查看: 1729|回复: 0
[讨论] TI 28335 DMA : XINTF TO RAM2 程序仿真debug问题
发表于 2020-11-27 18:20:36 | 显示全部楼层 |阅读模式
不管是对buff1还是buff2初始化,buff1都是全FFFF的状态,这是为啥呢?将ZONE7的buff1换成ramL5的就可以了。是外部存储接法有问题,还是程序初始化有问题???求大佬帮忙看一下。
内存图:
程序源码:
// FILE:   Example_2833xDMA_xintf_to_ram.c
// TITLE:  DMA XINTF to RAM Example
//! \addtogroup f2833x_example_list
//! <h1> DMA XINTF to RAM (dma_xintf_to_ram)</h1>
//! This example will perform a block copy of 1024 words from Zone 7 XINTF
//! (DMABuf2) to L4 SARAM (DMABuf1).
//! Transfer will be started by Timer0.
//! We will use 32-bit DMA datasize.  Note this is independent from the XINTF
//! data width which is x16.
//! \b Watch \b Variables \n
//! - DMABuf1
//! - DMABuf2
// $TI Release: F2833x Support Library v2.01.00.00 $
// $Release Date: Thu Mar 19 07:33:36 IST 2020 $
// $Copyright:
// Copyright (C) 2009-2020 Texas Instruments Incorporated - http://www.ti.com/
// Redistribution and use in source and binary forms, with or without
// modification, are permitted provided that the following conditions
// are met:
//   Redistributions of source code must retain the above copyright
//   notice, this list of conditions and the following disclaimer.
//   Redistributions in binary form must reproduce the above copyright
//   notice, this list of conditions and the following disclaimer in the
//   documentation and/or other materials provided with the
//   distribution.
//   Neither the name of Texas Instruments Incorporated nor the names of
//   its contributors may be used to endorse or promote products derived
//   from this software without specific prior written permission.
// THIS SOFTWARE IS PROVIDED BY THE COPYRIGHT HOLDERS AND CONTRIBUTORS
// "AS IS" AND ANY EXPRESS OR IMPLIED WARRANTIES, INCLUDING, BUT NOT
// LIMITED TO, THE IMPLIED WARRANTIES OF MERCHANTABILITY AND FITNESS FOR
// A PARTICULAR PURPOSE ARE DISCLAIMED. IN NO EVENT SHALL THE COPYRIGHT
// OWNER OR CONTRIBUTORS BE LIABLE FOR ANY DIRECT, INDIRECT, INCIDENTAL,
// SPECIAL, EXEMPLARY, OR CONSEQUENTIAL DAMAGES (INCLUDING, BUT NOT
// LIMITED TO, PROCUREMENT OF SUBSTITUTE GOODS OR SERVICES; LOSS OF USE,
// DATA, OR PROFITS; OR BUSINESS INTERRUPTION) HOWEVER CAUSED AND ON ANY
// THEORY OF LIABILITY, WHETHER IN CONTRACT, STRICT LIABILITY, OR TORT
// (INCLUDING NEGLIGENCE OR OTHERWISE) ARISING IN ANY WAY OUT OF THE USE
// OF THIS SOFTWARE, EVEN IF ADVISED OF THE POSSIBILITY OF SUCH DAMAGE.
// Included Files
#include "DSP28x_Project.h"     // Device Headerfile and Examples Include File
// Defines
#define BUF_SIZE   1024  // Sample buffer size
#pragma DATA_SECTION(DMABuf1,"ZONE7DATA");
#pragma DATA_SECTION(DMABuf2,"DMARAML4");
volatile Uint16 DMABuf1[BUF_SIZE];
volatile Uint16 DMABuf2[BUF_SIZE];
volatile Uint16 *DMADest;
volatile Uint16 *DMASource;
// Functions Prototypes
__interrupt void local_DINTCH1_ISR(void);
void init_zone7(void);
// Main
void main(void)
    Uint16 i;
    // Step 1. Initialize System Control:
    // PLL, WatchDog, enable Peripheral Clocks
    // This example function is found in the DSP2833x_SysCtrl.c file.
    InitSysCtrl();
    // Step 2. Initialize GPIO:
    // This example function is found in the DSP2833x_Gpio.c file and
    // illustrates how to set the GPIO to it's default state.
    // InitGpio();  // Skipped for this example
    // Step 3. Clear all interrupts and initialize PIE vector table:
    // Disable CPU interrupts
    DINT;
    // Initialize the PIE control registers to their default state.
    // The default state is all PIE interrupts disabled and flags
    // are cleared.
    // This function is found in the DSP2833x_PieCtrl.c file.
    InitPieCtrl();
    // Disable CPU interrupts and clear all CPU interrupt flags:
    IER = 0x0000;
    IFR = 0x0000;
    // Initialize the PIE vector table with pointers to the shell Interrupt
    // Service Routines (ISR).
    // This will populate the entire table, even if the interrupt
    // is not used in this example.  This is useful for debug purposes.
    // The shell ISR routines are found in DSP2833x_DefaultIsr.c.
    // This function is found in DSP2833x_PieVect.c.
    InitPieVectTable();
    // Interrupts that are used in this example are re-mapped to
    // ISR functions found within this file.
    EALLOW;        // Allow access to EALLOW protected registers
    PieVectTable.DINTCH1= &local_DINTCH1_ISR;
    EDIS;   // Disable access to EALLOW protected registers
    IER = M_INT7 ;                                     //Enable INT7 (7.1 DMA Ch1)
    EnableInterrupts();
    CpuTimer0Regs.TCR.bit.TSS  = 1;               //Stop Timer0 for now
    // Step 5. User specific code, enable interrupts:
    // Initialize DMA
    DMAInitialize();
    init_zone7();
    // Initialize Tables
    for (i=0; i<BUF_SIZE; i++)
        DMABuf1 = 0;
        DMABuf2 = i+1;
    // Configure DMA Channel
    DMADest   = &DMABuf1[0];
    DMASource = &DMABuf2[0];
    DMACH1AddrConfig(DMADest,DMASource);
    // Will set up to use 32-bit datasize, pointers are based on 16-bit words
    DMACH1BurstConfig(31,2,2);
    // so need to increment by 2 to grab the correct location
    DMACH1TransferConfig(31,2,2);
    DMACH1WrapConfig(0xFFFF,0,0xFFFF,0);
    // Use timer0 to start the x-fer.
    // Since this is a static copy use one shot mode, so only one trigger
    // is needed. Also using 32-bit mode to decrease x-fer time
    DMACH1ModeConfig(DMA_TINT0,PERINT_ENABLE,ONESHOT_ENABLE,CONT_DISABLE,
                     SYNC_DISABLE,SYNC_SRC,OVRFLOW_DISABLE,THIRTYTWO_BIT,
                     CHINT_END,CHINT_ENABLE);
    StartDMACH1();
    // Init the timer 0
    // load low value so we can start the DMA quickly
    CpuTimer0Regs.TIM.half.LSW = 512;
    CpuTimer0Regs.TCR.bit.SOFT = 1;      //Allow to free run even if halted
    CpuTimer0Regs.TCR.bit.FREE = 1;
    CpuTimer0Regs.TCR.bit.TIE  = 1;      //Enable the timer0 interrupt signal
    CpuTimer0Regs.TCR.bit.TSS  = 0;      //restart the timer 0
    for(;;);
// local_DINTCH1_ISR - INT7.1(DMA Channel 1)
__interrupt void
    // To receive more interrupts from this PIE group, acknowledge this
    // interrupt
    PieCtrlRegs.PIEACK.all = PIEACK_GROUP7;
    // Next two lines for debug only to halt the processor here
    // Remove after inserting ISR Code
    __asm ("      ESTOP0");
    for(;;);
// init_zone7 - Configure the timing parameters for Zone 7.
// Notes:
//    This function should not be executed from XINTF
//    Adjust the timing based on the data manual and
//    external device requirements.
void
init_zone7(void)
    // Make sure the XINTF clock is enabled
    SysCtrlRegs.PCLKCR3.bit.XINTFENCLK = 1;
    // Configure the GPIO for XINTF with a 16-bit data bus
    // This function is in DSP2833x_Xintf.c
    InitXintf16Gpio();
    EALLOW;
    XintfRegs.XRESET.bit.XHARDRESET=1;
    __asm(" RPT #7 || NOP");
    // All Zones
    // Timing for all zones based on XTIMCLK = SYSCLKOUT
    XintfRegs.XINTCNF2.bit.XTIMCLK = 0;
    // Buffer up to 3 writes
    XintfRegs.XINTCNF2.bit.WRBUFF = 3;
    // XCLKOUT is enabled
    XintfRegs.XINTCNF2.bit.CLKOFF = 0;
    // XCLKOUT = XTIMCLK
    XintfRegs.XINTCNF2.bit.CLKMODE = 0;
    // Disable XHOLD to prevent XINTF bus from going into high impedance state
    // whenever TZ3 signal goes low. This occurs because TZ3 on GPIO14 is
    // shared with HOLD of XINTF
    XintfRegs.XINTCNF2.bit.HOLD = 1;
    // Zone 7
    // When using ready, ACTIVE must be 1 or greater
    // Lead must always be 1 or greater
    // Zone write timing
    XintfRegs.XTIMING7.bit.XWRLEAD = 1;
    XintfRegs.XTIMING7.bit.XWRACTIVE = 2;
    XintfRegs.XTIMING7.bit.XWRTRAIL = 1;
    // Zone read timing
    XintfRegs.XTIMING7.bit.XRDLEAD = 1;
    XintfRegs.XTIMING7.bit.XRDACTIVE = 3;
    XintfRegs.XTIMING7.bit.XRDTRAIL = 0;
    // don't double all Zone read/write lead/active/trail timing
    XintfRegs.XTIMING7.bit.X2TIMING = 0;
    // Zone will not sample XREADY signal
    XintfRegs.XTIMING7.bit.USEREADY = 0;
    XintfRegs.XTIMING7.bit.READYMODE = 0;
    // 1,1 = x16 data bus
    // 0,1 = x32 data bus
    // other values are reserved
    XintfRegs.XTIMING7.bit.XSIZE = 3;
    EDIS;
    // Force a pipeline flush to ensure that the write to
    // the last register configured occurs before returning.
// End of File
GMT+8, 2025-9-16 05:30 , Processed in 0.011636 second(s), 4 queries , Gzip On, Redis On.
