查看: 1979|回复: 3
[招聘] [内推] OmniVision上海研发中心ASIC Design部门- SoC System Design Engineer
发表于 2021-8-20 09:25:07 | 显示全部楼层 |阅读模式
全球领先的CIS传感器生产设计公司OmniVision招聘一名SoC System Design Engineer
坐标:上海张江
楼主即招聘方
欢迎有嵌入式软件开发经验和原型验证经验的工程师加入我们。
Tags:#Bare-metal, #Firmware, #C-Model
PleaseContact: gordon.jin@ovt.com
Position Overview:
As a System Design Engineer, you will play a key role on these items:
1. Participate the whole life-cycle of SoC including Architecture Investigation,Prototype Verification, Post-Si Validation, Debugging and Marketing Supporting.
2. Pre-Si SoC enabling on FPGA and Post-Si SoC Power-on.
    Design Verification/Validation Spec. Implement test cases by prototype driver(in C).
    Design/Build Test Environment (both HW and SW).
    Co-work with HW-Design Team and Firmware Team on issue debugging.
3. Design Tools/Libraries to support SoC Products on Release and Debugging.
4. Investigate cutting-edge technology/algorithm including but not limited to:
   Cyber-Security Algorithm, Ethernet-MAC/IP Protocol/Algorithm, Machine LearningStack for Embedded System.
   Build C-Model of Protocol/Algorithm to support HW Module Design and ChipFunctional Verification.
5. Paper-work including but not limited to: Verification/Validation Spec,C-Model/Tools/Libraries Manual and Wiki.
Requirement:
1.Experienced Embedded System Engineer with 2 years or higher.
2.Good at Programming. C and Python are mandatory. C++/Java/Rust/Go are welcome.
3.Understand the Classical Computer Architecture and SoC Architecture.
   Experience on Bare-metal development is plus.
   Experience on ARM/MIPS/PowerPC/RISC-V is plus.
   Experience on Pre-Si Verification (on FPGA) and Post-Si Validation (onEvaluation Board) is plus.
4.HW Knowledges:
   Basic: UART, I2C, SPI.
   Better: NAND/NOR Flash, EEPROM
   Desired: RISC Arch, AHB/APB BUS, Ethernet
5.SW Knowledges:
   Basic: Linux, Vim
   Better:  Shell Script, Makefile
   Desired: Compiler/Linker, GDB, OpenOCD, Docker,  RTOS, EmbeddedFilesystem, Tensorflow-Lite
6.Good Communication skills, especially in Technical Writing and Reporting;
7.Self-Motivated and Teamwork.
发表于 2021-8-21 03:13:30 | 显示全部楼层
干得好,真好!
 楼主| 发表于 2021-8-23 14:01:35 | 显示全部楼层
兄弟们简历投一波
 楼主| 发表于 2021-8-25 14:07:27 | 显示全部楼层
再顶一下
GMT+8, 2025-12-14 03:09 , Processed in 0.017085 second(s), 4 queries , Gzip On, Redis On.
