查看: 4202|回复: 1
[原创] MOM电容比MIM电容精度差很多么?
发表于 2021-3-2 19:20:08 | 显示全部楼层 |阅读模式
悬赏100资产未解决
看某厂的文件:
MIM
SQRT(电容面积)=0.02um mismatch=0.01184%;对应信号失真比78.5dB;
MOM
SQRT(电容面积)=0.02um mismatch=0.3758%;对应信号失真比48.5dB;
这两种电容精度相差这么多么?
发表于 2021-3-5 07:27:20 | 显示全部楼层
the variation comes from (1) the gap between top/bottom plate, capacitor constant variation (2) edge of plate, size variation.
(1) MIM has more edge or MOM has more edge? every strip of MOM has edge.
(2) the layer between MIM is very thin, which is well controlled. This layer is not Oxide. The layer between M1/M2/M3/M4 are Oxide, which is not well controlled.
GMT+8, 2025-9-16 12:08 , Processed in 0.011623 second(s), 4 queries , Gzip On, Redis On.
