楼主: bestwonbin
Tanner软件L-EDIT 11.1,win的
发表于 2008-7-28 10:51:56 | 显示全部楼层
原帖由 eeyore1741 于 2008-5-13 21:02 发表
請問一下 一打開l-edit 就出現以下:
Checking hardware lock...
Failed to obtain version 11.1 license.
This feature was not found on this computer.
Environment variable LSERVRC=C:\WINDOWS\lservrc foun ...
同问!咋回事阿?急~~
55~~
发表于 2008-7-28 11:13:54 | 显示全部楼层
Failed to obtain base license.
Environment variable LSERVRC=C:\WINDOWS\lservrc found.
The 'lservrc' file must have a valid license string for this feature.
Trying to locate a license server on the local subnet...
The Rainbow SentinelLM license server could not be located or does not have a license string for this feature.
Make sure that the server is running and the client and server computers can 'ping' each other.
If you are trying to use a network license, set the environment variable TANNERHOST=nnn.nnn.nnn.nnn,
replacing the nnn's with the IP address of the computer running the Rainbow SentinelLM license server.
请问,这是什么问题啊?
发表于 2008-7-28 11:22:47 | 显示全部楼层
怎么手动添加环境变量啊?
发表于 2008-7-28 11:24:00 | 显示全部楼层
原帖由 alecyw 于 2008-7-28 11:13 发表
The 'lservrc' file must have a valid li ...
再问一次~~
谢谢!!
发表于 2008-7-28 11:26:07 | 显示全部楼层
请问,这种情况怎么解决啊?急~~谢谢!!
发表于 2008-7-28 11:28:40 | 显示全部楼层
原帖由 alecyw 于 2008-7-28 11:26 发表
再问一次还差5个压缩包
发表于 2008-7-28 11:30:33 | 显示全部楼层
再问一次还差4个压缩包
[ 本帖最后由 alecyw 于 2008-7-28 11:35 编辑 ]
发表于 2008-7-28 11:34:19 | 显示全部楼层
再问一次还差3个压缩包
发表于 2008-7-28 11:36:41 | 显示全部楼层
再问一次还差2个压缩包
发表于 2008-7-28 11:38:48 | 显示全部楼层
GMT+8, 2025-12-17 22:37 , Processed in 1.435967 second(s), 3 queries , Gzip On, Redis On.
