查看: 3408|回复: 9
[求助] DAC的SFDR仿真求助
发表于 2021-9-3 16:33:36 | 显示全部楼层 |阅读模式
悬赏100资产未解决
最近设计了一个8位的DAC,准备仿真它的SFDR,我已经在DAC前面用verilogA写了一个8位理想的ADC,时钟频率Fclk=100MHz,然后信号输入频率Fin=Fclk*127/256,得到了输出曲线,然后通过cadence取出了256个采样点,打算利用matlab分析,但是在网上找的matlab代码跑了之后出现了一些问题,如图所示,代码如下所示,想问问论坛里的各位大神这是什么原因呢?
clear
load DACtest.txt -ascii    %cadence导出的数据文件,文件必须以英文开头
A= DACtest;                                   %将测量数据赋给A,此时A为N×2的数组
x=A(:,1);                                        %将A中的第一列赋值给x,形成时间序列
y=A(:,2);                                        %将A中的第二列赋值给y,形成被测量序列
%显示原始数据曲线图(时域)
subplot(2,1,1);
plot(x,y) ;        %显示原始数据曲线图
%axis([min(x) max(x) 1.1*floor(min(y)) 1.1*ceil(max(y))])               %优化坐标,可有可无
xlabel('时间 (s)');
ylabel('被测变量y');
title('原始信号(时域)');
grid on;
format long;
%傅立叶变换
y=y-mean(y);                                               %消去直流分量,使频谱更能体现有效信息
fclk=(length(x)-1)/(max(x)-min(x));                                    %仪器的采样频率
numpt=length(y);                                                    %data.txt中的被测量个数,即采样个数
%If no window function is used, the input tone must be chosen to be unique and with
%regard to the sampling frequency. To achieve this prime numbers are introduced and the
%input tone is determined by fIN = fSAMPLE * (Prime Number / Data Record Size).
%To relax this requirement, window functions such as HANNING and HAMING (see below) can
%be introduced, however the fundamental in the resulting FFT spectrum appears 'sharper'
%without the use of window functions.
Doutw=y;
%Doutw=y'.*hanning(numpt);
%Doutw=y'.*hamming(numpt);
%Performing the Fast Fourier Transform
Dout_spect=fft(Doutw);
%Recalculate to dB
Dout_dB=20*log10(abs(Dout_spect));
%Display the results in the frequency domain with an FFT plot
figure; %建立图形
maxdB=max(Dout_dB(1:numpt/2));
%For TTIMD, use the following short routine, normalized to —6.5dB full-scale.
%plot([0:numpt/2-1].*fclk/numpt,Dout_dB(1:numpt/2)-maxdB-6.5);
%plot([0:30/2-1].*fclk/numpt,Dout_dB(1:30/2)-maxdB);
h=stem([0:256/2-1].*fclk/numpt,Dout_dB(1:256/2)-maxdB,'fill',':');
set(h,'MarkerEdgeColor','red','Marker','*')
grid on;
title('FFT PLOT');
xlabel('ANALOG INPUT FREQUENCY (Hz)');
ylabel('AMPLITUDE (dB)');
a1=axis; axis([a1(1) a1(2) -120 a1(4)]);
%Calculate SNR, SINAD, THD and SFDR values
%Find the signal bin number, DC = bin 1
fin=find(Dout_dB(1:numpt/2)==maxdB);
%Span of the input frequency on each side
%span=max(round(numpt/200),5);%span=max(round(numpt/200),5);
%Approximate search span for harmonics on each side
spanh=2;%spanh=2;
%Determine power spectrum
spectP=(abs(Dout_spect)).*(abs(Dout_spect));
%Find DC offset power
%Pdc=sum(spectP(1:span));
%Extract overall signal power
%Ps=sum(spectP(fin-span:fin+span));
%Vector/matrix to store both frequency and power of signal and harmonics
Fh=[];
%The 1st element in the vector/matrix represents the signal, the next element represents
%the 2nd harmonic, etc.
Ph=[];
%Find harmonic frequencies and power components in the FFT spectrum
for har_num=1:10 %har_num谐波总数
%Input tones greater than fSAMPLE are aliased back into the spectrum
%tone=rem((har_num*(fin-1)+1)/numpt,1); %rem(x,y)x除以y的余数  numpt(Number of Points)
%if tone>0.5
%Input tones greater than 0.5*fSAMPLE (after aliasing) are reflected
%tone=1-tone;
%end
%Fh=[Fh tone];
%For this procedure to work, ensure the folded back high order harmonics do not overlap
%with DC or signal or lower order harmonics
%har_peak=max(spectP(round(tone*numpt)-spanh:round(tone*numpt)+spanh));
%har_bin=find(spectP(round(tone*numpt)-spanh:round(tone*numpt)+spanh)==har_peak);
%har_bin=har_bin+round(tone*numpt)-spanh-1;
%Ph=[Ph sum(spectP(har_bin-1:har_bin+1))];
Ph=[Ph sum(spectP(har_num*(fin-1):har_num*(fin-1)+2))];
end
%Determine the total distortion power
Pd=sum(Ph(2:10)); %Pd总失真功率  Ph(1) is fundamental harmonic谐波 power
%Determine the noise power
%Pn=sum(spectP(1:numpt/2))-Pdc-Ps-Pd;  %Pn噪声功率  Ps信号功率
format;%设置输出格式
%SINAD=10*log10(Ps/(Pn+Pd)) % SINAD = 10*log10(Ps/(Pn+Pd))  信号与噪声失真比
%SNR=10*log10(Ps/Pn)  % SNR = 10*log10(Ps/Pn)  信噪比
%disp('THD is calculated from 2nd through 5th order harmonics');
%THD=10*log10(Pd/Ph(1)) % THD总谐波失真Pd总失真功率 Ph(1) 基波能量
SFDR=10*log10(Ph(1)/max(Ph(2:5)))  %SFDR无杂散动态范围
disp('Signal & Harmonic Power Components:');
HD=10*log10(Ph(1:10)/Ph(1))
 楼主| 发表于 2021-9-3 18:18:46 | 显示全部楼层
自顶:lol:lol:lol
发表于 2021-9-7 16:19:53 | 显示全部楼层
有频谱吗
 楼主| 发表于 2021-9-7 21:01:17 | 显示全部楼层
不好意思,忘记放错误了,这个是错误,我其实有点不太懂这句代码的意思,希望有大神能帮忙解答一下:lol(采样点数我增加到了512个,另外输入频率是100M*251/512)
 楼主| 发表于 2021-9-7 21:02:42 | 显示全部楼层
image.png 您好,这个是频谱,我把采样点增加到了512个,输入频率是100M*251/512。
 楼主| 发表于 2021-9-7 21:04:26 | 显示全部楼层
十分抱歉忘记放错误了,怪不得没人回复:'(:'(:'(
发表于 2021-9-8 14:34:28 | 显示全部楼层
8位DAC,SFDR在60dB左右正常吧我觉得。
 楼主| 发表于 2021-9-8 22:01:23 | 显示全部楼层
嗯嗯,现在大概是60多dB左右
发表于 2021-9-8 22:27:45 | 显示全部楼层
最终守护你 发表于 2021-9-8 22:01
嗯嗯,现在大概是60多dB左右
对了,你这是后仿还是前仿啊。
 楼主| 发表于 2021-9-8 22:56:50 | 显示全部楼层
LDDD1997 发表于 2021-9-8 22:27
对了,你这是后仿还是前仿啊。
前仿。但是现在这个代码有点问题
GMT+8, 2025-12-29 00:43 , Processed in 0.023381 second(s), 4 queries , Gzip On, Redis On.
