gsim_dump_advance Gsim_dump_basic Gsim_framework_advance
10:45:52 (snpslmd) FPGA-Express-A42MX-Optimizer FPGA-Express-A54SX-Optimizer FPGA-Express-APEX2-Optimizer
10:45:52 (snpslmd) FPGA-Express-APROA-Optimizer FPGA-Express-Constraint-Mgr FPGA-Express-EP20k-Optimizer
10:45:52 (snpslmd) FPGA-Express-EPF10k-Optimizer FPGA-Express-EPF6k-Optimizer FPGA-Express-EPF8k-Optimizer
10:45:52 (snpslmd) FPGA-Express-EPM7k-Optimizer FPGA-Express-EPM9k-Optimizer FPGA-Express-GAT
10:45:52 (snpslmd) FPGA-Express-isp1K-Optimizer FPGA-Express-isp2K-Optimizer FPGA-Express-isp3K-Optimizer
10:45:52 (snpslmd) FPGA-Express-ISP4000-Optimizer FPGA-Express-isp4K-Optimizer FPGA-Express-ISP5000-Optimizer
10:45:52 (snpslmd) FPGA-Express-isp5K-Optimizer FPGA-Express-isp6K-Optimizer FPGA-Express-isp7K-Optimizer
10:45:52 (snpslmd) FPGA-Express-isp8K-Optimizer FPGA-Express-MERCURY-Optimizer FPGA-Express-Open-Optimizer
10:45:52 (snpslmd) FPGA-Express-ORCA2-Optimizer FPGA-Express-ORCA3-Optimizer FPGA-Express-Synario-Optimizer
10:45:52 (snpslmd) FPGA-Express-VHDL-Base FPGA-Express-VHDL-Training FPGA-Express-VIRTEX-Optimizer
10:45:52 (snpslmd) FPGA-Express-VLOG-Base FPGA-Express-XC3k-Optimizer FPGA-Express-XC4k-Optimizer
10:45:52 (snpslmd) FPGA-Express-XC5k-Optimizer FPGA-Express-XC9k-Optimizer FPGA-HDL-Bundle
10:45:52 (snpslmd) ficdr_test/tio        FL_cosim_run        FL_ice_run
10:45:52 (snpslmd) FL_multichip_partition FL_recalc        Flash370i
10:45:52 (snpslmd) FLE_main        FLEX10K                FLEX10KA
10:45:52 (snpslmd) FLEX10KB        FLEX10KE        FLEX6000
10:45:52 (snpslmd) FLEX8000        Floops-1D_all        Floops-1D-MC_all
10:45:52 (snpslmd) Floops-2D_all        Floops-2D-MC_all Floops-3D_all
10:45:52 (snpslmd) Floops-3D-MC_all Floops-Parallel_all Floops-Parallel4_all
10:45:52 (snpslmd) Floorplan-Management Formality        Formality-DV
10:45:52 (snpslmd) Formality-E1        Formality-TransForm Formality-Transit
10:45:52 (snpslmd) FPABP                FPDP                FPGA_Express-APROA-Optimizer
10:45:52 (snpslmd) FPGA-Compiler        FPGA-Express        FPGA-Express-32OODx-Optimizer
10:45:52 (snpslmd) FPGA-Express-A1200XL-Optimizer FPGA-Express-A1400-Optimizer FPGA-Express-A3200DX-Optimizer
10:45:52 (snpslmd) emw-uniform-2d_all emw-uniform-3d_all ENACE
10:45:52 (snpslmd) ENACS                encore                Enterprise
10:45:52 (snpslmd) Equation-Reader Equation-Writer Espresso-Reader
10:45:52 (snpslmd) Espresso-Writer EssentialSignalAnalysis Estm-HDL-Advisor
10:45:52 (snpslmd) Estm-HDL-Advisor-Package etran                Eview
10:45:52 (snpslmd) eX                example_feature EXCALIBUR_ARM
10:45:52 (snpslmd) EXCALIBUR_MIPS        Extraction        FCII-Altera-Edition
10:45:52 (snpslmd) FCO                features        ficdr_test
10:45:52 (snpslmd) ficdr_test/gds        ficdr_test/goa        ficdr_test/io
10:45:52 (snpslmd) ficdr_test/nc        ficdr_test/poly ficdr_test/size
10:45:52 (snpslmd) ficdr_test/sizeOr ficdr_test/stmp DW-IP-Consultant
10:45:52 (snpslmd) DW-IP-DEBUG        DW-IP-Developer E5
10:45:52 (snpslmd) E502                E505                E520
10:45:52 (snpslmd) Early-Access-Technology ECL-Compiler        ECO-Compiler
10:45:52 (snpslmd) edif2e                EDIF-Netlist-Read-DC EDIF-Netlist-Write-DC
10:45:52 (snpslmd) EDIF-Netlist-Writer EDIF-Reader        EDIF-Schematic-Writer
10:45:52 (snpslmd) electromigration_drc ELGRECO_Davis        ELGRECO_DesignCenter
10:45:52 (snpslmd) ELGRECO_Simulator Emlab_all        Emlab-Dessis_all
10:45:52 (snpslmd) Emlab-Farfield_all Emlab-Nonuniform-2D_all Emlab-Nonuniform-3D_all
10:45:52 (snpslmd) Emlab-Static_all Emlab-Thermal_all Emlab-Uniform-2D_all
10:45:52 (snpslmd) Emlab-Uniform-3D_all emw_all                emw-farfield_all
10:45:52 (snpslmd) emw-nonuniform-2d_all emw-nonuniform-3d_all emw-sdevice_all
10:45:52 (snpslmd) emw-static_all        emw-thermal_all Dessis-Optic_all
10:45:52 (snpslmd) Dessis-Parallel_all Dessis-Parallel4_all Dessis-PMI_all
10:45:52 (snpslmd) Dessis-Radiation_all Dessis-Reliability_all Dessis-Schroedinger_all
10:45:52 (snpslmd) Dessis-SiGe_all Dessis-Thermo_all Dessis-Traps_all
10:45:52 (snpslmd) Dessis-VectorOptic_all Devise_all        Devise-3D_all
10:45:52 (snpslmd) Dfisetools_all        Dfisetools-Topo_all Dios_all
10:45:52 (snpslmd) Dios-3D_all        Dios-MC_all        Dios-PDEF_all
10:45:52 (snpslmd) Dios-SDO_all        DiosSmall_all        Dip_all
10:45:52 (snpslmd) DIRECTMEM        DS-Schem-Gen        DS-Schem-Gen-Estimator-Pa
10:45:52 (snpslmd) DS-Schem-Gen-Estimator-Package DS-Schem-Gen-Package DS-Verinet
10:45:52 (snpslmd) DS-Verinet-Estimator-Pack DS-Verinet-Estimator-Package DS-Verinet-Package
10:45:52 (snpslmd) DS-Vhdlnet        DS-Vhdlnet-Estimator-Pack DS-Vhdlnet-Estimator-Package
10:45:52 (snpslmd) DS-Vhdlnet-Package DW-Developer        DesignWare-MPEG2
10:45:52 (snpslmd) DesignWare-MPEG2-Source DesignWare-MPEG2-VDEC DesignWare-MPEG2-VDEC-Source
10:45:52 (snpslmd) DesignWare-MPEG-Source DesignWare-Package DesignWare-PCI
10:45:52 (snpslmd) DesignWare-PCIbasic DesignWare-PCI-Source DesignWare-PCI-X
10:45:52 (snpslmd) DesignWare-PCI-X-Source DesignWare-SystemIO DesignWare-SystemIO-Source
10:45:52 (snpslmd) DesignWare-TCA        DesignWare-TCA-Source DesignWare-USB
10:45:52 (snpslmd) DesignWare-USB2 DesignWare-USB2-Source DesignWare-USB-Source
10:45:52 (snpslmd) DesignWare-VERA Dessis_all        Dessis-3D_all
10:45:52 (snpslmd) Dessis-BONSIM_all Dessis-DensityGrad_all Dessis-Ferro_all
10:45:52 (snpslmd) Dessis-FloatingGate_all Dessis-GateLeakage_all Dessis-Hetero_all
10:45:52 (snpslmd) Dessis-Hydro_all Dessis-kpGain_all Dessis-Laser_all
10:45:52 (snpslmd) Dessis-LED_all        Dessis-MixedMode_all Dessis-Mono-Semicond_all
10:45:52 (snpslmd) Dessis-MonteCarlo_all Dessis-Noise_all Design-Budgeting
10:45:52 (snpslmd) Design-Compiler Design-Estimator Design-Estimator-FPI
10:45:52 (snpslmd) DesignSource        DesignSource-Estimator-Package DesignSource-Package
10:45:52 (snpslmd) DesignTime        Design-Vision        DesignWare
10:45:52 (snpslmd) DesignWare-1394 DesignWare-1394-Source DesignWare-6811-Source
10:45:52 (snpslmd) DesignWare-8051 DesignWare-8051MCU DesignWare-8051-Source
10:45:52 (snpslmd) Designware-Basic DesignWare-BIST DesignWare-BIST-Source
10:45:52 (snpslmd) DesignWare-Cardbus Designware-Developer DesignWare-Developer-MGI
10:45:52 (snpslmd) DesignWare-ETHERNET-Source DesignWare-FloatingPoint DesignWare-Foundation
10:45:52 (snpslmd) DesignWare-Foundation-Exp DesignWare-Foundation-Expert DesignWare-Foundation-Power
10:45:52 (snpslmd) DesignWare-Foundation-Ultra Designware-FPGA-Basic DesignWare-ISA-PnP
10:45:52 (snpslmd) DesignWare-MemoryBist DesignWare-MemoryBist-Source DesignWare-MGI
10:45:52 (snpslmd) DesignWare-MPEG Cyclone-Elaborator Cyclone-GUI
10:45:52 (snpslmd) Cyclone-HDL-Analyzer Cyclone-Simulator Cyclone-VHDL-Analyzer
10:45:52 (snpslmd) CYPRESS                DataExpansion        DataExpansionCoverage
10:45:52 (snpslmd) DataExpansionSim DATAIO                DataReplay
10:45:52 (snpslmd) DataReplaySim        DC64                DC-Beta
10:45:52 (snpslmd) DC-Cadence-Interface DC-Expert        DCExpert-PrimeTime
10:45:52 (snpslmd) DC-Falcon-Interface DC-FPGA-Accelerator DC-FPGA-Add-On
10:45:52 (snpslmd) DC-FPGA-Features DC-Layout-Interface DCM-Delay-Calculation
10:45:52 (snpslmd) DC-Min-Area-Retime DC-SDF-Interface DC-Ultra
10:45:52 (snpslmd) DC-Ultra-Features DC-Ultra-Opt        DC-XG
10:45:52 (snpslmd) Debussy                Debussy_shared        delaymill
10:45:52 (snpslmd) Delta39k        DEMO                Design-Analyzer
10:45:52 (snpslmd) Design-Analyzer-DAP COSSAP_matlab        COSSAP_mfd
10:45:52 (snpslmd) COSSAP_mpeg2        COSSAP_pdc        COSSAP_qed
10:45:52 (snpslmd) COSSAP_sds        COSSAP_srcfd        COSSAP_vcg_generic
10:45:52 (snpslmd) COSSAP_vcg_synopsys COSSAP_vcg_vantage COSSAP_vdefcg
10:45:52 (snpslmd) COSSAP_vdefcg_vlgxl COSSAP_vsiccg        COSSAP_vsiccg_cyc
10:45:52 (snpslmd) COSSAP_vsiccg_mti COSSAP_vsiccg_mtivlg COSSAP_vsiccg_vcs
10:45:52 (snpslmd) COSSAP_vsiccg_vlgxl COSSAP_vsivcg        COSSAP_vsivcg_vlgxl
10:45:52 (snpslmd) COSSAP_xdcg        COSSAP_xvcg        COSSAP_xvsi
10:45:52 (snpslmd) CoverMeter        CoverMeterOBC        CoverMeterOBCVCSAMSCompiler
10:45:52 (snpslmd) CRS_COVERMETER        CRS_VCM                CRS_VCS
10:45:52 (snpslmd) CRS_VCSi        CTV-Interface        CUSTOM_LIB
10:45:52 (snpslmd) Cyclone-Code-Generator Cyclone-Core        Cyclone-cosim
10:45:52 (snpslmd) COSSAP_cw_filter_sds COSSAP_dab        COSSAP_dcg_ad21020
10:45:52 (snpslmd) COSSAP_dcg_ansic COSSAP_dcg_ariel32c COSSAP_dcg_fe
10:45:52 (snpslmd) COSSAP_dcg_gc        COSSAP_dcg_krc        COSSAP_dcg_lsic30s
10:45:52 (snpslmd) COSSAP_dcg_m96000 COSSAP_dcg_mp        COSSAP_ddk_arm
10:45:52 (snpslmd) COSSAP_ddk_devlp COSSAP_ddk_dsp16000 COSSAP_ddk_dsp1610
10:45:52 (snpslmd) COSSAP_ddk_hawk COSSAP_ddk_nec        COSSAP_ddk_oak
10:45:52 (snpslmd) COSSAP_ddk_pine COSSAP_ddk_ssp16xx COSSAP_ddk_tic5x
10:45:52 (snpslmd) COSSAP_ddk_tic5xx COSSAP_dect        COSSAP_dvb
10:45:52 (snpslmd) COSSAP_ecc        COSSAP_gsmdve        COSSAP_gsmdve_utils
10:45:52 (snpslmd) COSSAP_gsmefrsc COSSAP_gsmeq        COSSAP_gsmfrcc
10:45:52 (snpslmd) COSSAP_gsmfrsc        COSSAP_gsmhrcc        COSSAP_gsmhrsc
10:45:52 (snpslmd) COSSAP_gsmphy        COSSAP_is136        COSSAP_is95
10:45:52 (snpslmd) CoCentric-SYS-Davis CoCentric-SYS-DesignCenter CoCentric-SYS-HWflow
10:45:52 (snpslmd) CoCentric-SYS-HWSimIF CoCentric-SYS-RDK-adsl CoCentric-SYS-RDK-cdma2000
10:45:52 (snpslmd) CoCentric-SYS-RDK-docsis CoCentric-SYS-Simulator Columbia
10:45:52 (snpslmd) ColumbiaTE        COMPONENT_LIBRARY Constraint_Translation
10:45:52 (snpslmd) Converter        COOLRUNNER        COOLRUNNER2
10:45:52 (snpslmd) coreAssembler        coreBuilder        coreConsultant
10:45:52 (snpslmd) coremill        coreSynthesis        COSIM-LFG
10:45:52 (snpslmd) COSIM-MTI        COSIM-NCV        COSIM-SRO
10:45:52 (snpslmd) COSIM-VCS        COSIM-VXL        COSSAP_adpcm
10:45:52 (snpslmd) COSSAP_adsl        COSSAP_amr        COSSAP_arm
10:45:52 (snpslmd) COSSAP_bde        COSSAP_celp        COSSAP_chart
10:45:52 (snpslmd) COSSAP_cw_filter_hdl CBA-Logical-MA        CBA-Physical-DS
10:45:52 (snpslmd) CBA-Physical-MA CBA-Transport        CD-Compiled-Lib-Gen
10:45:52 (snpslmd) CD-Compiled-Sys-Gen CD-GDI                CD-GDII-Link
10:45:52 (snpslmd) CD-Model-Developer CD-MSSC-Cross-Probe CD-MSSC-Netlist
10:45:52 (snpslmd) CD-Present-Builder CD-Present-Layer-Gen CD-REX
10:45:52 (snpslmd) cdsaavmx        cdsmetalib        cdsnet
10:45:52 (snpslmd) CD-Vhdlgen-Gen        CD-Vhdlgen-GUI        chipviewer
10:45:52 (snpslmd) cmod                cmod/ax                cmod/cbx
10:45:52 (snpslmd) cmod/drc        cmod/gx                cmod/gxadv
10:45:52 (snpslmd) cmod/hdrc        cmod/hlvs        cmod/ipc
10:45:52 (snpslmd) cmod/lvs        cmod/viewer        CmView
10:45:52 (snpslmd) CoCentric-FXD-GUI CoCentric-FXD-Interpolator CoCentric-FXD-Simulation
10:45:52 (snpslmd) avanwaveswin        awe_rcr                BC-FPGA
10:45:52 (snpslmd) BC-FPGA-HDL        BC-FPGA-VHDL        BC-HDL
10:45:52 (snpslmd) BC-Schedule        BC-VHDL                Behavioral-Analyzer
10:45:52 (snpslmd) Behavioral-Compiler BOA-BRT                c_exe_ax
10:45:52 (snpslmd) c_exe_cbx        c_exe_drc        c_exe_gx
10:45:52 (snpslmd) c_exe_ipc        c_exe_lvs        CA-Chip-Edit
10:45:52 (snpslmd) CA-CP-Advanced        CA-CP-Basic        CA-CP-Standard
10:45:52 (snpslmd) cadence                cadence_epic        CA-Foundation
10:45:52 (snpslmd) CA-Frame        CA-Hier-Timer        CA-Optimization
10:45:52 (snpslmd) CA-Timer        CA-Utils        CBA-ApolloGA-Interface
10:45:52 (snpslmd) CBA-Blk-Export        CBA-Blk-Import        CBA-CadenceSE-Interface
10:45:52 (snpslmd) CBA-DS-Beta        CBA-Frame        CBA-Logical-DS
10:45:52 (snpslmd) arc/ppx                arc/pro                arc/r3x
10:45:52 (snpslmd) arc1                arc2                arcexpert
10:45:52 (snpslmd) arcfc                arcviewer        arcviewer/raph
10:45:52 (snpslmd) arcxl                ARKOS-A                ARKOS-B
10:45:52 (snpslmd) ARKOS-C                ARKOS-D                ARKOS-E
10:45:52 (snpslmd) ARKOS-Ice        ARKOS-Mcomp        ARKOS-Rtlcomp
10:45:52 (snpslmd) ARKOS-Scomp        ARKOS-Simul        ARM7TDMI
10:45:52 (snpslmd) Astro                AstroBeta        AstroExp
10:45:52 (snpslmd) Astro-Express        AstroGA                AstroRail
10:45:52 (snpslmd) Astro-Rail        AstroRailSA        AstroSpecialBeta
10:45:52 (snpslmd) AstroXtalk        Astro-Xtalk        ATMEL
10:45:52 (snpslmd) ATMWB_ATMLAYER        ATMWB_UTOPIA        avanwaves
10:45:52 (snpslmd) APACM                APATD                APCS
10:45:52 (snpslmd) APDP                APEX20K                APEX20KC
10:45:52 (snpslmd) APEX20KE        APEXII                APGA4AP
10:45:52 (snpslmd) APGACS                APGADP                APGAHPO
10:45:52 (snpslmd) APGApwr                APGASolar        APGASolarII
10:45:52 (snpslmd) APGATime        APHPO                Apollo
10:45:52 (snpslmd) ApolloGA        APPower                APpwr
10:45:52 (snpslmd) APSolar                APSolarII        APTime
10:45:52 (snpslmd) APXtalk                arc                arc/bcx
10:45:52 (snpslmd) arc/c2x                arc/c3x                arc/cns
10:45:52 (snpslmd) arc/dnx                arc/dpx                arc/gds2
10:45:52 (snpslmd) arc/giper        arc/lefdef        A3200DX
10:45:52 (snpslmd) A42MX                A500K                A54SX
10:45:52 (snpslmd) A54SXA                A7                AARKOS-A
10:45:52 (snpslmd) ace_core        acega                acehdl
10:45:52 (snpslmd) acehdl/beta_status acehdl/internal_use acehdl_beta
10:45:52 (snpslmd) acehdl_gui        ACEX1K                ACS
10:45:52 (snpslmd) ACT2-1200XL        ACT3                AdvanceCalibration_all
10:45:52 (snpslmd) AdvancedCalibration_all AIM_DEBUG        AIM_DECRYPT
10:45:52 (snpslmd) AIM_DEVELOPER        AIM_ENCRYPT        aiu_foundation
10:45:52 (snpslmd) alien2lig_all        ALTGEN1                ALTGEN2
10:45:52 (snpslmd) amat-calib_all        amga                amps
10:45:52 (snpslmd) amps/cso        amps/pfx        amps/tr
10:45:52 (snpslmd) AN-Impl3D_all        any_technology
10:45:52 (snpslmd)
10:45:52 (snpslmd) Licenses are case sensitive for TE_CATS
10:45:52 (snpslmd)
10:45:52 (snpslmd) EXTERNAL FILTERS are OFF
10:45:52 (lmgrd) snpslmd using TCP-port 48068
10:45:52 (snpslmd) Serving features for the following vendor names:
snpslmd  ACAD  adalmd  anagram  arcd  atrenta  avantd  CADABRA  chrysalisd  cowared  EPIC  eved  extremed  hscd  innologd  ISE-TCADd  knights  magma  metasoftd  mwflexd  nassd  nsysnvs  numeritchd  pdld  perflmd  riod  saber_dmn  sandwork  sclmgrd  sigmacd  SIINT  simple  snpsOEM1  snslmgrd  ssilmd  synforad  synopsysd  synplctyd  targetld  TAVEREN  TE_CATS  tmald  vastlmd  vcsd  wlld
10/26/2021 10:45:53 (snpslmd) ------------------------------------------------------------------
10/26/2021 10:45:53 (snpslmd) Checking the integrity of the license file...
10/26/2021 10:45:53 (snpslmd) Valid SSS feature found.
10/26/2021 10:45:53 (snpslmd) The feature is needed to enable the other keys in your license file.
10/26/2021 10:45:53 (snpslmd) Licensed to student@eetop
10/26/2021 10:45:53 (snpslmd) Siteid: 26356, Server Hostid: 18C04D0D8DC0, Issued on: 1/8/2014
10:45:54 (snpslmd) SLOG: Statistics Log Frequency is 240 minute(s).
10:45:54 (snpslmd) SLOG: TS update poll interval is 0. TS update is detected by midnight reread only.
10:45:54 (snpslmd) SLOG: Activation borrow reclaim percentage is 0.
10:45:54 (snpslmd) (@snpslmd-SLOG@) ===============================================
10:45:54 (snpslmd) (@snpslmd-SLOG@) === Vendor Daemon ===
10:45:54 (snpslmd) (@snpslmd-SLOG@) Vendor daemon: snpslmd
10:45:54 (snpslmd) (@snpslmd-SLOG@) Start-Date: Tue Oct 26 2021 10:45:54 CST
10:45:54 (snpslmd) (@snpslmd-SLOG@) PID: 30810
10:45:54 (snpslmd) (@snpslmd-SLOG@) VD Version: v11.14.1.3 build 212549 x64_lsb ( build 212549 (ipv6))
10:45:54 (snpslmd) (@snpslmd-SLOG@) === Startup/Restart Info ===
10:45:54 (snpslmd) (@snpslmd-SLOG@) Options file used: None
10:45:54 (snpslmd) (@snpslmd-SLOG@) Is vendor daemon a CVD: Yes
10:45:54 (snpslmd) (@snpslmd-SLOG@) Is TS accessed: No
10:45:54 (snpslmd) (@snpslmd-SLOG@) TS accessed for feature load: -NA-
10:45:54 (snpslmd) (@snpslmd-SLOG@) Number of VD restarts since LS startup: 0
10:45:54 (snpslmd) (@snpslmd-SLOG@) === Network Info ===
10:45:54 (snpslmd) (@snpslmd-SLOG@) Listening port: 48068
10:45:54 (snpslmd) (@snpslmd-SLOG@) Daemon select timeout (in seconds): 1
10:45:54 (snpslmd) (@snpslmd-SLOG@) === Host Info ===
10:45:54 (snpslmd) (@snpslmd-SLOG@) Host used in license file: local
10:45:54 (snpslmd) (@snpslmd-SLOG@) Running on Hypervisor: Not determined - treat as Physical
10:46:16 (snpslmd) TCP_NODELAY NOT enabled
10:46:28 (snpslmd) OUT: "Design-Compiler" root@local  [l7f010031316_1]
10:46:31 (snpslmd) IN: "Design-Compiler" root@local  [l7f010031316_1]
14:45:55 (snpslmd) (@snpslmd-SLOG@) ===============================================
14:45:55 (snpslmd) (@snpslmd-SLOG@) === Last 10 Client Requests Processing Time (in ms) ===
14:45:55 (snpslmd) (@snpslmd-SLOG@) Time: Tue Oct 26 2021 14:45:55 CST
14:45:55 (snpslmd) (@snpslmd-SLOG@) Request processing time, when, #concurrent clients, client info (user, node, FD)
14:45:55 (snpslmd) (@snpslmd-SLOG@) 00000000 ms at Tue Oct 26 2021 10:46:56 CST,#3,(root,local,65)
14:45:55 (snpslmd) (@snpslmd-SLOG@) 00000001 ms at Tue Oct 26 2021 10:46:56 CST,#3,(root,local,65)
14:45:55 (snpslmd) (@snpslmd-SLOG@) 00000000 ms at Tue Oct 26 2021 10:46:28 CST,#4,(root,local,65)
14:45:55 (snpslmd) (@snpslmd-SLOG@) 00000001 ms at Tue Oct 26 2021 10:46:28 CST,#4,(root,local,65)
14:45:55 (snpslmd) (@snpslmd-SLOG@) === Top 10 Peak Client Requests Processing Time (in ms) ===
14:45:55 (snpslmd) (@snpslmd-SLOG@) 00000003 ms at Tue Oct 26 2021 10:46:28 CST,#4,(root,local,65)
14:45:55 (snpslmd) (@snpslmd-SLOG@) 00000001 ms at Tue Oct 26 2021 10:46:23 CST,#3,(root,local,65)
14:45:55 (snpslmd) (@snpslmd-SLOG@) 00000001 ms at Tue Oct 26 2021 10:46:28 CST,#4,(root,local,66)
14:45:55 (snpslmd) (@snpslmd-SLOG@) === Top 10 Peak In-house Operations time (in ms) ===
14:45:55 (snpslmd) (@snpslmd-SLOG@) NOTE: Peak times greater than 4 seconds get recorded.
14:45:55 (snpslmd) (@snpslmd-SLOG@) In-house operation time, when, #concurrent clients
14:45:55 (snpslmd) (@snpslmd-SLOG@) === Active Connections Info ===
14:45:55 (snpslmd) (@snpslmd-SLOG@) Peak active connections #4 attempted at Tue Oct 26 2021 10:46:28 CST
16:45:51 (lmgrd) TIMESTAMP 10/26/2021
16:50:55 (snpslmd) TIMESTAMP 10/26/2021
18:45:59 (snpslmd) (@snpslmd-SLOG@) ===============================================
18:45:59 (snpslmd) (@snpslmd-SLOG@) === Last 10 Client Requests Processing Time (in ms) ===
18:45:59 (snpslmd) (@snpslmd-SLOG@) Time: Tue Oct 26 2021 18:45:59 CST
18:45:59 (snpslmd) (@snpslmd-SLOG@) Request processing time, when, #concurrent clients, client info (user, node, FD)
18:45:59 (snpslmd) (@snpslmd-SLOG@) 00000000 ms at Tue Oct 26 2021 10:46:56 CST,#3,(root,local,65)
18:45:59 (snpslmd) (@snpslmd-SLOG@) 00000001 ms at Tue Oct 26 2021 10:46:56 CST,#3,(root,local,65)
18:45:59 (snpslmd) (@snpslmd-SLOG@) 00000000 ms at Tue Oct 26 2021 10:46:28 CST,#4,(root,local,65)
18:45:59 (snpslmd) (@snpslmd-SLOG@) 00000001 ms at Tue Oct 26 2021 10:46:28 CST,#4,(root,local,65)
18:45:59 (snpslmd) (@snpslmd-SLOG@) === Top 10 Peak Client Requests Processing Time (in ms) ===
18:45:59 (snpslmd) (@snpslmd-SLOG@) 00000003 ms at Tue Oct 26 2021 10:46:28 CST,#4,(root,local,65)
18:45:59 (snpslmd) (@snpslmd-SLOG@) 00000001 ms at Tue Oct 26 2021 10:46:23 CST,#3,(root,local,65)
18:45:59 (snpslmd) (@snpslmd-SLOG@) 00000001 ms at Tue Oct 26 2021 10:46:28 CST,#4,(root,local,66)
18:45:59 (snpslmd) (@snpslmd-SLOG@) === Top 10 Peak In-house Operations time (in ms) ===
18:45:59 (snpslmd) (@snpslmd-SLOG@) NOTE: Peak times greater than 4 seconds get recorded.
18:45:59 (snpslmd) (@snpslmd-SLOG@) In-house operation time, when, #concurrent clients
18:45:59 (snpslmd) (@snpslmd-SLOG@) === Active Connections Info ===
18:45:59 (snpslmd) (@snpslmd-SLOG@) Peak active connections #4 attempted at Tue Oct 26 2021 10:46:28 CST
 楼主| 发表于 2021-10-26 19:09:37 | 显示全部楼层
10:45:51 (lmgrd)
10:45:51 (lmgrd)
10:45:51 (lmgrd)
10:45:51 (lmgrd)
10:45:52 (snpslmd)
10:45:52 (snpslmd)
发表于 2021-10-26 20:45:37 来自手机 | 显示全部楼层
license问题
 楼主| 发表于 2021-10-26 21:14:17 | 显示全部楼层
您好,怎么说
发表于 2021-10-26 23:39:48 | 显示全部楼层
把运行icc之后的log发一下
 楼主| 发表于 2021-10-27 16:13:19 | 显示全部楼层
edacw 发表于 2021-10-26 23:39
把运行icc之后的log发一下
您好,就只有这些:
bash-4.2# icc_shell
Exit IC Compiler!
bash-4.2#
发表于 2021-10-27 19:42:09 | 显示全部楼层
樱花菲菲时 发表于 2021-10-27 16:13
您好,就只有这些:
bash-4.2# icc_shell
运行这个之后,log里面没有任何信息?
 楼主| 发表于 2021-11-2 15:41:38 | 显示全部楼层
edacw 发表于 2021-10-27 19:42
运行这个之后,log里面没有任何信息?
您好,请问log在哪儿看?我打开ICC所在的工作目录并没有任何文件产生
GMT+8, 2025-12-4 12:32 , Processed in 0.029238 second(s), 4 queries , Gzip On, Redis On.
