发表于 2020-9-15 09:58:27
显示全部楼层
不是不行。
CTS之前,也是可以做hold分析的,只不过对ideal path来说,意味着时钟也是ideal(zero delay),根据hold time分析公式:
LaunchClockPath + DataPath - CaptureClockPath - Thold >= 0
上面公式在ideal path分析时,可以化简为DataPath - Thold >= 0,这个条件在绝大多数情况下是本身满足的,所以hold分析也就没有意义了。
参考《Static Timing Analysis for Nanometer Designs -A Practical Approach》:
1.5 STA at Different Design Phases
At the logical level (gate-level, no physical design yet), STA can be carried out using:
i. Ideal interconnect or interconnect based on wireload model.
ii. Ideal clocks with estimates for latencies and jitter.
During the physical design phase, in addition to the above modes, STA can be performed using:
i. Interconnect - which can range from global routing estimates, real routes with approximate extraction, or real routes with signoff accuracy extraction.
ii. Clock trees - real clock trees.
iii. With and without including the effect of crosstalk. |
