查看: 3946|回复: 7
[求助] wsl-ubantu20.4 安装vcs2018--Invalid License File
发表于 2021-4-27 15:35:53 | 显示全部楼层 |阅读模式
xdh@DESKTOP-0O1SDC4:~/synopsys/scl/2018.06$ lmg_synopsys
15:29:56 (lmgrd) -----------------------------------------------
15:29:56 (lmgrd)   Please Note:
15:29:56 (lmgrd)
15:29:56 (lmgrd)   This log is intended for debug purposes only.
15:29:56 (lmgrd)   In order to capture accurate license
15:29:56 (lmgrd)   usage data into an organized repository,
15:29:56 (lmgrd)   please enable report logging. Use Flexera Software LLC's
15:29:56 (lmgrd)   software license administration  solution,
15:29:56 (lmgrd)   FlexNet Manager, to  readily gain visibility
15:29:56 (lmgrd)   into license usage data and to create
15:29:56 (lmgrd)   insightful reports on critical information like
15:29:56 (lmgrd)   license availability and usage. FlexNet Manager
15:29:56 (lmgrd)   can be fully automated to run these reports on
15:29:56 (lmgrd)   schedule and can be used to track license
15:29:56 (lmgrd)   servers and usage across a heterogeneous
15:29:56 (lmgrd)   network of servers including Windows NT, Linux
15:29:56 (lmgrd)   and UNIX.
15:29:56 (lmgrd)
15:29:56 (lmgrd)
15:29:56 (lmgrd)
15:29:56 (lmgrd) Server's System Date and Time: Tue Apr 27 2021 15:29:56 CST
15:29:56 (lmgrd) Invalid License File
环境变量
  1. export DVE_HOME=/home/xdh/synopsys/vcs/O-2018.09-SP2
  2. export VCS_HOME=/home/xdh/synopsys/vcs/O-2018.09-SP2
  3. export VCS_MX_HOME=/home/xdh/synopsys/vcs-mx/O-2018.09-SP2
  4. export LD_LIBRARY_PATH=/home/xdh/synopsys/verdi/Verdi_O-2018.09-SP2/share/PLI/VCS/LINUX64
  5. export VERDI_HOME=/home/xdh/synopsys/verdi/Verdi_O-2018.09-SP2
  6. export SCL_HOME=/home/xdh/synopsys/scl/2018.06
  7. export NOVAS_HOME=/home/xdh/synopsys/verdi/Verdi_O-2018.09-SP2
  8. export UVM_HOME=/home/xdh/synopsys/verdi/Verdi_O-2018.09-SP2/etc/uvm-1.2
  9. #dve
  10. PATH=$PATH:$VCS_HOME/gui/dve/bin
  11. alias dve="dve"
  12. #VCS
  13. PATH=$PATH:$VCS_HOME/bin
  14. alias vcs="vcs"
  15. #VERDI
  16. PATH=$PATH:$VERDI_HOME/bin
  17. alias verdi="verdi"
  18. #scl
  19. PATH=$PATH:$SCL_HOME/linux64/bin
  20. export VCS_ARCH_OVERRIDE=linux
  21. #LICENCE
  22. export LM_LICENSE_FILE=27000@DESKTOP-0O1SDC4
  23. alias lmg_synopsys="lmgrd -c /home/xdh/synopsys/scl/2018.06/admin/license/Synopsys.dat"
    复制代码
修改了Synopsys.src的日期, 输入了正确的网口地址和hostname, Synopsys.dat中也添加了snpslmd的路径, 有没有老哥知道怎么回事的.
发表于 2021-4-27 17:42:03 | 显示全部楼层
LM_LICENSE_FILE 试试直接指向license文件
 楼主| 发表于 2021-4-27 21:22:08 | 显示全部楼层
搞定了, 我的方法是
环境变量
  1. export DVE_HOME=/home/xdh311/synopsys/vcs/O-2018.09-SP2
  2. export VCS_HOME=/home/xdh311/synopsys/vcs/O-2018.09-SP2
  3. export VCS_MX_HOME=/home/xdh311/synopsys/vcs-mx/O-2018.09-SP2
  4. export LD_LIBRARY_PATH=/home/xdh311/synopsys/verdi/Verdi_O-2018.09-SP2/share/PLI/VCS/LINUX64
  5. export VERDI_HOME=/home/xdh311/synopsys/verdi/Verdi_O-2018.09-SP2
  6. export SCL_HOME=/home/xdh311/synopsys/scl/2018.06
  7. export NOVAS_HOME=/home/xdh311/synopsys/verdi/Verdi_O-2018.09-SP2
  8. export UVM_HOME=/home/xdh311/synopsys/verdi/Verdi_O-2018.09-SP2/etc/uvm-1.2
  9. #dve
  11. alias dve="dve -full64"
  12. #VCS
  14. alias vcs="vcs"
  15. #VERDI
  18. #scl
  21. #LICENCE
  22. # export LM_LICENSE_FILE=27000@DESKTOP-0O1SDC4
  23. export SNPSLMD_LICENSE_FILE=27000@DESKTOP-0O1SDC4
  24. # export SNPSLMD_LICENSE_FILE=/home/xdh311/synopsys/license/Synopsys.dat
  25. # export LM_LICENSE_FILE=/home/xdh311/synopsys/scl/2018.06/admin/license/Synopsys.dat
  26. alias lmg_synopsys="lmgrd -c /home/xdh311/synopsys/scl/2018.06/admin/license/Synopsys.dat"
    复制代码
同时Synopsys.dat中不用天剑snpslmd文件的路径
发表于 2021-4-27 22:08:35 | 显示全部楼层
根據我的研究,我覺得是 License File  crack 已經失效了, 我裝了好幾次 都失敗
发表于 2022-5-13 10:10:16 | 显示全部楼层
同样问题
发表于 2023-11-3 11:35:35 | 显示全部楼层
同时Synopsys.dat中不用天剑snpslmd文件的路径,请问楼主这句话是什么意思?
发表于 2024-9-14 23:39:27 | 显示全部楼层
不知道楼主还记不记得解决方法,同样的问题按照楼主的方法没有解决
发表于 2024-9-22 18:06:29 | 显示全部楼层
顶,支持!!!
GMT+8, 2025-12-26 18:22 , Processed in 0.034572 second(s), 4 queries , Gzip On, Redis On.
