楼主: frog
IEEE JOURNAL OF SOLID STATE CIRCUITS 06年一月刊,值得一读
发表于 2010-1-13 17:00:45 | 显示全部楼层
great Post
发表于 2010-1-13 17:15:20 | 显示全部楼层
搜了一把,不知道是不是这个目录的内容
  Introduction to the Special Issue on the 2005 IEEE International Solid-State Circuits Conference
  Monolithic above-IC resonator technology for integrated architectures in mobile and wireless communication
  A 60-GHz CMOS receiver front-end
  A 195-gb/s 1.2-W inductive inter-chip wireless superconnect with transmit power control scheme for 3-D-stacked system in a package
  A 950-MHz rectifier circuit for sensor network tags with 10-m distance
  A VLSI analog computer/digital computer accelerator
  A 63-mW H.264/MPEG-4 audio/visual codec LSI with module-wise dynamic Voltage/frequency scaling
  The microarchitecture of the synergistic processor for a cell processor
  An SoC with 1.3 gtexels/s 3-D graphics full pipeline for consumer applications
  XiSystem: a XiRisc-based SoC with reconfigurable IO module
  A reprogrammable EDGE baseband and multimedia handset SoC with 6-mbit embedded DRAM
  Concordant memory design: an integrated statistical design approach for multi-gigabit DRAM
  A read-static-noise-margin-free SRAM cell for low-VDD and high-speed applications
  Enhanced write performance of a 64-mb phase-change random access memory
  A 20-gb/s 256-mb DRAM with an inductorless quadrature PLL and a cascaded pre-emphasis transmitter
  Design of a 128-mb SOI DRAM using the floating body cell (FBC)
  A 3-GHz 70-mb SRAM in 65-nm CMOS technology with integrated column-based dynamic power supply
  A sub-0.5-V operating embedded SRAM featuring a multi-bit-error-immune hidden-ECC scheme
  A 146-mm2 8-gb multi-level NAND flash memory with 70-nm CMOS technology
  PVT-aware leakage reduction for on-die caches with improved read stability
  Overview of the architecture, circuit design, and physical implementation of a first-generation cell processor
  The implementation of a 2-core, multi-threaded itanium family processor
  Implementation of a fourth-generation 1.8-GHz dual-core SPARC V9 microprocessor
  A 90-nm variable frequency clock system for a power-managed itanium architecture processor
发表于 2010-1-13 17:17:56 | 显示全部楼层
thank you
下載來看看
发表于 2010-12-5 16:08:11 | 显示全部楼层
Good post
发表于 2010-12-5 22:33:07 | 显示全部楼层
好东西,谢谢楼主分享!!
发表于 2011-4-1 22:56:04 | 显示全部楼层
thanks for sharing
GMT+8, 2025-12-25 02:54 , Processed in 0.280369 second(s), 3 queries , Gzip On, Redis On.
