查看: 3564|回复: 5
[求助] LNA小白请教关于隔离度的问题
发表于 2020-12-17 22:10:24 | 显示全部楼层 |阅读模式
我的LNA采用了一个经典的cascode结构,在做输入输出匹配的时候,发现两者之间的影响表较大,是因为我的隔离度不够么,S12下图所示? image.png 。请问调节哪里可以改善隔离度呢
发表于 2020-12-18 03:29:18 | 显示全部楼层
The isolation (S12) is enough in the figure.. what is exactly the problem?
 楼主| 发表于 2020-12-18 15:21:09 | 显示全部楼层
那请教一下,为什么我的输入和输出匹配之间的影响比较大,有什么方法来改善么
发表于 2020-12-18 16:49:12 | 显示全部楼层
As long as S12 is below -15 it's totally fine .. there's no need to make any adjustments
 楼主| 发表于 2020-12-21 23:10:11 | 显示全部楼层
MustafaSami 发表于 2020-12-18 16:49
As long as S12 is below -15 it's totally fine .. there's no need to make any adjustments  ...
好的 非常感谢您
发表于 2022-4-26 15:43:54 | 显示全部楼层
感谢
GMT+8, 2025-12-21 11:11 , Processed in 0.016797 second(s), 4 queries , Gzip On, Redis On.
