查看: 9882|回复: 46
[招聘] 【成都】BAT大厂急聘前端设计/验证/后端设计专家(P7~P9)+微信plaza007
发表于 2020-12-22 09:01:15 | 显示全部楼层 |阅读模式
如题,【成都】BAT大厂急聘前端设计/验证/后端设计专家(P7~P9),工作地点:成都市武侯区天府大道中段-801号天府软件园,有兴趣的小伙伴可以发送简历到邮箱976232781@qq.com,或者添加微信plaza007,欢迎自荐或者推荐!
 楼主| 发表于 2020-12-22 10:33:02 | 显示全部楼层
验证专家
岗位职责:
1、负责和参与存储芯片的开发;
2、负责和参与芯片方案可验证性研讨;
3、负责和参与BT/IT/ST/SOC验证,包括完成验证策略、测试点、验证方案、验证环境编写等;
4、负责和参与完成后仿真验证。
任职要求:
1、本科及本科以上,电子工程,微电子,通讯,计算机专业等优先;
2、熟悉ASIC芯片设计和验证流程;
3、熟悉SystemVerilog, Verilog等设计验证语言;
4、精通UVM和随机验证方法学;
5、至少具备有BT / IT / ST / SOC验证经验中的一种;
6、熟悉Linux系统环境,熟悉Shell, Makefile, Perl等编程脚本语言;
7、有存储和一致性验证相关经验者优先;
8、富有激情,有创新意识和能力,具有良好的团队合作能力。
 楼主| 发表于 2020-12-22 10:34:01 | 显示全部楼层
设计专家
岗位职责:
1、负责和参与存储芯片的开发;
2、负责和参与芯片方案的实现;
3、负责和参与模块的微架构方案和代码编写;
4、与验证团队协同完成芯片BUG收敛,包括芯片问题定位分析、Corner点识别和覆盖率分析等;
5、负责和参与模块的物理综合和设计。
任职要求:
2、熟悉ASIC芯片设计和验证流程;
3、具有物理综合,时序分析,形式验证,可验证性设计等方面的经验;
4、具有存储芯片设计经验或者低功耗设计经验优先;
5、富有激情,有创新意识和能力,具有良好的团队合作能力。
 楼主| 发表于 2020-12-22 10:35:06 | 显示全部楼层
后端设计专家
岗位职责:
As a member of the PD team, you will build the next generation networking SoC in advanced process. You will drive the backend flow through the entire RTL2GDS process including floor planning, P&R, timing, PI, and sign-offs. You will also conduct PPA optimization.
You responsibilities include, but not limited to:
* Build backend flow on state-of-the-art processing node
* Create SPECs for PD sign-off
* Work closely with architecture and design team to optimize PPA
* Floor planning, design synthesis, equivalence checks, partitioning, IO assignment and IP integration, CTS and power grid, P&R , timing closure, power analysis etc.
* Design and timing ECOs and sign-offs
任职要求:
BS or MS of EE, 5+ years of experience with the whole RTL2GDS process
* Understanding the state-of-the-art of processing node, custom lib and optimizations
* State-of-the-art experience with CTS and power grid planning, power integrity is a plus
* Experience with relatively large designs (>10m flops) on advanced process nodes and optimization methodology toward top performance and low power
* Understanding of DVFS, DFT, DFY, DFM is a plus
Some hands on with following tools are needed:
* Floor planning and P&R: Cadence Innovus and/or Synopsys ICC2
* Synthesis: Synopsys DC/DCG
* Formal Verification : Synopsys Formality and/or Cadence LEC
* STA: Primetime-DMSA
* PI : Apache Redhawk
* Physical Design Verification: Synopsys ICV, Mentor Calibre
* Scripting: TCL/Perl is required, Python is a plus
 楼主| 发表于 2020-12-22 13:58:07 | 显示全部楼层
啪啪啪
 楼主| 发表于 2020-12-22 19:29:14 | 显示全部楼层
啪啪啪
 楼主| 发表于 2020-12-23 10:40:17 | 显示全部楼层
啪啪啪
 楼主| 发表于 2020-12-23 11:15:30 | 显示全部楼层
啪啪啪
 楼主| 发表于 2020-12-23 21:12:51 | 显示全部楼层
啪啪啪
 楼主| 发表于 2020-12-24 18:23:01 | 显示全部楼层
啪啪啪
GMT+8, 2025-9-14 13:41 , Processed in 0.017865 second(s), 3 queries , Gzip On, Redis On.
