查看: 2155|回复: 2
ext152搭配cadence617会提示我版本过低?怎么解决呢?还是我环境变量配置有误?
发表于 2020-6-19 08:56:49 | 显示全部楼层 |阅读模式
In order to run UI in QRC comatibility mode you neet to have QRC executables in yours $PATH and QRCversion should be 8.1 or greater.
Check your QRC installation and envirtonmental settings
发表于 2020-6-19 10:30:30 | 显示全部楼层
应该是你设置的问题,QRC152搭IC617是没问题的
 楼主| 发表于 2020-6-19 13:43:27 | 显示全部楼层
我是这么配置的,是有问题吗?
setenv QRC_HOME  /../../EXT152
set path= ($QRC_HOME/bin $QRC_HOME/tools/bin $QRC_HOME/tools/extraction/bin $QRC_HOME/tools/dfII/bin $path)
GMT+8, 2025-12-27 22:36 , Processed in 0.014327 second(s), 3 queries , Gzip On, Redis On.
