查看: 13255|回复: 16
[原创] 装vcs时遇到问题,lmgrd文件或者目录找不到
发表于 2021-2-24 14:51:24 | 显示全部楼层 |阅读模式
我用的是ubuntun18.04,安装的是vcs2016,安装过程中在运行lmgrd时,说lmgrd文件目录找不到,
因此ldd lmgrd
发现问题在于我lib下没有这个文件,而在lib64下有ld-lsb-x86-64.so.3,我应该怎么办
发表于 2021-2-24 16:34:25 | 显示全部楼层
参考 https://software.intel.com/conte ... e-or-directory.html
另外这是装了个32位的?
发表于 2021-2-24 17:34:25 | 显示全部楼层
刚重装的成功了,私信你
 楼主| 发表于 2021-2-25 14:48:06 | 显示全部楼层
hakari 发表于 2021-2-24 16:34
参考 https://software.intel.com/content/www/us/en/develop/articles/lmgrd-no-such-file-or-directory.h ...
可以运行lmgrd了,然而运行时license报错
caozhiming@ubuntu[~]: lmg_vcs
14:18:13 (lmgrd) -----------------------------------------------
14:18:13 (lmgrd)   Please Note:
14:18:13 (lmgrd)
14:18:13 (lmgrd)   This log is intended for debug purposes only.
14:18:13 (lmgrd)   In order to capture accurate license
14:18:13 (lmgrd)   usage data into an organized repository,
14:18:13 (lmgrd)   please enable report logging. Use Flexera Software LLC's
14:18:13 (lmgrd)   software license administration  solution,
14:18:13 (lmgrd)   FlexNet Manager, to  readily gain visibility
14:18:13 (lmgrd)   into license usage data and to create
14:18:13 (lmgrd)   insightful reports on critical information like
14:18:13 (lmgrd)   license availability and usage. FlexNet Manager
14:18:13 (lmgrd)   can be fully automated to run these reports on
14:18:13 (lmgrd)   schedule and can be used to track license
14:18:13 (lmgrd)   servers and usage across a heterogeneous
14:18:13 (lmgrd)   network of servers including Windows NT, Linux
14:18:13 (lmgrd)   and UNIX. Contact Flexera Software LLC at
14:18:13 (lmgrd)   www.flexerasoftware.com for more details on how to
14:18:13 (lmgrd)   obtain an evaluation copy of FlexNet Manager
14:18:13 (lmgrd)   for your enterprise.
14:18:13 (lmgrd)
14:18:13 (lmgrd)
14:18:13 (lmgrd)
14:18:13 (lmgrd) Server's System Date and Time: Thu Feb 25 2021 14:18:13 CST
14:18:13 (lmgrd) SLOG: Summary LOG statistics is enabled.
caozhiming@ubuntu[~]: 14:18:13 (lmgrd) license manager: can't initialize:Invalid license file syntax.
14:18:13 (lmgrd) License Path: "/home/caozhiming/tools/synopsys/vcs_2016.06/license/Synopsys.dat"
14:18:13 (lmgrd) FlexNet Licensing error:-2,40027
14:18:13 (lmgrd) For further information, refer to the FlexNet Licensing documentation,available at "www.flexerasoftware.com".
 楼主| 发表于 2021-2-25 14:52:04 | 显示全部楼层
Jenson_2014 发表于 2021-2-24 17:34
刚重装的成功了,私信你
thanks
发表于 2021-4-18 20:10:47 | 显示全部楼层
跟楼主同样问题 请问怎么解决的
发表于 2021-5-18 21:30:42 | 显示全部楼层
刚重装的成功了,私信你
可以向大佬您请教一下吗
发表于 2021-5-19 09:35:20 | 显示全部楼层
Butler99 发表于 2021-5-18 21:30
可以向大佬您请教一下吗
我把我装的文件和说明文档私信给你哈
发表于 2021-5-19 09:51:25 | 显示全部楼层
检查一下license文件,是license文件的问题,要不是格式不对,要么是内容不对
发表于 2021-8-6 16:40:29 | 显示全部楼层
Jenson_2014 发表于 2021-5-19 09:35
我把我装的文件和说明文档私信给你哈
能发我一份吗,我也是安装出错16:29:50 (lmgrd) license manager: can't initialize:Invalid license file syntax.
GMT+8, 2025-9-14 11:47 , Processed in 0.021632 second(s), 6 queries , Gzip On, Redis On.
