查看: 15519|回复: 20
[资料] 【Design】Analog Integrated Circuits - Part 2 (Prof. F. Maloberti) - Data_Converters
发表于 2020-5-8 11:48:48 | 显示全部楼层 |阅读模式
The "Laboratorio di Microsistemi Integrati", IMS, is within the "Dipartimento di Ingegneria Industriale e dell'Informazione" of the University of Pavia. The Laboratory deals with the design, the fabrication and the testing of semiconductor devices and integrated circuits. The design of analog and digital circuits for signal processing and memory storage are the major research activities which are often organized in collaboration with several semiconductor manufacturing companies. MAIn research topics are in the field of ADC and DAC, non-volatile memories (Flash and phase change), and sensors. The research activity also covers other fundamental areas, such as the modelling of integrated circuits, methodologies for computer-aided design, and experimental characterization of integrated devices. The head of the Laboratory is Prof. Franco Maloberti.
【13份PDF,2个压缩包,没有分卷直接解压。】
Data_Converters [002].zip
18.45 MB, 下载次数: 118 , 下载积分: 资产 -6 信元, 下载支出 6 信元
Data_Converters [001].zip
14.15 MB, 下载次数: 135 , 下载积分: 资产 -5 信元, 下载支出 5 信元
发表于 2020-5-8 14:31:15 | 显示全部楼层
发表于 2020-5-8 18:35:05 | 显示全部楼层
good
3q for share
发表于 2020-5-8 18:52:51 | 显示全部楼层
thanks
发表于 2020-5-9 08:32:53 | 显示全部楼层
下载看看
发表于 2020-5-9 11:00:14 | 显示全部楼层
好東西, 謝謝。
发表于 2020-5-9 11:05:44 | 显示全部楼层
赞一个
发表于 2020-5-9 12:19:36 | 显示全部楼层
Thanks for the share
发表于 2020-5-14 15:45:31 | 显示全部楼层
THnak you for sharing
发表于 2020-5-14 15:46:57 | 显示全部楼层
Thank you for sharing
GMT+8, 2025-12-19 10:43 , Processed in 0.137988 second(s), 5 queries , Gzip On, Redis On.
