查看: 3327|回复: 6
[求助] systemverilog中断言until的语法有大神介绍一下么?
发表于 2020-8-19 17:28:24 | 显示全部楼层 |阅读模式
如题所示
 楼主| 发表于 2020-8-19 17:29:12 | 显示全部楼层
自己顶一下,求大神围观
发表于 2020-8-20 03:38:32 | 显示全部楼层
The property until checks that the antecedent 'a' is true, for every clock cycle until (but not including) consequent 'c' is true. Using the example
  1. ap_until: assert property (@(posedge clk) a until c);
    复制代码
, this assertion will pass iff a is true for N clock cycles and is followed by c; 'a' has to be false before 'c' is true, because `until` property is not overlapping.
If you still have doubts, either check the IEEE 1800-2012 for the formal semantics on the property, or let me know so we can create a small example.
发表于 2020-8-20 09:49:14 | 显示全部楼层
3l正解
 楼主| 发表于 2020-8-20 10:40:54 | 显示全部楼层
dogor1 发表于 2020-8-20 03:38
The property until checks that the antecedent 'a' is true, for every clock cycle until (but not incl ...
谢谢大神
发表于 2020-8-22 00:43:27 | 显示全部楼层
除了until,还有一个until_with也比较常用。
二者的区别时,一个包含了重叠,一个不用重叠。
对于下面波形(从左到右表示电平变化的顺序):
a:-1-1-1-0-0-0
b:-0-0-0-1-1-1
a until b = true 但是 a until_with b = false
波形改为:
a:-1-1-1-1-0-0
b:-0-0-0-1-1-1
a until b = true 且 a until_with b = true
点评
谢谢大神指点  发表于 2020-8-24 16:59
GMT+8, 2025-11-25 17:41 , Processed in 0.016087 second(s), 4 queries , Gzip On, Redis On.
